Question about Dell E193FP 19" LCD Monitor
My Dell monitor keeps turning off . - Dell E193FP 19" LCD Monitor
  • 11,361 Answers
Look for shorted out transistors and blown fuse, bad caps, poor solder joints,
http://s807.photobucket.com/albums/yy352/budm/Dell%20E193FP/
Posted on Aug 05, 2010
I have a dell monitor and I keep getting this notice that control menu is blocked. how can I resolve this?
For the E771MM, press and hold the OK button on the monitor for 15+ to toggle off the OSD lock. Holding the button turns on the OSD lock as well. The OK button is the rightmost of the control buttons (excluding the power button). This is a useful feature if a small child will be near the monitor or if the monitor is being used for demonstrations.
The user's manual for the Dell E771MM is here: http://support.dell.com/support/edocs/monitors/e771mm/English/index.htm .
I hope this helps.
Jul 01, 2011 | Dell E771MM 17" CRT Monitor
My dell monitor will only turn on for a few seconds then it goes black. it doesnt turn of it just goes black and I can keep doing it and it will keep going black.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jun 29, 2010 | Dell E193FP 19" LCD Monitor
Dell Monitor wont turn on.
Your monitor has a self-test feature. Have you tried using it? The link below will give you directions on how to do this. It will also give you information on common problems.
http://support.dell.com/support/edocs/monitors/E176FP/En/index.htm
Jun 03, 2010 | Dell E176FP 17" LCD Monitor
Cn-ou4931-46633-52L-OHGU - monitor keeps showing
Here you go!
From Dell website:
'OSD Lock': Controls user access to adjustments. When 'Yes' (+) is selected, no user adjustments are allowed. All buttons are locked except the menu button.
All buttons can be locked or unlocked when the 'Menu' button is pushed and held for over 15 seconds. See more here:
http://support.dell.com/support/edocs/monitors/E173FP/En/controls.htm
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 13, 2010 | Dell E173FP 17" LCD Monitor
Dell 22" monitor goes black
Your monitor probably has bad capacitors now. Bring it to a local electronic repair shop and have the monitor tested. They can easily replace any bad capacitors.
I hope this helps. Have a nice day.
- HotRatchet
Dec 14, 2009 | Dell 22" SP2208WFP Widescreen Flat Panel...
The brightness control window keeps opening on the
The Up or Down button on your Flat Panel monitor is stuck. Please contact Dell Tech Support to have the monitor replaced if this is still within warranty
Jun 13, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
OSD Main Menu appears randomly and uncontrollably /flashing. Power Button does not always work. Need to keep clicking unti works.
hello..the problem is just sticky tack switch's so try to clean or re-align the frame/body of LCD..Thanks.Good Luck..^_^
May 08, 2009 | Dell E207WFP LCD Monitor
E172fpb monitor that turns on, but then goes dim
Your display have an inverter driver broken, So the back light can't turn on. Here is a website that shows this issue:
http://josepino.com/?howto-repair-dell
Feb 14, 2009 | Dell E173FP 17" LCD Monitor
Monitor goes black...computer keeps running regularely otherwise
its due to wahter problem its commen problem in a dell monitor u have to take ur monitor with a good electronic technision or if u have knowlged then u have change the id of u r ic in ur monitor & ur monitor will be redy to use
Jan 04, 2009 | Dell Inspiron 1521 Laptop
Dell E193FP 19" LCD Monitor Logo
135 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
