Question about Kitchen Ranges
Pacific Hydrostar water booster pump. Besides all the plastic parts leaking. The pump runs but doesn't shut down. Goes up to 100 psi. How can you adjust this? The blue box on it has some wires,but I didn't see a pressure switch.Model no. 96719 / 800 watt pressure booster pump. Came from Harbor Freight. Also can I replace the plastic switch on top with some kind of metal switch? If I can first get it to shut down. Thanks
micromaster
  • 3614 Answers
SOURCE: WIRE CONNECTIONS
may i know the exact model # of your unit, and the part # of your switch control.
let me know, thanks.
micro
Posted on Aug 27, 2008
  • 56 Answers
SOURCE: lower oven burner has a yellow flame,broiler flame
Just Live With It
Posted on Aug 07, 2009
  • 10 Answers
SOURCE: I have a Flotec model FP4105. When running
Try cleaning the jet.
Posted on Oct 24, 2009
SOURCE: Help! i have a pacific hydrostar 65078. Engine
You have to have a clogged hose gun. Try blowing it out with air. Also, Harbor Freight sells the Pacific-Hydrostar and you can buy a 2 year full warranty for around $70 bucks. A small price to pay if you use your powerwasher on a frequent basis. If anything goes wrong, regardless of what the cause, they simply replace the washer.Hope this helps.
Posted on Nov 23, 2009
digritz
  • 530 Answers
SOURCE: my compressor runs upto 145 psi before it shuts
Usually you have a screw set in the middle and one set off to the right or left. One (normally center), will adjust the cut-in and cut-out pressure, the other will only effect the cut-out. Clock-wise to raise for both screws.
I am not positive on your make of switch but it is probably a Furnas or similar brand switch.
To get the desired setting you will need to adjust both screws.First you will need to lower the "Cut-out" screw this should be the plastic screw. Turn this counter clock-wise. You will need to drop it the same amount that you want to raise the "Cut-in" pressure.
Second turn the "Cut-in" "Cut-out" screw clock wise to raise both the settings.
If you raise the "Cut-in" psi without lowering the other first you will end up with a "Cut-out"pressure of 165 psi.
Since I am not positive on the brand check your setting after your first adjustment to verify you are changing the "Cut-out" only psi. Make small adjustments, 1/2 to 1 turn of the screw.
If you have any problems please don't hesitate to ask for a clarification. Hope this helps.
Posted on Jun 10, 2010
What causes my booster pump to increase pressure even after I shut power and or water supply off?
something wrong here. your incoming pressure is 4 psi ( tank pressure to the pump and you use a pump to boost pressure to a maximum of 65 psi at which point the pump is shut off ( all taps close off)
yet with no pumps running the pressure goes up to 100 psi
Find where you are getting pressure in that is making the pump leak
if you have 100 psi to the pump when it is turned off, then it would not be turning on ( power on) as the shut off pressure is set at 65 psi and the line pressure is 100 psi
Sep 27, 2016 | Grundfos MQ3-45 1 HP Pressure Booster...
I need to change the pump on my pacific hydrostar 2800
That cannot be done over the internet, no matter what ISP you have.
Further, you need to be more-specific about exactly what you have.
Pacific Hydrostar makes both sump pumps and pressure washers with 2800 ratings (gallons per hour and PSI, respectively). So you should use the model number of your device, not what the large print on its decals say, when requesting help with them.
Apr 03, 2015 | Computers & Internet
Pacifichydrostar 1650 pump pulses when pulling the trigger
It may be time to do mainatance to it. Look at: http://www.manualslib.com/manual/443079/Pacific-Hydrostar-1650-Psi.html?page=14
for information on that. It is also possible you do not have enough water flow to the pump. Be sure your feed hose is not colapsing.
Sep 21, 2013 | Plumbing
Pacific hydrostar 68333 1500psi pressure washer...motor keeps cutting out, but reset breaker does NOT trip.
dont know the model or if it has a pressure switch inside the box but try and remove your lance and just operate the gun... if it runs ok your last could be blocked
Aug 21, 2013 | Pacific Hydrostar Pacifichydrostar...
Pacific Hydrostar pump 2" 6.5 HP Item # 95977. I
Do you know where get a owner/repair manual for a Pacific Hydrostar portable water pump #95977?
Jul 09, 2011 | Plumbing
Ok at the place I am employed they have a 1 Hp submersible pump it pumps about 300 ft into the top of a 120 gal storage tank then the water comes out of the bottom of the tank and goes into our grundfos...
The booster should have been placed after you restrooms with a check valve to prevent back-pressure. then you can adjust both the sub-pump pressure, and the booster pressure accordingly
let me know
Dec 18, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
Pacific Hydrostar 95618. pump oil?
Pacific Hydrostar is another pacific rim product that has no website, and no manuals online, and nobody to contact, and no parts available. These machines must be made for the throw-away user.
Pump oil comes about half way up inside pump housing > pump oil is 20 or 30 weight non-detergent oil SAE20 SAE 30
Engine oil comes half way up dip stick > engine oil 10W30
Do not turn power washer on its side or upside down when draining oil, or engine oil will go into carburetor and machine will not start
Oct 13, 2010 | Garden
Help! i have a pacific hydrostar 65078. Engine runs fine. Pump pressure is good with the hose off. the stream shoots across my driveway. But when i connect the hose(sears 3/8 25'' i loose all pressure.
Nov 20, 2009 | Garden
Leaks water out of the back
Well, I am no plumber but I would think that 108 psi is a bit high for your plumbing system. I have this pump installed in my house and have the max pressure set at 50 with a PRV on the outlet side of the pump.
Mar 24, 2009 | Grundfos MQ3-45 1 HP Pressure Booster...
Kitchen Ranges Logo
875 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
