Question about Marantz Audio Players & Recorders
Hi, I need have DECODE BOARD, FKV7.825.070 to replace on my Marantz Receiver model CS 4300/U1B. Do you know where cani buy it? Thanks, RM
robotek
  • 1512 Answers
SOURCE: stereo connection
Hi spanky
Sorry for the delays in getting back to you. Been busy here this week.
OK. to connect the 2275 to the 1152,there are 2 ways of going about this.
You can plug the pre- out of the 2275 to the power amp-in of the 1152. In doing this you are using the power amp section of the 1152 and the preamp functions of the 2275. Your other gear like CD player, tape deck and so on also plug into the 2275.
the other(better) way is to plug the pre-out of the 2275 into the tuner inputs of the 1152, leaving the volume at about 40% on the 2275 and use the 1152 as an integrated amp. This means you are using the 2275 as a tuner only. When you do this, you will need to use an RCA lead to jumper the pre-out/poweramp-in connections on the back of the 1152, and the 2275 ... L to L and R to R respectively.
I am still wondering why you want to use 2 integrated amps (each having a preamp and a poweramp section) The only real benefit the 2275 brings to your system will be tuner functions. You could just get a tuner and run the 1152 to be an ideal rig.
Let me know what your ideal setup you are wishing to build would have. Speakers, other gear like CD, tape deck, etc.
regards
robotek
Posted on Jul 24, 2008
ginko
  • 19396 Answers
SOURCE: MARANTZ CD PLAYER/RECORDER MODEL#CDR500/U1B
Contact
Marantz
to get original replacements
Posted on Jul 31, 2008
  • 4234 Answers
SOURCE: Marantz MA-7 schematics diagram needed
I am not aware of this beig available in PDF format. What is the problem you are trying to address? Perhaps we can resolve it without the schematic.
Dan
Posted on Apr 09, 2009
  • 323 Answers
SOURCE: Receiver won't fit Model 52-CS
Turn the breaker off first.
You'll have to take the fan down and of course disconnect the wires. I run into this a lot. What I do is take a razor knife and cut carefully into the ceiling on the side of the box, Then connect the wires from the box to the remote module with wire nuts. I always wrap them in a couple turns of eletricians tape.
Then connect the long wires to the other end of the module and push it up through the slot I cut out and lay it flat on the top side of the ceiling.
When you put it back together the part that goes against the ceiling will cover the hole in the sheet rock. Pain in the rear, huh?
Sirwriter
Posted on May 15, 2009
  • 118 Answers
SOURCE: switching off after 15mts
in need of output replacement
Posted on Nov 04, 2009
Marantz SR19/U1B 5.1 AV Surround Receiver Unit powers on but will not play audio out of any of the speaker channels. Buttons respond. No further testing could be done with my knowledge.
The receiver could have gone into protect mode as a result of incorrect speaker connection in which case there should be some indication on the front panel.. Check all speaker connections as even a short between wire strands can shut down the receiver output. You may have to open up the receiver to check for open fuses in the output.
Nov 30, 2013 | Audio Players & Recorders
CS4228A burns after replacment
Hi
Martynas Z
CS4228A on DSP board can be overdriven on the inputs
CS4228A on DSP board can have shorted loads on the output
Check also the board (might be burnt also)
Here is block diagram for you:
Check components around it thoroughly.
Let us know how you make it out.
Sep 28, 2012 | Marantz SR-5200 Receiver
Need to replace the rubber feet on my marantz Model 6150 turntable
Take some off of an old receiver or other turntable. You can also buy rubber chair feet at Lowes or Home Depot in the hardware section
Nov 27, 2010 | Marantz Audio Players & Recorders
There's a error pow5v on the display what can i
chek it on service manual, I remplazed Icn 601 TA7317P speaker protector ...and it works succesfully
tecso.com.mx
Marantz servicing Engineer
Jul 13, 2009 | Marantz SR-4300 Receiver
Sr4300 mainly dead
Hi..
If you dont mind getting a real good service manual , try
www.stereomanuals.com
I'd say 15-25 $
Jan 08, 2009 | Marantz SR-4300 Receiver
Computer input to Marantz 50 Inch TV
You will need a VGA to HDMI converter, at least $100. Just Google it and you'll find one. One is linked here: http://www.hdtvsupply.com/vga-to-hdmi.html
Aug 16, 2008 | Televison & Video
Standby Problem
No, I think you have a bias problem in the audio output circuit of this receiver. There is really not a lot a user can do to fix this unless you have the electronic know how and know how to trouble shoot solid state electronics. Good Luck
Jun 12, 2007 | Marantz SR-4300 Receiver
85 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
