Question about Seiko Office Equipment & Supplies
My SR950 does not re-boot after changing batteries (and pressing the re-boot button). The "keyboard button pressed" sound eminates, but no display.
SOURCE: When I press the power button LG displaying chars for 1 second
Had the same problem, turned out it was due to a faulty capacitor on the inverter board, 680uF 25V (105 celsius rated). Simple to fix once you have the unit dismantled and the correct replacement part. Two screws hold the shroud on, but you need to be careful with an (old) credit card levering it off.
Unit is now working fine.
Posted on Oct 23, 2008
SOURCE: Keyboard won't type
The problem ended up not being with the connect buttons. I am assuming after I changed the battery in the keyboard it deleted the encryption code. I did the Ctrl-Alt-F12, THEN, the "connect". Put in the encryption codes and Hallelujah, the keyboard is working again. Almost pitched the darn thing and purchased new. Hope this helps someone else.
Posted on Mar 04, 2009
jubag14
  • 89 Answers
SOURCE: dell wireless keyboard stoppped working
you will have to get a new one to me it sounds like there is no hope for it sorry but in you give me a rate of fixya for my help i will send you a wireless keyboard and mouse logitec
Posted on Apr 21, 2009
  • 12 Answers
SOURCE: keyboard keys not working properly
the problem you're having is a setting in your control panel. I don't know what OS you're using but if it is Vista, go to control panel and click on ease of acces...and click on MAKE THE KEYBOARD EASIER TO USE...unclick Turn on StickyKeys, Togglekeys and filter keys. Then go to control panel and open Keyboard...and increase the repeat and delay rate. If all these doesnt work...it means it might be a hardware problem
Posted on Jun 14, 2009
  • 5 Answers
SOURCE: I have a Compaq CQ50 laptop, there seems to be a
I was working in a computer with the same problem, when you remove the keyboard and the keyboard cover at the right side of the power button you can see an small plastic cap with two wires, is the num lock led, when the wires are under the top cover and the screws of the keyboard or the cover are too tight the wire is damage and make contac with the earth shuting down the power supply, check the wires, repair if broken and take care that its not under the top cover when you assembly.
Posted on Jan 12, 2010
When I turn on my Kurzweil PC2X, the LCD screen shows the message 'Scanner is dead!' followed by 'battery voltage low (0.0 volts).' The lights on the keyboard flash at me and the keyboard won't make any...
Try a factory reset.
Turn the unit on, and while the display says "Please Wait", press and release the Panic button. Press the right arrow button till the display says "Hard RESET". Press Enter, then the button under "Yes" in the display.
Sep 03, 2012 | Music
The brightness and sound indicator appear automatically(without pressing any buttons on the screen) on the screen and there is nothing that takes it away.
have you tried pressing the escape button on your keyboard
there are a number of things you could do to correct your problem
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
another thing you could try scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications if you see anything running that you dont want or need select end now
and another
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
Apr 06, 2011 | Computers & Internet
Hello, I have a Logitech wireless mouse and keyboard. I changed the battery for the keyboard and now both are not working. I should install the driver again?
I just had the same problem. First of all, make sure the transmitter to the wireless keyboard and mouse is plugged in tightly to the computer. It's possible that you could have pulled on the wire without realizing it, and it's not plugged in tightly! Unplug and replug the transmitter anyway after you change the batteries for the wireless keyboard. Then, there's a button on the transmitter, press it for 3 seconds, then quickly press the small button on the keyboard for 3 seconds, (my small buttons are underneath my wireless keyboard and mouse, and I use the tip of a ball point pen to press them). Then do the same for the wireless mouse. This syncronizes and boots them to start.
I'm not sure about the driver, but try the above first, it worked for me after I changed the batteries on my wireless keyboard and mouse.
Nov 03, 2010 | Logitech Wireless Access Duo Optical...
Our wireless keyboard has stopped working. we changed the batteries and now there is a lock looking figure on the display screen with a 1 inside of it. help?
My guess is that you need to resynch the keyboard with the receiver. The receiver likely has a button on it. Press it and then press a key on the keyboard.
May 20, 2010 | Computers & Internet
Dead keyboard. Yes! I have replace batteries, uninstalled everything, booted pc.
i just got off the phone with logitech tech support about my 'dead keyboard'. I have a logitech wireless keyboard/mouse ex100. the mouse still worked and the keyboard just quit all of the sudden like. THE FIX! 1. Make sure in your device manager that the keyboard is still connected and working properly. if it is...
2. then remove the batteries and type on the keyboard for 10 seconds or so.
3. Then reinsert the batteries.
4. press the left alt key, left control key, and the f12 key all at the same time.
5. Then press the connect button on the reciever
6. press the connect button on the keyboard
7. press the escape button on the keyoard
8. test the keyboard
it worked for me :) that's how i was able to type this. hope it works for you
Jan 04, 2010 | Logitech EX100 967499-0403 Keyboard
Selecting booting device
Normally with the new laptops you have to press F2 to access your bios settings, you will definitely be able to select the boot device from there.
If F2 does not work startup your laptop and watch the screen, there must be an option that will tell you which key to press to enter bios.
If the screen comes and goes to fast for you, press the pause button on your keyboard so you can read it at your own time and do your actual selection.
Hope it helps.
Aug 29, 2009 | Microsoft EF1330255 Keyboard/Mouse
LX 500 Keyboard not working mouse fine
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard.
Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps. Bud
Dec 29, 2008 | Logitech LX 700 9674180101
Keyboard not recognized
I'm assuming it's a wireless keyboard?
Have you tried "ReSyncing" the keyboard?
1) On the base unit for the keyboard/mouse plugged into the computer press the button on it.
2) Press the button on the bottom of your keyboard.
3) Try to use the keyboard.
You might have to try it a couple of times. That'll fix the problem 99% of the time. The other 1% means your keyboard is dead.
Oct 08, 2008 | Logitech Cordless Desktop MX3200 Laser...
Reformatting my computer
  • Using System Recovery CDs
  • Change the boot order in the BIOS:-
  • Turn off the computer:
  • Disconnect devices that are connected to USB, Fire wire, parallel and serial ports, except the keyboard, the mouse anb Internet Connection.
  • Turn on the computer.
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.)
  • Wait until the BIOS setup program opens.
  • Press the right arrow key to select Boot.
  • Press the down arrow key to select Boot Device Priority, and then press Enter on the keyboard.
  • Change the first boot device to CD-ROM using one of these methods:
  • Press the down arrow key to select the CD-ROM item. Press the + (plus) key to move the CD-ROM item up until it is the first item in the list.
  • Press the down arrow key to highlight the First Boot Device selection. Press the + (plus) key until CD-ROM is the selection.
  • Start the recovery:-
  • Press the Eject button on the top CD-ROM drive, and wait for the tray to open. Insert the System Recovery CD #1 and close the tray.
  • Press the F10 key to save the changes and exit BIOS.
  • With Yes selected, press Enter.
  • The recovery window automatically starts; wait for the onscreen instructions to display, and then follow the instructions:-
  • Press R, and then press the F key again.
  • Click yes to perform the full system recovery.
  • Insert the remaining CDs when directed.
  • When the recovery program finishes, click Restart to restart the computer.
  • Before the computer restarts, the CD tray ejects. Remove the CD
  • Return the BIOS to the previous setting
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.) Wait until the BIOS setup program opens.
  • Press F5 Key to Set Default Settings in BIOS.
  • Select yes and press Enter.
  • Complete the recovery
  • After the computer restarts, a series of startup screens appear. Complete Microsoft Windows setup as follows:
  • Complete the registration process, and then reconnect the devices that were disconnected earlier.
  • Reinstall software that did not originally come with the computer.
  • Write data files that were previously saved on the backup CD or diskette you made from the hard disk.
Jul 04, 2008 | Computers & Internet
Keyboard never works mouse works fine
have you tried changing the batteries? My mouse has an issue just like that when the batteries get low.
Dec 06, 2007 | Logitech Express (967407-0403)...
26 people viewed this question
Top Seiko Office Equipment & Supplies Experts
Marvin
Marvin
Oloyede Monsuru
Andrew Taylor
Andrew Taylor
Are you a Seiko Office Equipment and Supply Expert? Answer questions, earn points and help others
