Question about Datalogic PowerScan M8300 - PowerScan M8300 AR PM8300-AR433RB PC Notebook
There is a clip on the DATALOGIC Powerscan D8330 which is used to secure the scanner to a retaining wire it is ontop of the scanner I am trying to source some of these clips, they are secured by two screwws.
3 Suggested Answers
  • 8 Answers
SOURCE: Datalogic Dragon D101
You could use a ps2 splitter cable to connect both the barcode scanner and the keyboard to the pc. You would also have to use the correct scanner codes to ensure that the scanner is configured properly. Alternatively, you could try connecting the scanner with only the ps2 to usb and miss out the extension cable to determine if that is the problem. If the scanner is a ps2 wedge scanner, it will need reprogrammed with the correct scanner codes for usb.
Posted on Sep 23, 2007
SOURCE: Problems with very small Barcodes
Default settings set a global limit of 4.
You can set the global minimum code length by following the instructions in the user manual on page 24:
1) Start
2) Set Global Min Length
3) Scan the number on page 303: I.e. '0' followed by '3' to set length to 3
4) Set
5) End
Posted on Apr 23, 2011
How to set up QuickScanplus6000
Assuming that you are using USB type connection,try connect to other USB ports.Most Datalogic scanners if fail to connect to PC,mainly it's the cable problem or PC port problem.
Jul 18, 2014 | Datalogic QuickScan Computers & Internet
Flexible cable m8300
It depends on what type of cable it is... if its a flat ribbon type cable, you MAY be able to source one from a dead printer or laptop... you may need to modify it to suit however...ie, remove unneeded contacts, etc. have a look at your local tipshop or the like.
Printers often have many of these cables, often 10 or more, ranging from 3 pin up to 30 or more pins. They are usually the same as ones used in notebooks. I've done this to repair a damaged laptop cable using an old hp printer.
Hope this info helps.
May 21, 2012 | Datalogic PowerScan M8300 AR, M8300/D Bar...
Asked for a Powerscan 8000 manual?
Here you go. It's for the 8300.
http://lib.store.yahoo.net/lib/barcodescannersdiscount/pwsnn300ug.pdf
Here is teh quick reference guide for the charger as well: https://easeofaccess.scanning.datalogic.com/public/marketlit/Send.aspx?file=820002080
and the quick reference guide for the 8300 itself: https://easeofaccess.scanning.datalogic.com/public/marketlit/Send.aspx?file=820001951
and here are the specs for it: http://www.sektor.co.nz/site/sektor/files/ProductPDFs/lc/powerscanpm8300.pdf
Sorry for the misguidance and lack of seriousness in the guides that answered your question previously.
Good luck, let me know if there are any problems
Dec 28, 2009 | PSC PowerScan RF 8000 (psrf8000) Handheld
Datalogic QS6500BT barcode scanner and 2D codes
Usually some symbologies are disabled at default.
i think you need the manual and scan the barcode to enable it for scanning.
the links is:
https://easeofaccess.scanning.datalogic.com/public/marketlit/Send.aspx?file=R44-2816A
it's chapter 6-191 or page 279 in pdf.
you have to begin with scanning "Start" en end with scanning "END"
becarefull with printing this page and not the whole manual. there are 336 pages.
good luck
Jan 16, 2009 | Datalogic QS6500BT Barcode Scanner -...
1) Start
4) Set
5) End
Jan 09, 2009 | Datalogic PSC QuickScan QS6500 Handheld...
Configuring (changing) barcode reader suffix
Reset tbe scanner and again program the scanner for your required configuration.
Aug 15, 2008 | Datalogic Computers & Internet
Can i clone the configuration from another scanner?? please i need to know how to make this....
You can contact them directly at either link: http://www.datalogic.com/ http://www.scanning.datalogic.com/html/contact.htm They may have software for it that does this.
Mar 27, 2007 | PSC PowerScan RF Base Station
Can't scan label..... i've got some labels in 128 code... when i scan more than 2 times the scanner gets blocked.... so the keyboard too
You can contact them directly at either link: http://www.datalogic.com/ http://www.scanning.datalogic.com/html/contact.htm They'll have your answer.
Apr 09, 2007 | PSC PowerScan RF Base Station
Datalogic PowerScan M8300 - PowerScan M8300 AR PM8300-AR433RB PC Notebook Logo
70 people viewed this question
Top Datalogic Computers & Internet Experts
Paul Bade
jackcity
jackcity
Level 1 Expert
 Ian Kayhan
Ian Kayhan
Are you a Datalogic Computer and Internet Expert? Answer questions, earn points and help others
