Question about MSI P4M900M-L Motherboard
UnKnow Bios error Error Code =8302 Sr, Computer Opening No Display ....F1 Press Continue Display Ok
  • 487 Answers
Hi, this can be caused by a BIOS update or a faulty motherboard battery. You can reset BIOS to default settings by pressing the F1 key during bootup, which will take you to the BIOS screen.
Posted on Aug 04, 2010
    New Friend:
Tambien me pasa lo mismo pero no se pueden restaurar los valores
Posted on Feb 10, 2013
Emachines pc unknown error code 8302-press f1 to continue
http://www.tomshardware.co.uk/forum/295726-30-bios-error-code-8302 READ IT.IT EXPLANES THE PROBLEM.
Apr 05, 2013 | E-Machines eMachines Desktop PC
Emachines pc unknown error code 8302 press f1 to continue
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove power from the PSU, then do >>Clear CMOS Guide<<
then leave one memory stick only in 1st DIMM close to CPU socket.
Then try to boot, if that can be done, enter in BIOS Setup and "Load BIOS Optimized Defaults" followed by save and exit.
Apr 05, 2013 | Computers & Internet
Bios error 8302
Hi, there could be a number of reason for this ..
1. Hardware problem
2. BIOS setting has changed, entering the bios can sort this.
3. Real time clock battery voltage has dropped too low therefore contents of BIOS not held when turned off, this can be sorted by replacing the CMOS battery
http://www.computerhope.com/issues/ch000239.htm
Please keep me updated.
Regards
Dec 21, 2012 | Acer AM3400U2502 PC Desktop
On my computer i have to push f1 to start it
first try to notice the message before the (press F1 to continue) message, it could be a bad component (memory, hard drive, etc...) or the time & date is not set correctly in the BIOS, this would help a LOT thank's...
Jun 25, 2011 | Dell Computers & Internet
Every time I on my PC it appears in screen unknown bios error. error code 8302 press f1 to resume
You need to flash your bios before it becomes totally corrupted. You are losing small bits of information that your motherboard needs to continue functioning.
I have what i believe is the proper page for your bios, but your exact model doesn't show up when I search the site, so the best solution for your problem is the MSI live bios update located at the bottom of this webpage:
http://www.msi.com/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=1150
Simply install that and allow it to automatically fix your bios for you.
Aug 05, 2010 | MSI P4M900M-L Motherboard
Abit Av8. 2nd post fault on this m/b. post fails to complete and stops at code display 7F. screen displays . mem test OK HDD iodentified CMOS checksum error-defaults laoded F1 to continue Del to...
For that When you power up the computer press F1 or F2 or del or ALt +F2 key to enter in bios .
If still you are not able to enter in bios then open cpu cabinet if you have desktop and if you have laptop open back cover of laptop then pull cmos cell from motherboard for 10 minutes.Reattach the RAM memory .
Then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Apr 03, 2010 | Computers & Internet
Error code =8302
check your bios settings that the vid output is set to boot from the right device that you want it to be from. try reseting defaults
Feb 24, 2009 | MSI P4M900M-L Motherboard
Code error
first you reset the BIOS remove CMOS battery or shorting it with jumber. this may give solution
Jul 05, 2008 | ASUS P5PE-VM Motherboard
MSI P4M900M-L Motherboard Logo
1,331 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
