Question about GE Refrigerators
I had no cold air in my refrigerator so i pulled it out and blew all the dust off the motor then i pulled a panel off the back and it had wires behind it with a mother board the panel must of touched metal i got a spark and the motor stopped working but all the lights are still on is there areste switch or do i have to replace the board
  • 119 Answers
ON SOME MODEL THEY DO HAVE A LITTLE BLACK RESET SWITCH. MOST LIKELY YOU WILL BE REPLACING THE BOARD. NO COLD AIR, WAS YOUR COMPRESSOR RUNNING?
Posted on Aug 04, 2010
Freezer and refrigerator not getting cold but motor running
What is the make and model of your fridge?
Mar 31, 2014 | Refrigerators
Refrigerator won't cool
seal on door must be letting moisture into compartment, need new door seal
Aug 20, 2012 | Kenmore Top Freezer Refrigerator
The fridge/freezer is not getting cold enough- i'm assuming the 9 is as cold as it gets?
This problem is usually caused by dust build up on the condenser (a car radiator looking device but smaller). The condenser is usually located at the bottom of the refrigerator and accessed though a panel at the back of the refrigerator. There is a fan that pulls or blows air through it, this air should be warm (this is the heat pulled out of the refrigerator through the condenser). If the condenser fins are clogged with dust this heat exchange is hindered thus the refrigerator will not get as cold. All one has to do is unplug the refrigerator access the condenser (behind a slotted panel near the cooling fan) and blow the dust out of it (between the fins in particular), either with a small compressor or a can of pressurized air (like the type used on computers), plug the refridge back in and it should be cold again. Remove any dust hanging around, as this has a tendency to get into the condenser fins again. Hope this helps.
Sep 02, 2011 | Danby (DAR604BLS) Refrigerator
Refridge is warm, freezer is working fine. There is a damper controlled by a small motor behind the meat drawer or top drawer. Pulled out drawer, and hole that gets air from freezer was blocked with a...
This is known as the CZT or Climate Zone Technology fan and if you direct wire it and it does not run, replace.
This is the cold zone fan which supplies cold air to the meat and crisper drawers.
Feb 07, 2011 | Maytag MSD2758GEW
My Ge Monogram Refrigerator required maintenance cleaning on the condenser, typical with this type of built-in system. blew out the dust and cleaned it. the freezer is working fine but the refrigerator...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 18, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
AC repair on a 2005 Dodge Sprinter Van
system needs serviced possible low on ac fluid.
Aug 25, 2009 | 2005 Dodge Sprinter 3500 Standard Roof
Maytag plus refrigetor not cooling model msd2756geb
after removing all of the freezer racks and shelf pull the 4 1/4 inch screws out at the bottom back panel of the freezer. pull the 2 panels off and slide them out strait down to the floor of the freezer. if your freezer coils are full of snow and ice then the fan cant pull any cold air up into the refrigerator.your problem is probably th defrost adaptive timer. if the heater ohms out at around 20 to 30 ohms it is ok. next ohm the 2 white wires at the plug this is checking the thermostat it shoud ohm out at aproximately 240 k ohms if those 2 things check out the problem is the adaptive defrost timer it is in the ceiling behind the temperature controls on yhe right side.
Oct 02, 2008 | Refrigerators
Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
Mar 18, 2008 | Frigidaire FRS26ZSG
Kitchenaid refrigerator w/bottom freezer french doors
please check the air flow to the refrigerator side. it could be a stuck damper motor or damper thermostat. if the fan inside the freezer is running, you should be able to feel cold air coming out off the vents in the refrigerator side. you might have to press the button light switch on the panels to run the fan.
Feb 19, 2008 | KitchenAid Architect KBFA25ERSS Stainless...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
