Question about HP Office Equipment & Supplies
I have a new wireless hp deskjet F4580.I have a paper jam and don't know how to get it out.I'm 76 and my grandkids installed it and I can't find read me on computer
yooperbud
  • 8637 Answers
SOURCE: hp deskjet f380 paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 24, 2009
SOURCE: paper jam in hp deskjet 5900 series. how do i correct?
hp 5900 printing report after print
Posted on Apr 20, 2009
SOURCE: HP 3915 paper jam error
I had the same problem and just talked with HP technician Neeta and she showed me how to fix it. It's a bit convoluted. In essence you have to clear the print spooler. Here is what she told me.
First you have to be clear that there really ISN'T a paper jam by printing a test message this back door way.
Neeta : The USB cable should be disconnected. Neeta: To print a self-test page, press and hold the Power button. Raise and lower the printer cover four times. Release the Power button, and the self-test page prints
If the sel-test page prints, this means you truly do not have a paper jam. Next, clear the print spooler
Neeta : The USB cable should be disconnected.Neeta : Now click on start->RUN.Neeta : Then type "services.msc".Neeta : Then it will open the services window.Neeta : Now please look for the option "print spooler. Neeta : Okay, now , please right click on the option "print spooler" and click on stop then click on start, 3 times.
Posted on May 04, 2009
  • 14 Answers
SOURCE: paper jam in HP deskjet 380 series
I just completely took apart my front feeder unit because I just didn't believe there was a paper stuck in there. Sure enough, when I got to the bottom (an hour later) there it was- and it wasn't from the paper that was jammed. It must have been floating around in there waiting to get in just the right place to block the little sensor wiggly thing.
After I got it out, I realized there was a MUCH easier solution--- get some heavy paper (I used cardboard folded in half) and manually feed it through the paper feeder in the front assembly by hand. You can see where it should go in (it's where the paper from Tray 1 goes in) and out (it lines up with the belt in the main body of the printer) and there is a large gear on the side you can turn to help you get it through (just turn the gears until you feel the one that grabs your heavy paper.)
As it comes out, it should have your stuck paper with it.
Jeremy
Posted on Jun 15, 2009
  • 72 Answers
SOURCE: HP deskjet F380 - 'status: paper jam'. There is no paper jam!
Unplug the power cord and while doing that make sure printer is powered on i mean do not turn off the printer using the power button. When you unplug the power cord than press and hold the power button for 30 seconds. Than release the power button and connect the power cord and then try to print.
Posted on Jul 22, 2009
How do I connect my new BT hub 4 wirelessly to my HP F4580 printer
Keep Pressing the BT hub button until the light continuously burn. Search your BT name in the printer bluetooth device. connect it using the PIN 0000.
Dec 28, 2014 | HP Open Box Deskjet F4580 All In One...
How do I reset the ink level on HP F4580 printer
It automatically reset them when you install them & close the lid.
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
Dec 14, 2014 | HP Open Box Deskjet F4580 All In One...
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
Connect to Hp printer deskjet f4580
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
Dec 20, 2012 | HP Office Equipment & Supplies
Lost cd for hp deskjet f4580
what's your Operating System (OS)? anyway, you can download the driver here, on HP's site. Just select the right OS and you're good to go.
Don't forget to rate me if I was able to help you. :)
Jan 10, 2012 | HP DeskJet F380 All-In-One Printer
HP deskjet D2520 does unable to print. paper jams all the time.
Put less paper in the bottom, they jam if there are too many pieces. They don't hold as much pieces as some older models of printers.
Jul 03, 2011 | HP DeskJet D2560 InkJet Printer
Need to install my hp F4580 printer to my new net book...cannot use CD is there any other way?
I have two options that I can recommend for you.
1. Download the HP F4580 from the Hp website.
Here's the link: Click Here F4580 PRINTER DRIVER ...
It will take you to a screen which looks like this:
Select your operating system running in your netbook. Then select driver.. Then run it. Then follow the on screen instructions. After the installation, your printer will print.
2. The second option is to use an external dvd/cd drive. It could be connected to your netbook by using a usb cord. You can buy it from any computer stores..
I hope this helps.
Don't forget to leave your comments and ratings for your free technical support in fixya.
Thank you for using fixya. Have a good day.
Carlo
Sep 25, 2010 | HP DeskJet F380 All-In-One Printer
Blinking lights on my hp deskjet 840c printer
There should be some error .So you know how to remove the catridges just remove it n re insert it properly.If there are any paper jams try removing it also.and by the way if you haven't installed the drivers for HP deskjet this problem may arise.So make sure you ahve don this.Also this can be happened if the printer have some hardware problems.So none of this solutions are working its better to consult it with an expert.
Dec 18, 2008 | HP DeskJet 840c InkJet Printer
Printer Will Not print
There probably is, in fact, a "paper jam". A very tiny piece of paper is stuck somewhere in this printer. If the printheads (where the ink carts. are) move freely when cover is opened, it's most def. a paper jam.
gurutim
Dec 18, 2008 | HP DESKJET PRINTER, HP OR COMPATIBLE
539 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
