I have an SMG 900 KARAOKE MACHINE, 3 CD TRAY. regardless of which tray i load the disk in, it skips, jumps etc. the disks play normally in my other players. I i checked the machine, but don't see any loose alignment of the tray mechanism.. Where might i look
  • 275 Answers
SOURCE: Disc Error, and DVD tray ejecting on it's own....
If it is new, best advice is to take it the Comapny Service Centre, as you are having Warranty.
Posted on Apr 04, 2007
Orbixx
  • 133 Answers
SOURCE: music format
It's .wav format. However if you burn your MP3s as an audio disc (not an MP3 disc) with a program like Nero or Roxio Easy DVD Suite, then it will automatically convert them to .wav and burn them to CD and it will work with your CD player straight off.
Posted on Sep 07, 2007
bluenadas
  • 203 Answers
SOURCE: cd tray mechanics
It can be repaired but in all of my years in consumer repair, I dread the CD/DVD tray alignments the worst.
There are many things involved in getting them to operate without fail. Using the mfgs documentation you can get them up and running but most of the time they failed because something is amiss to begin with. So you spend an hour getting everything setup and it will work once or twice but them fail. Only to find out that a location sensor is bad or a gear is missing a tooth....
Posted on Nov 21, 2007
dg9dotorg
  • 151 Answers
SOURCE: Player will only play track #1
Maybe your "play once" option or "repeat" option is activated, try and check it and get it back to normal play...
Posted on Dec 09, 2007
  • 28 Answers
SOURCE: cd dont revolve in player
This sounds like a problem with the CD motor. As CD players get used a lot, the motor gets worn down and eventually stops working. If you get a lot of dust in the player, this can also slow down or stop the motor. If you feel like frankensteining the CD player, you can try and see if there is any dust. If you like this perticular cd player, I would suggest going to a electronics repair shop and have them take a look, but with the prices of portable CD players these days, you might be better of just getting a new one. You may even find one with better features at a lower price.
Posted on Mar 30, 2009
Is there an easy fix to the problem given in the details section below?
No there will not be a easy fix for this. You can keep putting up with this the way you have been or buy a new receiver and try to sell this one on craigslist, eBay, etc.
Jan 20, 2016 | Sony CDP-CE375 5-Disc CD Changer
I received my karaoke yesterday Feb.,2015. when I put the cd in to play the music there is a scratching noise. it seem to be in the turning mechanism of the player. Even when the music is playing y
some body has prob been picked up by a disk
then when inserted the blob of stuff is then stuck too the disk drive motor
i think its a fault caused by some bit of rubbish
you can also check the cd tray for any signs of rubbish also stuck too it
Feb 07, 2015 | Washing Machines
DISC SKIPPING ON MY JVC OR RSQ TRIPLE TRAY KARAOKE MACHINE THANKS SHANE
Hi Shane, sounds like a dirty or worn laser. If memory serves there are two screws on each side and two on the upper rear. Once the lid is off you should be able to see cd laser. If so you need a cotton bud ( ear plug ) and a dash of Isoproponol ( from any chemist )...make sure unit is switched off...soak end of bud in isoproponol and wipe over laser ensuring it is clean..leave for 30 minutes and switch on and put disk in to check..hope this helps..
Jun 26, 2011 | JVC XL-MV303 CD Player
When i put a cd in to play, we cant get the words to show on digital screen??
You MUST use a special Karaoke CD disk to show lyrics on the screen. Plain music CD's will play music but NOT display the lyrics. Karaoke disks can be expensive... so shop online for Karaoke CD's. Some music stores, including Costco and other warehouses sell some Karaoke disks, but they are usually in a very small section of the displays.
Dec 27, 2010 | GPX Karaoke Party Machine
Karaoke Machine - words are overlapping/jumping
The Sining Machine #SMG-301 has a problem with not playing because of the word 'DOOR' coming up on the readout. I've checked the door/Tray to make sure that it was closed and when you open up the tray/door to put or take out another disk the word that comes up on the readout is not DOOR it's OPEAN! Any suggestions?
Aug 24, 2009 | B&W 5.5" TV/CD+G Monitor Karaoke Machine...
My right side does not play
Hi I have the CD-Mix 1 unit and my left hand disk tray is doing exactly as you describe, i have dismantled the whole thing and tested out and looked at as much as i can and everything seems okay. It's almost like something isn't quite lining up properly when the disk tray is closed because I have found that pulling down the tray door and using my thump to hit the right hand side of the tray itself eventually gets the disk spinning. The main issue is that when you hit the unit so hard the cd playing in the other tray skips as you would probably expect...But at least this information might at least let you spin up one and then fade/mix with the other afterwards.
If you do find out the exact issue, please email me at littleguydan@googlemail.com
Thanks!
Jul 24, 2009 | Nu Mark Numark Cd-Mix-2 Dual CD...
Jvc xlmv33 three tray karaoke cdg player
TRY A LASER LENS CLEANER,,AND TAKE COVER OFF TRY BLOWING IT OUT ,,
May 12, 2009 | JVC KARAOKE, 3-CD CHANGER, 3 MIC INPUT,...
We have the RCA RS2767i Home Stereo with 5-disc changer and ipod dock. The CD Tray won't eject or shuffle...everything else works fine. It seems the disc tray isn't responding to anything. We read in the...
Let me respond with a possible solution although I'd bet that both of you already tried these.
The reason I checked into this is because I'm looking for a new mini system. I happen to be at Target and they only had 2 models - this one and a SONY. I certainly didn't want to buy the RCA given these problems, so I asked the salesperson, who seemed to have some knowlege.
As far as opening the tray on top, there is a button to push right under the tray. The button has an icon of a triangle on it. This seems to be somewhat of a standard icon for opening the tray or ejecting a CD (my car's CD has the same icon for ejecting a CD).
As far as only being able to get 3 CD's out, there is another button under the tray marked "disc skip". This rotates the tray. When you open the tray, you can only get to 3 of the CD's. When you push disk skip, it rotates the tray one position, so you can get the 4th one out. Another push and now you can get the 5th one.
Sometimes my CD changer doesn't shuffle the disks. If I only have 1 CD or DVD in it and push the tray open button, the disk stays in the unit and the tray revolves to an intermediate position. I push the button to put the tray back and try disc skip; that usually works.
If your problems are not solved per above, then I definitely do NOT want to get this.
Fred
Dec 05, 2008 | Audio Players & Recorders
Plays when it feels like
Try using a compressed air can to blow air into the CD tray and also into the vents in the back. It sounds like either dust or debris is caught in the CD tray or is blocking the vent in the back causing the machine to over-heat.
Sep 05, 2008 | Sony PlayStation 2 (PS2) Console
53 people viewed this question
 Grubhead
Grubhead
