Question about Microsoft Wireless Laser Mouse 5000
Only left click and wheel work, rest of buttons on mouse stopped working
  • 61 Answers
Try to open the mouse software and find out...next
Posted on Aug 04, 2010
Samsung laptop mouse left button
-If me I'll buy a new mouse.
Good luck
Mai
Jun 16, 2017 | Computers & Internet
This is a problem with a iHome Laser Mouse product. ihome 3-Button Laser Mouse Model Number- iH-M120LB Serial Number:0906001183 I am having trouble using the left click button on the mouse. I...
When you change the left mouse pointer to be the right mouse pointer in the settings of the mouse, then if the right mouse button stops working, it is a software problem and reinstalling drivers is the way to go. If on the otherhand the left mouse button still does not respond, then there is a problem with the switch in the mouse. This is hardware related. Either clean the mouse or buy a new one.
May 11, 2017 | iHome 3 Button Fast Track Laser Mouse...
The left click button on my Logitech M555b mouse stopped working earlier today for no apparent reason. It has no physical damage, such as dents, scrapes, or water damage. The mouse is only about 2 months...
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
then click on the >> all control panel items scroll to mouse in the buttons tab you will see the defaults left button right button and middle wheel click you might have to set the left click button again
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Or disconnect the mouse from your computer restart.
If still does not work you need a new mouse.
hope this helps
Sep 30, 2012 | Logitech Mouse Bluetooth M555b Black Pc...
I have a HP Precision Tracking wireless mouse. The left click has stopped working. The right click, wheel, & all else seems fine. Any suggestions?
One fix is to try and clean under the button with something like a Q-Tip or something small like that. It is probably not working because something is underneath it such as dirt stopping it from clicking.
Sep 03, 2011 | Computers & Internet
The magnifier pop-up icon plus works but the minus won't work.The google help in google docs is so large that it overlaps onto itself. I'm working on a Toshiba Satellite L635---Help???
Connect an external mouse then press and hold the CTRL key on the keyboard. Just scroll down the scroll wheel located in between the left and right click buttons on the mouse and it should zoom out the page.
Hope this helps.
Jun 13, 2011 | Toshiba Computers & Internet
Microsoft wireless intelimouse explorer 2.0
Having experienced the same problem with (2) Intellimouse Explorers I analyzed the problem and found a solution after driver updates failed to correct it.
Remove the single screw inside the battery compartment, lift off the rear portion of the mouse top cover, then gently lift up the back end of the remaining shell.
Once you have the inner workings exposed, use a Q-Tip to dab rubbing alcohol on the right click button's micro switch, manually clicking it a couple dozen times to clean the button's inner workings. Do not work about shorting out the mouse, as alcohol is non-conductive, and non-corrosive. It will not harm the electronic circuitry.
It doesn't hurt to do the same for the left click micro switch and the side button switches as well, as long as the mouse is disassembled.
Next use a clean Q-Tip to clean the edges of the top & bottom housing. This is the most likely cause of the right click button failure - there are small particles of debris lodged along the edge where the travel of the right click button is supposed to depress, but cannot.
Next, turn the top cover over and move the catch on the right underside forward and push it gently downward to uncatch the edge of that latching clip. The click on the left underside is a bit more complicated and requires a gentle lifting of the rear pins and moving the left clip more to the left and downward to release it from it's locking position.
Once you have freed the actual button's cover from the rest of the top cover, clean it thoroughly with a Q-Tip swab soaked with rubbing alcohol.
While the works are exposed, check for hair and debris around the scroll wheel as well. The small plastic wheel cover lifts off starting from the read and tipping up and forward.
Carefully reassemble all parts and hte right click function should now be restored. The debris has been removed and the right click now has it's full range of travel restored.
Apr 29, 2008 | Microsoft Wireless IntelliMouse Explorer
Microsoft Wireless Laser Mouse 5000 Logo
59 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
