Question about Garden
I was cutting the grass ,i went to turn the lights on,they can on for a second and then the lights and the blades stopped working.then i turned the key to off and nothing will work,no sound,click or anything
  • 103 Answers
Check your fuses. one of them has blown out which will cause all of your symptoms.
Posted on Aug 04, 2010
My craftsman DLT 2000 won't cut grass , the pulleys are clean n moving the blades are rotating but when I let the deck down to cut the grass it stops and sounds like the belts trying to turn, making the...
be sure the blades are not bent and you dont feel any wiggle when pushing them up and down. be sure nothing is wrapped around the spindles. be sure the belt isnt damaged and tight when the deck is engaged to cut with the engine off.
Sep 18, 2017 | Garden
Sears Craftsman rider mower bought in 2001. Still runs really great. However, lately it will not cut the grass when I lower the deck to positions 1-3; the blades seem to stop; no cutting action at all. As...
Do the blades need sharpening? Check the belts for tightness and the spring that holds the tension. what stops? The blades stop, but the belt is still turning? Check to also make sure the blades turn freely with the belt disengaged. you may have a spindle problem too.
Jul 23, 2017 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Need a troubleshooting manual for a craftsman mod. 917.287070
Went out to cut grass and the blades will not engage and when I put it in gear it does not move. Belts are intact. I cleaned the deck of dirt and grass. Still nothing. Just replaced the cable to engage the blades last year. Cable seems to be working.
Jun 25, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blades won't stay engaged in any length of grass
Sounds like a broken shear pin in the drive pulley. Check the belts and see if they are slipping. Broken shear pin will not let the blades spin under pressure. .
Aug 09, 2017 | Toro Garden
When I engage the blades on my ez4824 the blades intermittently stop cutting particularly in higher grass. Do you think this is a loose belt problem? Thanks.
That is the most likely cause of the problem - taller and thicker grass the blades encounter more resitance and the drive belt slips and it doesn't cut. This would likely cause a juddering of the machine when it occurs.
Hope this helps.
Jul 11, 2011 | Husqvarna EZ4824 24 hp 48" Zero Turn Lawn...
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
My Toro mower is 7 yrs old. 3 speeds, blade
I've noticed that when the blade get dull it work harder a cutting tall grass. I just put a new blade on mine and now it runs and sounds like a brand new mower. also if the inside of the deck is coated with old grass that makes a differance too
Jun 23, 2009 | Toro Lawn Mower With Toro Power Tools
Tractor?troy bilt/mtd 2002
the electric clutch that operates the blades needs replaced
Sep 22, 2008 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
