Question about Cambridge Audio 640R 7.1 Channels Receiver
I have a Cambridge audio amp 640r , the remote work intermittently now the amp wont turn on i only have a blue dot on the screen. can anyone help please
Omg I have the same problem with this small blue dot in the middle, the rceiver is not going on. Did anybody find any solution??
Posted on Jun 23, 2012
  • Mud man May 27, 2016
    Mine did the same I just pulled optic cable out vaccummed it . Dropped it a few times turned it on and off a few times . And started working again haven't had problem again I have a sneaking suspicion it was the optic cable just at a wild guess ...??? Who knows try everything ha ha.. Talk to it maybe even I sweared at it a few times too:)
Arthur, I have the same problem - did you ever find a solution to this?
Thanks
Toby
Posted on Dec 14, 2010
  • 1 more comment
  • Tom Ridchardson Jan 18, 2011
    Anyone figured what was the problem ?
  • tobywp Jan 19, 2011
    No one responded unfortuately. The partial good news though is that after leaving it unplugged for several weeks, i switched it back on just before taking it the the shop for fixing and it started working again! Very strange. I still get intermittent remote problems though - sometimes it doesn;t work at all, sometimes volume changes by itself or switches off mute by itself - ghosts in the machine!
    New Friend:
Same thing happened to me, blue dot appeared when you turned on the power at rear or plug. By flicking the rear power switch off and on slowly it sometimes worked sometimes not, I ended up keeping it on standby to avoid the problem after it worked. This lasted a few months till the house power went off one time and the blue dot came on permanently from that moment on. Just today was cutting my losses and pricing up a cheap alternative, then I though there's nothing to lose so I put the amp up on its side and let it drop onto it's top, did this on both sides. Was surprised when eventually after hooking power up it came back on. Hoovered it out as well just incase 9 years of dust had been a factor, switched off power and blue dot came on again. I managed to pull out plug and in again, it started fine so leaving it in standby. If I can't get it working some day in the future going to use the old drop tactic to try and revive. Hope this helps!
Posted on Feb 28, 2016
    New Friend:
Bump!
Same problem,but any suggested solution doesnt help..
Posted on Jul 04, 2015
Hi,I just got the same issue: first the remote stopped working, i tryied to switch the amp off (what i never do...), and now i can't power it up again, i have this blue point on the display. Did you guys find a solution?Thanks,Pierre
Posted on Oct 06, 2011
Same here. Same problem with unresponsive remote then once I set the unit to standby it wouldnt power up again. All I got was the single blue dot on the Dot Matrix screen.
I tried cycling the NORM/UPDATE switch on the back but it did not help.
I finally got it to work by quickly cycling the power switch on the back.
This is obviously a common problem.
Anyone know of the cause/solution ??
Posted on Feb 27, 2011
Posted on Jan 18, 2011
  • 1 more comment
  • Tom Ridchardson Jan 19, 2011
    I got news from Cambridge Audio, there's a switch at the back of the device, next to the RS232 connector, labeled "Normal/Upgrade", this switch should be in "Normal" and will fix the blue dot problem.
  • Ryan Dick
    Ryan Dick Jan 04, 2017
    Same thing hap with mine...th plug was pulled ou before I unit wa switch off at at back. Took the top cover off, check the fuses, all were good. Tried plugging it back in an turning it on, didn't work...fumbled by pushing buttons while turning th power on and off....finally worked....think it is some kind of safe mode if there is an accidental power shortage or surge. There should be a common/proper fix to this issue
  • Anonymous Sep 10, 2017
    Amazing, Tom thanks, by putting the switch to Upgrade then back to Normal I got mine to work, better than dropping it repeatedly like I did before.
Cambridge Audio Azur 640R AV Recorder won't switch off
Sounds like the unit is victim of a power surge. The power control board is probably damaged. You will be better off replacing the amp as having it repaired will cost more than replacing it.
Mar 02, 2014 | Cambridge Audio Azur 640R 7.1 Channel...
Tip
Cambridge Audio DV30 DVD Manual Download
Download Cambridge Audio DV30 DVD Player Manual
Would you like to review the features of the Cambridge Audio DV30 DVD Player?
Have you lost your Cambridge Audio DV30 DVD Player Users Guide?
Would you like a digital, searchable, pdf version of the Cambridge Audio DV30 DVD Player Owners Manual?
Follow this link (& click FREE) to download a pdf version of the Cambridge Audio DV30 DVD Player documentation.
I hope that helps.
___________________________________________________
Cambridge Audio DV30 Remote Codes Download
on Jul 14, 2010 | Televison & Video
Tip
Cambridge Audio DV30 DVD Remote Codes Download
Download Cambridge Audio DV30 DVD Player Remote Codes Manual
Have you lost your Cambridge Audio DV30 DVD Player Remote Codes?
Would you like a digital, searchable, pdf version of the Cambridge Audio DV30 DVD Player Remote Codesl?
Follow this link (& click FREE) to download a pdf version of the Cambridge Audio DV30 DVD Player remote codes documentation.
I hope that helps.
Cambridge Audio DV30 Manual Download
Thinking of buying head phones have Cambridge amp but cant find socket for phones
Without knowing the model number of the Cambridge amp there is no way anyone on Fixya can help you.
Aug 21, 2013 | Cambridge Audio Audio Players & Recorders
Hi, just made a stupid mistake - plugged in an HDMI cable into the output HDMI port of the Azur 640R - it's gone dead on me! Changed fuse in plug, still no joy are their any other fuses / things I
As you know the out has a different pin connection so you shorted something out---no suggestions aside from having someone look at the unit--it may have a hidden protection against this or not.
How expensive is the unit to replace?
Jun 13, 2012 | Cambridge Audio 640R 7.1 Channels Receiver
Tip
I hope that helps.
on Jul 14, 2010 | Audio Players & Recorders
Tip
I hope that helps.
Tip
I hope that helps.
on Jul 14, 2010 | Cambridge Audio Sonata DV30 Player
Tip
I hope that helps.
Open Questions:
Cambridge Audio 640R 7.1 Channels Receiver Logo
1,276 people viewed this question
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
