Question about Nokia 6070 Cellular Phone
My phone 6070 has problems on key pad.sometime 1 is not working and some times 2..how can i solve this problems.
    Scholar:
  • 129 Answers
Open your set, take out keyboard, check all pin of keyboard connector, also behind the keyboard, clean if necessary.
Posted on Aug 04, 2010
Problem in my keypad in nokia 6070
My Dear your phone keypad ic default so please change keypad ic
and keypad problem will solved
Sep 24, 2012 | Nokia 6070 Cellular Phone
Tip
How to repair keypad problem in China Mobile
First we need to know china phone keypad connected with PCB how way
(A) Direct on PCB
(B) Flex System (flex cable direct soldering pcb to keypad panel)
© Flex and socket system include (flex one side soldering with key panel other side connect to pcb with socket)
(D) only Socket System (here have 2 socket, 1 with key panel others with pcb)
Keypad problem have various type
1. All key not work.
2. some key work and some other not work.
3. sometimes work and sometimes not work.
1. All key not work
china phone all key not work for this type of problem
(A) though its touch screen phone, first try to disconnect touch panel line from phone pcb or display flex (4 line)
(B) though not solve and keypad direct on pcb first you try to good clean full pcb with cleaner.
© though not solve now you try to format/flash your phone because some time key problem come from software problem.
(D) though still not solve now you check must be CPU. 95% china phone keypad directly going in cpu. and other 5% first going to resistor or capacitor near the cpu or keypad than going to cpu. so now first check them than you can try to re-hot, re-soldering or changing cpu.
(E) though its flex or socket system, first check GND connection continuslay pcb to key panel. next check full flex or socket all line going continuously pcb to key panel or not. also sometimes flex or socket shorted with other line or gnd so check also them.
(F) Also you can check all key anyone is short 2 line.
(G) sometimes keypad line broken from cpu pin on pcb to key panel, so check them.
2. Some key work and some other not work
Some key work and some other is not work for this type of problem
(A) maximum time this problem we face for flex or socket system keypad. so check flex cable and socket all line any line is broken or not and though need change them. and check all key connection on key panel.
(B) though its direact on pcb, some of key line broken internaly. and maximum china phone have alternative test point near every key or with other key on keypad. so check them with multimeter and though need connect to not work key with near testpoint or other working key.
© common problem is keypad metal ball (which is short 2 line on key when we press) sometimes its damage for phone water damage or over key voltage, so clean them or change.
(D) also try to check line continuously from cpu to not working key.
this problem come from this defect
(A) flex or socket system keypad any line is bad soldering or do lose contact. check them and
re-soldering or keep there line join with extra ware.
(B) for cpu bad soldering or cpu pin is broken. so re-hot or re-ball cpu.
on Jan 06, 2010 | Cell Phones
Please give a reset code for nokia 6070 when mobile without sim card
You may try default phone and security code to remove restrictions. ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000 Default 6 Digit Security code: 123456 or 000000
if not solved tell me your IMIE number
type *#06# on your phone to get IMIE number
still not solve! format your phone by this process 1. Switch off your Nokia phone 2. Now Press following key sequence *#7370# or *#7780# 3. Enter Default lock code is 12345. 4. While holding these buttons, press the power button and switch on the phone. 5. Wait for message ‘Format
Aug 13, 2010 | Nokia 6070 Cellular Phone
Nokia 6070 key pad 3, 6, 9, # key not working i
Sorry to say this please replace keypad crstal IC,and jumper it will work 100% ....reheat the upper components and the the whole pcb,with care,the keypad ic is same as 6600, 6630, n70, 6680, 6280 LCD IC.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 28, 2010 | Nokia 6070 Cellular Phone
Reset my nokia 6070
Press "green key" + "*" + "3" + "power up" old all keys untill you see formating screen
May 26, 2010 | Nokia 6070 Cellular Phone
I have a problem with the key pad sometimes or most of the time i have to click twice.
you need to change the keypad button. Its not contacting the phone keypad board well.
Take care.
Mar 04, 2010 | Nokia 6070 Cellular Phone
Menu & key pad (no-)2 not working
remove its keypad, wash it's contact surface(which is made up of rubber) with soap and water gently then dry it thoruoghly , refix it n u r problem is gone :)
please do care to rate my solution . thx
May 26, 2009 | Nokia 6070 Cellular Phone
Nokia 6070
hey man u have very small problem with u r key pad ....
try a new key pad...
im sure ur prob will be solved..
best regards & best of luck..
Oct 12, 2007 | Nokia 6070 Cellular Phone
Razr v3
To solve this you need to clean up the flex cable in the screen.To do this u need 2 take your phone to an authorised phone repair person to get it done. If this doesn't work to need 2 replace the main flex cable. Sam !
Sep 19, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Nokia 6070 Cellular Phone Logo
82 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
