Question about Seagate Barracuda ATA IV (ST340016A) 40 GB Hard Drive
Can i hook a Seagate Barracuda ATA IV model 340016A to a HP Elitebook 6930?
  • 251 Answers
SOURCE: soft ware for seagate barracuda ata model st
this link is a walk through on how to mount a hard drive ,hope this helps
http://www.mydigitallife.info/2008/02/19/how-to-mount-and-access-new-partition-volume-or-drive-as-folder-path-in-windows/
Posted on Apr 25, 2010
bronk50
  • 27725 Answers
SOURCE: i need the driver of
you might have to physically unplug the disk drive then plug it back in this should activate the found new hardware wizard or
control panel administrive tools computer management device manger scroll to disk drives + to expand if you see your drive right click you will have options update driver ,uninstall,scan for hardware changes,properties in the properties tab you will have more options in the general tab you can troubleshoot, in the driver tab you can update driver,rollback driver,uninstall driver
hope this helps
Posted on Nov 24, 2010
pgh_pa_guy
  • 2992 Answers
SOURCE: what type of hard disk
I assume you want an external enclosure for this drive. Hard drives are built to standard dimensions and have the same power and data connectors, so any enclosure designed for a 3.5-inch IDE drive would work. Here's one I've bought several of for myself and others, and it's been reliable. There are many more available from many vendors. Just be sure you get one designed for IDE drives or that will take both IDE and SATA. If you get one meant for SATA only, the connectors inside won't fit your drive. Which enclosure you finally choose will depend on which you think is best (based on price, appearance, reviews, or whatever you look for), but any one will work.
Posted on Dec 02, 2010
  • 2386 Answers
SOURCE: which is the correct jumper settings on Seagate
Hello Please see the image below for correct jumper setting cmptrlink_16.jpg
Hope this helps, if so do rate the solution
Posted on Jan 15, 2011
CameraParts4
  • 109 Answers
SOURCE: My Seagate Barracuda ATA IV
If I were you I would make sure your computer has no size barriers.. Some computer bios have
a maximum drive size that it will accept. Be sure to check this before purchasing. Of course you can always go with the same size 40GB, but your best move is to upgrade to a higher size.
Everyone has their opinion about vendors. If you ask me Drives fail just like any other device, so
get one with a good included warranty and back up your stuff. Look for speed and size and
make sure its the same I/O as your original.
MOST IMPORTANT : Verify your system can handle the size you wish to purchase
Posted on Jan 23, 2011
Hi, I have some troubles with my Baracuda ATA IV 20gb,so I need to download some softwear for this harddrive.Do you know weare I can find it? Thanks Allex Bulat
Hi
Hard Drive faults can rarely be repaired by downlading drivers. The drivers for almost all hard drives are already in any operating system.
Most hard drive faults are physical faults, such as bad sectors, controller board faults or shock damage.
Some apparent faults may actually be due to incorrect jumper settings. It is worth fully exploring all the jumper setting options available on this drive.
This drive is quite an old ATA drive and because hard drives work so hard spinning several thousand times per minute (yours is 7,200rpm), the older a hard drive gets the more susceptible it is to failure.
Your drive was probably manufactured in 2001 and is likely to have had a 3 year warranty when new, so it is long past its warranty period. This means that little help is now available to you from Seagate.
It is sometimes possible to download Firware Updates for certain hard drives, which can improve the performance of the drive. But Firmware Updates rarely repair hard drive errors.
You can find detailed technical information about your hard drive here:
www.seagate.com/support/disc/manuals/ata/100129212b.pdf
Available Firmware Update Information for Seagate Drives can be found here:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=207931&NewLang=en To check if any Firmware Updates are available for your drive, you need the full model number, which should be somewhere on the label (possibly ST380021A).
If firmware updates or jumper settings changes don't work, you may have to consider buying a new ATA hard drive.
I hope this helps.
Aug 27, 2011 | Seagate Barracuda ATA IV (ST320011A) 20 GB...
I have a Seagate Barracuda ATAIV model ST340016A 40 Gig HDD. I want to put it in an external enclosed drive so that I can format and wipe the drive. I suspect it has some viruses on it that are bogging it...
You do not need a driver, I suspect the Seagate hard drive may be faulty.
Try conncting your hard drive as a Slave drive in your computer, if the BIOS does not detect the hard drive then the hard drive is faulty.
Aug 11, 2011 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
What kind of hard drive enclosure would i need for a Barracuda ATA IV model ST380021A?
im not sure what you mean this hard drive should fit into a computer without a need for any extra enclosures just the normal leads if you want any further assistance
http://www.seagate.com/cda/products/discsales/marketing/detail/0,1121,381,00.html
hope this helps
Apr 19, 2011 | Seagate Barracuda ATA IV (ST380021A) 80 GB...
My Seagate Barracuda ATA IV model ST340016A runs for about 15 minutes and shut the computer completely down. I was told my drive is crashing and I should get a new one. can I just pick up any seagate or...
Jan 23, 2011 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
Which is the correct jumper settings on Seagate Barracuda ATA IV 80 GB Hard Drive
Jan 15, 2011 | Seagate Barracuda ATA IV (ST380021A) 80 GB...
What type of hard disk enclosure wll work for a 40 gig Seagate Barracuda ata IV drive?
Dec 02, 2010 | Seagate Barracuda ATA IV (ST340016A) 40 GB...
Harddrive
Hi, Looks like it will be a motherboard issue not Maxtor (ATA) and Barracuda (SATA) combination. So the question really would be if your motherboard would accept and recognize the Barracuda SATA. Post back with your motherboard details, (brand/model/version). Kind regards.
Aug 30, 2007 | Seagate Barracuda 7200.8 300 GB Hard Drive
Seagate Barracuda ATA IV (ST340016A) 40 GB Hard Drive Logo
118 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
