Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
My Kodak ESP-3 won't print. It has full ink, but when the loading dock shows up for the printer, it only says spooling, but nothing happens. What should I do?
I've got same problem with the same, new printer. Can't find any information or help.
Posted on Sep 01, 2010
Kodak esp 5210 wont print black
I figured it out. If you are low on (25%) on either colors or black, then it won't print. Even if you load a new black cartridge and it reads as 100% black, it won't print because it will only print when BOTH cartridges have been replaced and reads 100%.
Same thing happens reversed with color being replaced.
So basically, ALL printers short you 25% ink and FORCE you to buy their ink more often. Kodak is no exception.
I have 100% black and 25% color and a BW only needed text paper won't print. I been through this before. *facepalm*
Apr 16, 2012 | Kodak ESP 7250 All-in-One InkJet Printer
I just bought a Kodak ESP 5210 and when it tried to calibrate after putting the ink cartridges in nothing comes out on the calibration page. Now when I try to print something, nothing is on the page. I...
Sounds like your print head needs replacing, exact same happened with me, appears to be a common problem with these Kodak printers, if new it should be covered under warrenty although good luck trying to get through to Kodak, I sent mine back in the end for a refund as long term print heads are around £65 each and they don't appear to last long
Jan 16, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak esp 3 printer will print but has lines through letterring o
Suggest you contact Kodak directly as it may need a replacement part
Jul 16, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Kodak ESP 3 Won't Scan
Did you install the full software driver for the all-in-one? The drivers are here: http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=9103/12666/12667&product=EKN034524
Next try a new USB cable and plugging the unit into a different port. If you use a print server or USB hub, try connecting directly to the computer. Scanners need bi-directional communication with the computer and thus are likely to have issues even if the printer doesn't.
Can the scanning software on the computer initiate the scan? (That is in the full software package. Alternatively Vista came with Paint and File> Import from Camera or Scanner > New Scan.)
I hope this helps.
Apr 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Not Printing anything today. Ink cartridges show
Uninstall than reinstall the software. This has worked for me in the past.
Feb 26, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Sub spool has stopped working and it only prints yellow.
Follow www.kodak.com/go/itg and try the step by step solution.If issue persists,Call Kodak @1800 421 6699 and get a new printhead free of cost.....Printhead has gone bad and it is the part in which we install the ink cartridges.It takes the ink out of the cartridges and spit the ink on the papers,...Cheers and Enjoy.
Dec 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
When I print, it says spooling
Go to Control Panel, Printers and Faxes, Cancel any pending document on your Kodak Printer, then delete all kodak icons.
Turn off the printer, Unplug and Replug the USB cable, then turn on the printer. If nothing happens..
Second options: Click Start then select Run Type the word "net stop spooler" then "net start spooler" Then unplug and replug the printer while its on.
Josh
Aug 18, 2009 | Kodak ESP 5 Printer
Shows black ink full but not printing
Call kodak @ 1800 421 6699 and they will replace the entire printer for you free of cost. Have a happy experience.
May 01, 2009 | Kodak ESP 5 Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
830 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
