Question about North Star Stainless Steel Under Car Cleaner 16in
2000 epw Northstar Item # 157942E 230v 2000 psi 3.5 gal/min #5 nozzle Problem: No pressure. Motor running...seems to be in bypass. Checked starter...but not finding power to the pressure regulator. May need a new starter/relay/contactor. Was working fine..May wish to order a starter and a possibly a pressure regulator...I have photo's of the complete set up if needed. Need to know part numbers to order and what company to order from. Thanks, Greg Scott
How do you adjust the pressure?
get larger nozzles, if you are using size 4 nozzles now ( looks right for 3 gpm at 2500 psi) then you would use size 4.5 for 2000 psi, size 5 for 1600 psi etc
Chart here https://www.stens.com/assets/media/pdf/2012_Nozzle_Size_Reference_Guide.pdf
Sep 07, 2014 | Dewalt Pressure Washer - DXPW3025
Iam wanting to buy a 2-way cylinder to run off one of my outlets i need to know the pressure that my sk 1020 has ; in order to buy the correct one
Type Komatsu sk1020
Pump Gear
Max. flow - auxiliary hydraulic 21 gal/min 80 ltr./min
Max. pressure - auxiliary hydraulic 3,045 psi 210 bar
Control valve 3 elements fully Servo-controlled
High flow auxiliary hydraulic system "SUPER FLOW" (OPTIONAL):
Max. flow 34 gal/min 130 ltr./min
Max. pressure 3,045 psi 210 bar
cheers
Joe
www.barter-joes.com
Feb 12, 2011 | Computers & Internet
I have on oil psi put in a new oil psi sensor and new oil pump and still when you rev the motor you get 18 to 20 psi what could it be
Hello, This information is from the 1995 cadillac 4.6 Northstar service manual: oil pressure specifications engine at normal operating temp at idle 5 psi at 2000 rpm 35 psi Based on experience you would be better off putting another engine in your car. You can not turn the crankshaft on a Northstar engine. It sounds like the main and connecting rod bearings are worn beyond specs and also the cam bearings. You would spend more on parts compared to cost of another engine. That is my recommendation.
Sep 20, 2010 | 1995 Cadillac DeVille
Have a northstar model 157182d with an electric motor and the suction tube that pickups soap or chemicals does not work. Not sure also what position it needs to be in when I want to use it.
Hi there PBM,
The siphon will only work at low pressure.
The wand should have several different nozzles. There is a specific low pressure nozzle.
If they are color coded, it is usually black, If nothing else, look for the one with the biggest opening. and attach it.
The siphon will work with it
Best regards
Mike
Apr 18, 2010 | Northstar Pressure Washer 3000 PSI
My Northstar Turbo nozzle emits a solid stream of water without any turbo action.
NorthStar Pressure Washer Turbo Nozzle --> --> Turbo nozzle sprays up to 3.1 GPM at 2300 PSI and 194°F. Unique design delivers 0° high pressure impact with wide angle spray coverage.
The point of the Turbo is that it is a solid ( high pressure stream of water )
Oct 19, 2009 | Northstar Pressure Washer Turbo Nozzle
I have NorthStar 2000 psi pressure washer with a
1999 campbell hausfield 1800 psi--2.2gpm. weak pressure at the nozzle. water sprays out, but with the pressure of a garden hose.
Mar 20, 2009 | Garden
NO PSI
have you checked to make sure that keyway is installed between electric motor and pump. also adjustment on unloader valve may be incorrect. If the big brass nut on the unloader is able to be turned by hand, then this is probably your problem (running pressure and spike pressure needs to be set and locked down using a pressure guage). does water come out of nozzle at all? if not, tip being stopped up may be the problem. trash between unloader ball and seat can also cause no pressure (usually caused by a burr left inside brass pieces during the manufacturing process). I have seen all the check valves stuck on a brand new unit from sitting on the shelf for so long, but this is usually the case with General Pumps.
Jan 07, 2009 | Northstar Pressure Washer 3000 PSI
30'000 btu spark style will not lite
  1. clean the fuel filter
  2. clean the nozzle
  3. set the air pump pressure.
It should fire off, unless you have developed an air leak, worn nozzle, bad fan, or a motor that is not turning rpm's.
Nov 10, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
North Star Stainless Steel Under Car Cleaner 16in Logo
185 people viewed this question
Top North Star Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a North Star Garden Expert? Answer questions, earn points and help others
