Question about RCA DRC8030N
Constant hello's my rca drc8030n has been out of commission for a while. how can i solve the problem of constant hello's and no display?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
Constant hello is most likely the DVD drive. if you have a spare, then I would recommend replacing it (it is a computer drive so any will work). If you do not have a spare, then you can go to Ebay or Ecrater and purchase a used DVD drive and pop it in. It is failry easy to do.
Posted on Jun 12, 2008
I NEED POWER SUPPLY BOARD FOR DRC8030N
I am sure that the fault was relative of the bad capacitor and swapping the working board has proved. Hope that solves the issue as all what is needed is to check and replace all the suspected capacitor is the Primary /Secondary side as the SMPS is working BUT with a limited voltage. So the threshold is low and so can be a tank capacitor, change the mains capacitor and also the secondary +B side.
Dec 02, 2011 | RCA DRC8030N
RCA DRC8030n Owner's Manual
Hey jacquesnoir,,
I can email you a copy of the manual..
bigsteve1962@excite.com
PLEASE put "RCA DRC8030N" in the subject line otherwise I will delete the message and you won't get the manual... I get quite a bit of junk at this address so be patient..
Steve
Mar 27, 2009 | RCA DRC8030N
Multi region code
1. Go to the main manu.
2. Open the Tray.
3. Press OK on setup.
4. Hightlight disk options
5. Press 8 2 1 3 x where x is the region you wish to use. Use 9 for all regions.
If you typed 8 2 1 3 9 it will quickly say region 9 on the display.
I want to find a replacement for DRC8030N
you can replace the DVD-RW yourself with any computer DVD/DVD-rw drive.  You will need to modify the way it sits in the unit as the screw holes will be different and some drilling will most likely be needed to make new screw holes.  Finding an original replacement DVD-RW for this unit will be hard because the first problem that this unit has is a constant HELLO message due to a faulty DVD-RW, so they are in high demand.
Jan 13, 2009 | RCA DRC8030N
RCA DRC8030N No output
Connect the unit as you normally would using the composite cables. Once you turn the unit on and the RCA logo flashes and then the video *poof*, dissappears, press the Video Out button on the remote control so that the PS OFF (progressive output for S-Video) is shown on the LCD, this should get the video back to normal.
Nov 09, 2008 | RCA DRC8030N
Rca drc8030n hello
9 out of 10 the Hello problem lies in the DVD-RW board (I replace this board to correct the problem) and that 1 out of 10 time the problem lies in the main board that the IDEs connect to. I have replaced this board as well to correct such problem. I understand that these spare parts are impossible to come by. If you can make sure that the DVD-RW is fine by hooking it up to your PC and reading from it, then I can send you an RCA DRC8030N with the Hello issue that originates in the DVD-RW (so you can swap out the main board that connects the IDEs) and still have extra parts for later possible problems. If interested, you can contact me via triple w.suncitybargains.ecrater.com Thanks.
Jul 25, 2008 | RCA DRC8030N
RCA DRC8030N Problem
This is due to the DVD-RW drive that is in the unit. This is the first to fail and RCA seems to have gone with the lowest bidder on this model. The DVD-RW drive will need to be replaced. If you used the DVR to watch and burn DVDs then you will need to replace it with any computer DVD-RW but you may need to re-drill some holes to have the replacement drive fit exactly aligned with the DVD door. If you only want to use this DVR for the internal hard drive recording and TV viewing, then any CD or DVD computer drive will do, just simply connect the replacement drive and leave it in the case (you wont have access to the DVD or CD drive under this option). If you do replace the drive, make sure you match up the jumper on the back so that it will be in the same position as in the original DVD drive ( the Master setting). I hope I did not scare you with all this information, but unfortunately, the dreaded HELLO issue with the DRC8030N has no easy fix.
Jul 09, 2008 | RCA DRC8030N
Manual
my drc8030n only say "hello"
May 03, 2008 | RCA DRC8030N
Says hello
This is the power on procedure. Once it goes out, then press the poer button. If all you get is a blue screen, then turn off the progressive scan by pressing the small round button on the remote that is labeled "video out"
Apr 19, 2008 | RCA DRC8030N
Drc8030n says hello
Are all the cords connected? Is there any disk in? Make sure theese are all done
Nov 29, 2007 | RCA DRC8030N
RCA DRC8030N Logo
235 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
