Question about Acomdata 1TB Puredrive USB Esata 1 TB Hard Drive
Everytime i turn the power on my acomdata 3.5" PureDrive External Hard Drive i recieve an error message (usb device not recognized) and then i can't access any of my storage.
One thing to note even when using a external drive to store/backup your data it is always good to burn your most important data to a DVD/CD to keep a hard copy for times like this, you can burn the DVD as a live DVD so you can rewrite over files with the same DVD or you can just Burn a new DVD each time as DVD's are very cheap these days.
If you have it fixed please let know and tell your solution or your problem for future users, please & thank you
How old is the drive? How long have you been using it? Have you dropped it or even tipped it over running/turned on or not?
It could be lots of things, Have you tried to reboot your computer unplug the external USB drive then replug it in another USB Port once windows is loaded? You can plug it in while the drive is turned on to see if that works at all. It could also be your Mass storage driver, OS uninstall that in device manager and then reinstall it by plugging in the drive. Do you have another computer home, work or friend that you could take the drive to and plug it in to test and see if it works there.
If it does its probably your machine if not its the probably the drive. If its your computer you may need to re-install the mass storage device driver or just change the usb port your using.
I do not know what Operation System you are using so I can only throw out some ideas to try.
If it is under warranty you can take it back to the store see if you can get a exchange if not, try a RMA with the manufacture you will lose all your data if you have to do this. So below are some instructions if you know basics to do, please use caution)
The hard drive itself may be corrupt, burned or bugged out or it could be the actual enclosure I have seen this lots of times. If it is still under warranty and make sure it will not void the warranty to open the enclosure most have pieces of tape stickers over parts so they know if it was opened it will be wripped, open it up and make sure all your plugs/wires are plugged in nice and tight, or look for any sign of wires being exposed or broken, if there are any wires.
When the drive is turned on can you hear and funny noises coming from it? Was the drive tipped over or dropped any distance?
Last resort if you tried everything else and may think its upir hard drive.
Next area is for anybody who may be having this problem with any external drive and has basic knowledge of hooking up a hard drive very simple for some.
Please read through it first or print it out then look up anything you do not understand on Google before starting.
This part is getting into testing and trouble shooting the actual hard Drive that was in your enclosure drive, the fastest and easiest way if you know the basics of what to do I will give instructions.
Unplug the computer and wait a few mins for power to drain from the motherboard. Make sure you always ground your self by touching the steal part of the case and try not to touch any parts, but if you are touching a steel part of the case you should be grounded and static electricity should not hurt anything, very rare but can happen you have been warned... lol
If you have the knowledge take the hard drive out of the external enclosure (usually a couple screws) and hook it up directly inside your computer via a SATA cable or if you know somebody that does and will do it for free? If not skip this part...
If you do not have any extra cables you can even just unplug the computers main Hard Drive SATA cable and power wire and plug it into this drive no need to take anything out of the case, or screw the drive in the case just set it beside the case with the side panel off.(when your done you can just plug it back into your main hard drive you pulled the wires from in the first place.)
Once you have the drive plugged in you can plug the computer back in and turn it on. Press the button to go into the bios and look and see if the hard drive shows up in the bios or you can watch the bootup screen and see if you see the drive show up. If the drive shows up you just unplug it plug your main computers hard drive in with the wires you were using from it, boot up the machine to windows or your OS (This can be done before you even put the drive in the first time to skip some steps plus this CD is always good to have anyway.) then open your web browser and go to www.google.com and search for a Linux live cd. Download it & burn it then, put the CD/DVD in the cdrom drive and boot your machine when it asks hit any key to boot from CD do so and it will boot into Linux live to make sure you did it right it is very simple you are just burning a image to a cd most CD burning programs can do this easily if you do not have one a program called "ImgBurn" is free and easy to use you can download it just put name in google and search downloa and install, great for burning any image files or files in general to CD or DVD.
Complete the first steps above to put the other hard drive(one you are testing) back in the computer, boot up into the linux live cd you burned and once in check and see if you can access the drive.(to boot into the Linux live CD you may need to go into your Bios when the computer first starts and change the boot order so the CD-Rom boots first so CD-Rom then Hard drive and put floppy disk last as they are pretty useless in today world where cd's & Jumpdrives can be used for everything.
OR another way Below
Hookup the drive directly to your computer using a SATA wire, plug in the power cord, (that is if your computer is not old enough that the power supply does not have any SATA power connectors if not you will have to buy a 4 prong to Sata power cable),( very cheap on eBay or a Computer store around your house.)
Keep in mind the actual brand of the Hardrive inside the enclosure because it will not be a "Acomdata" as that is only the company brand name that made the enclosure and put it all together very simple task.
Turn on the computer and watch if it shows up in the list of drives(could be a good sign) or you can go into the bios and take a look at the list of drives connected to the computer and see if it is in the list.
After the computer boots up take a look in "My Computer" for the drive, if it shows up click on it to see if you can access it, if not (This part on is for Windows Vista or WIndows 7 users if not go to end and read end part)
then go into "Control Panel\All Control Panel Items\Administrative Tools" then double click computer management, when it opens on the left side click on storage then disk Management.
Find the drive in your list depending on how many hard drives you have most will only have one, unless you added others.
Now find the drive you just installed, usually you can find it easiest by either its brand name or the drives size. Look in my Computer at drive C and how big it is and compare with the drives in the list, or you can look at the drives, drive letters like C: D: E: and so on. C: should be your main hard drive, D: is usually your DVD/CD rom...
Under health look and see what the smart is saying about the drive, it should say healthy if the drive is good. Click on the drive in that Windows and initialize it if needed (initialize does not mean "Mark Partition as active" when you right click on that drive)
Now if the drive does not show up at all or will not work or is not in a healthy state in the computer managment area we were just in the Drive is probably bad and should/needs to be replaced or its gonna fail soon, if everything works while it is connected directly to the computer it is the enclosure or your computers mass storage driver as explained above.
Posted on Sep 06, 2010
How do i locate the drive for external hard drive e5 (acomdata) 500gb in my computer
right clicking on "MY COMPUTER" and selecting "MANAGE"
In the left hand panel your'll find "DISK MANAGMENT"
See if you can see the drive there, if you can you may need to assign it a drive letter.
Mar 23, 2011 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
My external hard drive fell off my desk and since it has been beeping and not operating correctly
You broke it. Does the Acomdata warranty cover self-inflicted damage?
Did you buy it with a credit-card that adds "all-perils" insurance?
All you can do is to disassemble the enclosure, remove the disk-drive,
buy a similar, compatible, disk-drive, install it into the enclosure,
and thus "revive" your external storage device.
Nov 02, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
My PDHD1000 hard drive starts but does not boot up and connect to my computer like it used to.
You have a usb controller board that is malfunctioning and it or the case for the usb hard drive needs to be replaced.
the power regulator that is built into the usb controller is not working therefore the usb logic circuit cannot transmit the signal to the PC viia the USB port and will not recognize the device. You can order or purchase a new case that will accommodate the hard drive from your local computer store.
Sep 09, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
I have the western digital media player and it won't read my hard drive
Segate free agent External hard drive not recognizing as a drive
Although in device manager mass storage device is taken as drive for that.
one pop-up is coming "your usb could perform better in usb 2.0
operating system server 2003.
the same hard drive is working fine with windows XP system,but not working with server.
Jan 12, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
External hardrive not recognized
Try a different cable between the computer and the drive.
Disassemble the casing, and remove the "internal" disk-drive.
If the USB-to-disk-drive adapter has "died", it's possible that the
disk-drive itself is intact, and your data will be intact.
Connect the "internal" disk-drive as a "slave" drive in a desktop computer, and see if it can be detected.
If it's dead, and it's still under warranty, then exercise the warranty.
Jan 04, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
When i power up my 1TD external harddrive Windows is unable to access the drive or even reformat it is there a way to fix this?
Did you check the disk manager in Windows? Right-click My Computer and select Manage. You can see if the disk is there, if it is partitioned and formatted.
Could be a driver letter conflict.
Check some more ideas here: http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Dec 06, 2009 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
Not enough disk space to copy
Scan the drive due to possibly virus managing your disk drive. Virus can easily access through USB hard drives. If not solve the problem, so its better to format.
Mar 12, 2009 | Acomdata 500GB PureDrive USB eSATA 500 GB...
The red light is staying on on my Acomdata 1TB Puredrive USB Esata 1 TB Hard Drive and the computer will not recognize it.
I would say take the drive out and if you have SATA connectors on your motherboard, connect it directly to you computer and see if the computer will recognize it.  If it does, your enclosure is bad.
Mar 04, 2009 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
File transfer
Try turning everything off and then replugging the drive in.  Then start your computer back up/turn drive back on (if you have to).
Jan 31, 2009 | Acomdata 500GB PureDrive USB eSATA 500 GB...
Acomdata 1TB Puredrive USB Esata 1 TB Hard Drive Logo
145 people viewed this question
Top Acomdata Computers & Internet Experts
Donna Sander
Tom
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
