Question about Saeco VIA Venezia
Cannot express the coffee into the cups
We have a Saeco Via Venezia Espresso machine. and for a while now, we are not able make coffee, the pump is in the water container, we have cleaned the filters, but still it does not want to express any coffee out of the filter.
The steamer works fine.
  • grantd Aug 27, 2008
    We have lost the instruction for the Via Venezia and we put water in, put coffee into the little cup thing but the coffee is not dripping through to coffee cup, the steamer works. What are we doing wrong?
  • Anonymous Mar 05, 2009
    samesys
    Scholar:
  • 65 Answers
Solution nr one cold be the machine ran out of water and the circuit need to be filled up again.
This is the procedure to do that
Fill up your water tank
Open the steam knob na push the coffe button...in that way the water will be forced to go to the steamer.If you have water in the steamer like you asking for hot water....go to the next step
Close the steam knob and at that point you will hear a different noise and the watewr should be able to go direct into the boiler and start dripping like it was before.
if you don`t have hot water coming oput from the steamer....the problem is before the boiler and could be a clog on the silicon tube or the water pump is loosing friction..
Pls don`t forget to rate your experience
Fabio
Posted on Dec 02, 2008
Try cleaning out the steel filter cup which the coffeesits in, as this often gets blocked
Posted on Nov 08, 2008
Have you descaled?
Posted on Jun 09, 2008
We have broken the handle on pressurized portafilter for Saeco Via Venezia espresso machine. where can we get replacement?
I don't think the handle is sold separately. Seattlecoffeegear does sells both a bottomless and an unpressurised portafilter for the Via Venezia. Both would be considered upgraded gear vs the pressurized one.
Jan 30, 2013 | Saeco VIA Venezia
After months of perfect performance, my via
HI I think you have a blown element in the boiler. You might have a leak that is shorting inside also.
Jan 26, 2010 | Saeco VIA Venezia
My Saeco Via Venezia espresso maker broke; the screw that holds the metal filter into the machine will not remain there. What can I do?
HI
There is a large screw in the brew head that your screw screws into. You need to replace the big screw and you should be good to go.
Nov 12, 2009 | Saeco VIA Venezia
Saeco espresso machine Isn't pulling water at all
Can you brew a coffee? If not then the problem is the pump might be blocked.
Jun 22, 2009 | Saeco VIA Venezia
Saeco via venezia coffee machine wont prime
Turn machine on and make sure that the knob is fully opened, if the pump does not engage(vibrate) then either the machine is not getting power or there is a problem with the pump.
Apr 19, 2009 | Saeco VIA Venezia
Makeing coffee
No, these machines use a pressurized portafilter to make brewing espresso easier. Be sure your coffee is ground about the fineness of table salt. Just level the coffee in the filter and insert the filter as instructed.
Mar 08, 2009 | Saeco VIA Venezia
Saeco Via Venezia Cappacino Machine The black plastic sleave for the frothing arm has melted and no longer fits on - where can i get a new one? I am based in Canberra - its a Via Venizia Espresso
Contact Saeco Australia to see if they can help you.
Saeco Australia Pty Ltd
6/87 Newlands Road Reservoir
Victoria 3073
Australia
Tel.: +61 3 94624949
Fax: +61 3 94624955
E-mail: info@saeco.com.au
/Mirran
Aug 31, 2008 | Saeco VIA Venezia
Steam works, coffee doesn´t
Try to prime the machine.
Open the steam knob and press the buttom for coffee, when the water comes, close the steam knob.
Aug 24, 2008 | Saeco VIA Venezia
Saeco VIA Venezia Logo
358 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
