Question about Hanns.G Corporation JW-199DPB 19" LCD Monitor
Moniter is not on . i checked the power is comming to the moniter. no picture no lights, screen is not on i mean moniter totally dead.
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 05, 2010
My dryer stopped working this morning. The light to the on switch is "on," meaning it's red. But everything else looks dead: The start button doesn't have a light. And, the display panel is...
If it there is power in the system (red light on power swithch),yet the dryer does not run - with a totally blank LED screen (no error message), the controller board may be out. You can snap in a new one (remove the top of the dryer, take picture to make sure you know where the wires go) remove from clips n replace. Only thing, it'll cost you $220 to buy a new one. Try repairclinic.com - if it doesn't work you can return for full refund.
Mar 11, 2011 | Asko T731 Electric Dryer
Daewoo Moniter blank screen
First make sure that all the cords are connected properly from the back of the CPU to your Monitor.I suggest you to unplug all the cords of the CPU and then plug them back in after 10min. and make sure they are all connected tightly.Next check if the power cord connected to the Monitor is attached tightly.
If you still face the problem then you will have to replace it with a new power cord whih connects the CPU to your Monitor.It is black in colour.
Sep 30, 2008 | Gateway FPD2275W LCD Monitor
Moniter power light blinks purple.
Inspect the power supply and also try it on another PC too.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 30, 2010 | Smart Modular SV3170A
My moniter display is not coming it alway show
You need to try this monitor on other PC to narrow down the problem, it can be the monitor, cable, PC. I f you try all the suggestions and it still does not work, then you need to open it up and see the pictures here: http://s807.photobucket.com/home/budm/allalbums
and check for shorted transistors or bad fuse.
Mar 11, 2010 | Dell E173FP 17" LCD Monitor
Viewsonic sreen isn't displaying the picture
More likely to have bad caps, see example here: http://s807.photobucket.com/home/budm/allalbums
Common problems to ALL brands, they all failed after a couple of years.
Jan 17, 2010 | ViewSonic VX2235WM Monitor
No picture on screen but power light blinks
May be the problem with your Pc. If you can hear a beep sound when booting the Pc is Ok. Otherwise check memmory for loose connection.
May 03, 2009 | Computers & Internet
A95 Canon LCD moniter
Canon will resolve this problem free of cost as per announced Canon CCD Advisory.
Your Canon A95 has problem with CCD Imager and this part will be replaced by Canon Support free of cost. Click above said web link to get details.
Have a nice day.
Oct 26, 2008 | Canon PowerShot A95 Digital Camera
Monitor wont turn on, green power light on
Hi you can inspect that what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 08, 2008 | IBM ThinkVision L170 17" LCD Monitor
Monitor is dead (black)
ask to moniter service technition
thanks
prasanna
Hp flat panel monitor looses picture
Here
Here
and Here
I've tried all the aforementioned fixes, and my conclusion is... when your monitor's dead it's dead. Go to NewEgg and and get a new one.
Nov 12, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
Hanns.G Corporation JW-199DPB 19" LCD Monitor Logo
143 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
nm8r
Level 1 Expert
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
