Question about Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer clothes get stuck under the washplate ..the gap looks too wide between tub and washplate...does the washplate need replaced,, or is the plastic seal around the washplate replaceable???
    Problem Solver:
  • 5 Answers
Replacing the bottom rotating plate is the fix for this. I did it myself last year and we have not had a problem since. We NEVER put rugs or mophead (or similar) in this washer to protect the weak separate-drive water pump. BUT, the problem with the clothes getting grabbed is the plastic white flexible rim of the plate...its bends up. If you can see a space between the plastic edge and the inner surface of the wash tub, then you need to replace the disk. It will work...until you can save enough money to purchase a replacement for the planned-obsolescence product.
Posted on Aug 12, 2010
  • 119 Answers
THE PLATE CAN BE REPLACED, GET ONE FROM YOUR LOCAL APPLIANCE PARTS STORE OR SEARCH ON LINE, SEARSPARTSDIRECT.COM, REPAIRCLINIC.COM, ETC. GET MESH BAGS FOR YOUR SMALL ITEMS. THAT WILL PREVENT FUTURE PROBLEMS, IE: PUMP GET STUCK AND BURN(COMMON PROBLEM)
TIMOTHY DO 714-334-1998
Posted on Aug 04, 2010
Sheets stuck under the agitator
The agitator should come off without to much grief. These are two piece agitators and the sheets are probably stuck between the dome and the wash plate.
Jan 22, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I get dirty streaks on cloths during the wash cycle.
It's a common problem with modern machines.
Due the modern way of washing on low temperatures some dirt will stick into the machine's.
You can try to wash some old stuff several times on a high temperature and instead of using washingpowder you have to use a handfull of soda.
It will clean the inside. Worked fine overhere.
Good luck,
Gerard
Jan 20, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
How to remove outer washplate from. kenmore
1. UNPLUG THE WASHER.
2. Open the washer top. Look along the front seam of the washer where the top meets the front. There are a couple of retaining clips (about 2" in from each side) that you will need to push in on with a putty knife while gently lifting up on the top to get the top to release. Carefully open the top and lay it back in a resting position. Make sure you support the lid so it doesn't fall open when you tilt the top back. NOTE: I would recommend using duct tape to keep the lid closed and gently place the top against a wall for support. Use a towel between the cabinet and wall to prevent any damage to painted surfaces. This also reduces the strain on the top panel supports.
3. Remove the tub ring. This is the plastic donut shaped ring that sits on top of the wash tub. There will be a tab on either side of the outer tub near the back that you can use a screwdriver to release the tub ring. The ring is filled with fluid and is used to balance the tub. So, if you hear liquid sloshing around, this is normal.
4. Remove the wash plate center dome from the wash plate. This is the center cone on top of the wash plate. Use a flat blade screwdriver and insert it into any of the slots available along the sides. Gently pry until it pops off. I say "gently", but you may have to use a little muscle to get it to come off. Sometimes they stick. Once the center cone is removed there will be a series of nuts under it.
5. Remove the nuts and the main wash plate should lift out, exposing the inner wash plate. This is another cone shaped device located under the main wash plate. Remove the inner wash plate, using care not to damage the gasket under it. It is common for clothing to become tangled in the leveler or u-joint under this inner wash plate.
6. When all required maintenance is complete, reinstall the inner wash plate, ensuring the gasket is seated under it. The inner wash plate is keyed and should only install one way.
7. Insert the main wash plate and insert mounting bolts. Use a criss-cross pattern when tightening to ensure all bolts are tightened evenly and the gasket seats properly.
8. Reinstall the center dome on the wash plate by snapping it back in place.
9. Reinstall, the balance ring on the wash tub.
The following is a parts list of the most common items that may require replacement when you experience erratic motion of the wash plate, and/or clothing becoming damaged or entangled:
Wash Plate Dome
Main (Outer) Wash Plate
Inner Wash Plate
Leveler Assembly
Inner Wash Plate Seal
U-joint
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2009 | Kenmore Washing Machines
Kenmore calypso has clothing stuck
I believe the problem is the Outer Wash Plate. Replacing it may fix your problem. I am about to do that to mine, so I don't know yet. The outer plastic 'seal' or rim of the washplate should be touching the inner surface of the stainless steel wash basket. So it catches clothes. I just installed a u-joint kit today, so needless to say, I got out the washplate and retrieved my clothes on the way to replacing the u-joint. It involves leaning up the upper lid and cover, removing the tub ring and balance ring and the dome. Then there are 6 bolts to remove the outer wash plate to get to your clothes underneath. Might as well replace the washplate while you are at it. to download the manual, copy this https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
into your internet explorer address line and save the manual. page 36 starts the instructions I used to remove the washplate and other items. I spent a LOT of time cleaning the gunk out.
May 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso once wash cycle is selected. The machine will fill then stop and there will be a humming noise
does it wash or spin anywhere on the dial.  If not, the coupling that connects the motor to the transmission is defective and need replacing.  A $20 part
Mar 25, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
CLOTHES GETTING STUCK UNDER WASH PLATE
I don't know of a "permanent" fix, but I do know that replacing the nunater (wash plate) may help. Especially, if the rubber around the edge is starting to crack or curl, creating areas where clothing can catch. This is a known problem with the Calypso. As I was instructed, the problem was attributed to an excessive nunator time at the end of the wash cycle. Such a vacuum was being generated that it was pulling clothing into the edges of the nunator, leaving rubber marks and/or clothes becoming lodged. The manufacturer modified the control board to reduce the nunator time to prevent this. I can provide you with a part number, but do not know if the manufacturer will cover the cost of replacment. If interested, let me know. Do you need advice on how to remove the nunator (wash plate)? Or, did my previous post explain this enough for you? Please post back if you require additional assistance.
Aug 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
CALYPSO WASHER
on calypso the wash plate has a rubber seal around outside edge it can become distorted and have gaps ..replace entire plate gasket not separate and if you haven't already ckd the leveler/universal that moves the plateif has original it may be wearing and while you have it apart might be good idea to change it to head off future problems
Jul 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore calypso washer
LD is an error code for 'Long Drain'. The water pump may be clogged, there may be a clog under the washplate where the water exits the tub or a clog at the check valve. The best place to start is the water pump.
Jul 12, 2008 | Kenmore 20172 Top Load Washer
Kenmore Elite Washer with Calypso Model # 110-22062100
The 'FL' is a flood code indicating there is too much water in the machine.
What has probably happened, is a small article of clothing has gone under the washplate and is now stuck somewhere it the drain system, most likely in the pump.
The control board change that was made may help a little, but not necessarily a cure all. If you are considering a new control, replace the washplate as well.
I don't know how long you have had this machine but I do know you paid alot for it. I purchased one of these machines about 6 years ago and about 2 years later began having problems you described. I found it best to cut my loses and get a new plain agitator type top loader. Best thing I ever did.
The Calypso was a great concept and does a great job when it works right. But this machine has been plagued with numerous issues from the beginning, causing may owners many sleepless nights not to mention laundry pile-ups..
Regards;
reg501
The FixYa Team
Jun 23, 2008 | Kenmore 22422 Top Load Washer
Whirlpool calypso
Have you checked the agitator? There may be sharp edges on the agitator blades. OR the towels may be getting stuck under the agitator and tub bottom. The agitator is supposed to suck the clothing down in the center and forcibly throw the clothing outwards against the tub. The cycle then repeats.
Sep 09, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
337 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
