Question about Mansfield Plumbing Products Home
2 new toilets installed. customer complaint of occasional clogs. no apparent problem although i feel the flush valve closes very fast. any changes or adjustments for this
  • 43,501 Answers
Often I change the flapper to get the toilet flapper to stay up longer, giving a longer flush....
Check for a generic flapper that wiill work with the toilets you installed...
heatman101
Posted on Aug 05, 2010
Travel trailer septic won't drain not sure why the valve feels like it is opening
Its clogged with a big (s h i t ) from ur wife. Go to can tire and buy the part that allowes u to hook a hose to it try and flush it with water if that don't work fit an air connnector to it. And slightly open ur toilet valve then use air to push the clog out into the main tank.be sure not to do this with the toilet valve closed or u will hate ur self. Good luck and tell the wife to ease off the chilly and bread. Lol
Jan 13, 2018 | RVs
Tip
What to do if your toilet stops working
When a toilet stops working it can be a major inconvenience. If your toilet isn't working right, try the simple fixes below.
If the toilet doesn't flush:
When you jiggle the handle, nothing happens. Remove the lid from the toilet tank and peek inside. Most likely, either the chain came off at the lift rod or flapper end, or the rod broke in half. If the chain came off the rod, you can simply reattach it. (Finding the right amount of slack will take some trial and error.) Likewise, if it came off of the flapper, it can easily be reattached.
If the lift rod (the arm attached to the handle) is broken, you can purchase a new rod and handle assembly for a few bucks at just about any hardware store. A plastic nut holds the handle into the side of the tank and the whole assembly can be popped out and replaced. Once you've installed the new assembly, reattach the chain.
If the toilet keeps running:
Remove the tank lid and watch the toilet as it flushes. You'll probably see that the chain is too tight, causing the flapper to not close all the way, which results in water continuing to drain out and having to be replenished. Loosen the chain a little and see if it fixes the problem.
Another cause of a constantly-running toilet is an improper float height. The float is the balloon-looking thing that sits on the end of a shaft and falls and then rises when the toilet is flushed. When the float reaches a certain height, the fill valve is closed and the water stops flowing. If your toilet is running longer than it should, push down a tiny bit on the float and see if it stops running. If it does, the float just needs to be adjusted downward a little (by turning the screw at the other end of its shaft). You may need to try a few different heights to determine the optimal position of the float; adjust it slightly and flush the toilet, then adjust it again if necessary.
If there's not enough water pressure:
The chain may be too loose if there isn't enough pressure. With the tank lid off, watch the toilet flush. If there is too much slack in the chain, the flapper may close prematurely, reducing water pressure. Tighten the chain and see if that makes a difference.
Loss of water pressure can also be caused by the holes in the toilet bowl getting clogged up. There are little holes all around the side of the bowl, where water is forced into the bowl to refill it after a flush. If any of these holes get clogged, clean them out with a round file, a nail punch, or a similarly-shaped instrument. (Don't push too hard or hammer on the bowl.)
If the toilet overflows:
If your toilet overflows, the first thing to do is to turn off the water to the toilet. There is a valve on one side of the toilet, where the pipe runs from the wall to the toilet. Turn this valve clockwise to close it.
Once the water is off, use a plunger to try to clear the clog. If it works, you'll see the water drain out of the bowl. If the plunger can't clear it, try a simple drain-cleaning tool like a Zip-It or Turbo Snake. If you don't have anything that can remove the clog, or if the clog remains even after trying to clear it, you'll need to call a plumber (or buy yourself a closet auger or plumber's snake).
If you are able to remove the clog, turn the water back on and flush the toilet to make sure the clog is completely gone.
on Feb 06, 2011 | Plumbing
After flushing the toilet the bowl only a small amount of water comes back into bowl. This is a new problem. Could there be a clog?
Is the flapper valve closing sooner then it should? Is the water line (the 1/4" vinyl tube at top of fill valve) going into the tank or into the overflow tube? Did anyone drop anything into the flush valve?
Jul 02, 2014 | Toto Drake ADA Compliant Toilet with...
Not flushing all waste on first flush
Your inflow valve is probably clogged. This is what allows the water in and how fast. You can change this also for a minimal cost.
May 02, 2014 | Toto Aquia II Dual Flush Toilet
TOILET DOESNT HAVE A GOOD FLUSH PRESSURE AND DOESNT FILL FAST ENOUGH
Valve needs adjustment (Small screws on top) or replaced. tank ball rod bent or turned down.Depends on model.
Mar 17, 2012 | KOHLER Revival Two-Piece Elongated Toilet,...
Occasionally after flushing ,water continues to trickle slightly in toilet bowl. Have changed flapper twice. Wondering if the seat that the flapper sits on is worn or something. It looks ok. Have a one...
Make sure the flush valve is closing properly and that the water level is not set too high causing water to enter the overflow tube. If the flapper seat is damaged and cannot just be be cleaned, you can add a new seat right over the old one. Fluidmaster sells them for just a few dollars. Most hardware stores have them - Home Depot and Lowes stock them.
Feb 27, 2011 | Eljer Toilet Onepiece Canterbury ...
My mansfield toilet 160 has a weak flushing problem
My toilet had same problem:
I thought it was a clog in the drain pipe.
But the problem was clogged holes where water flushes into toilet bowl.
Here's how I fixed problem.
Purchase:
Gallon of CLR calcium-lime-rust remover from Home depot.
Pumice stone from hardware store.
Home supplies:
Cut off bottom of empty clorox bottle to make container for CLR
Old 3" paint brush you don't use for anything else to apply CLR
Small cup to pour CLR into toilet flapper opening
Steps:
Look inside toilet bowl under rim and see holes where water comes out
Use brush and apply CLR to holes where water comes out.
Use pumice stone to scrape ... pumice stone will not hurt toilet surface.
Flush toilet to clear holes so far.
Turn off water to toilet.
Open flapper to drain tank.
Keep flapper open.
Use cup and pour dose of CLR directly into flapper opening.
(You can also pour CLR down overflow tube... but flapper opening puts whole dose directly onto problem)
Pour another cup of CLR into opening.
Notice how CLR starts coming out the holes into bowl.
Pour CLR down flapper hole until it runs easy and fast out of holes.
Close flapper, turn on water, toilet fixed.
Nov 22, 2010 | Home
Just hooked up new pressure asist tank & bowl,turned on water to it,and it want flush.what i mean about want flush, is it will flush but water does'nt go down,as if it's not staying open long enough.
Sounds like you have a clogged drainline or vent-stack. Fill a large bucket with about three gallons of water and dump it quickly into the bowl. If the drainline/vent is clear, the toilet will "flush" like a gravity toilet and the water will drain from the bowl almost as fast as you can pour it in.
If the water level in the bowl slowly rises (as if it's about to overflow) and then slowly drains, you have a clog somewhere.
All toilets, regardless of their flushing mechanism, require a clear, unoibstructed drain/waste/vent system to extract waste.
If the toilet "flushes" with the bucket of water, you may want to call Flushmate tech support (the number is on top of the tank) or check out the installation and troubleshooting videos at howto.flushmate.com.
Hope this helps.
Aug 18, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
Toilet flapper closes too fast
MAKE SURE YOUR FLOAT INSIDE THE TOILET IS'NT SITTING TO LOW TRY HOLDING IT UP WHEN FLUSHING THE TOILET FOR A FEW SECS TO SEE IF THIS COULD BE THE PROBLEM ALSO CHECK THE WATER LEVEL INSIDE THE BOWL MAKE SURE IT IS'NT TO LOW
Mar 10, 2009 | Plumbing
Home Logo
106 people viewed this question
Top Mansfield Plumbing Products Home Experts
john h
bobalix
richochet
Are you a Mansfield Plumbing Products Home Expert? Answer questions, earn points and help others
