Question about Maytag MAV7700 Top Load Washer
Greetings, I Have a maytag cloths washer MAV7700AWW. The drive motor will turn on with no load and loudly hums with no movement with belt on. Ckecked the transmition and water pump - they move freely. Took motor out and found what looks like a capasator mounted near the windings. it's about 1/4 inch thick, rectangular in shape, 1 3/8 inch by 1 inch. It has 2 stabs for staykons on either side of the 1 3/8 inch sides. The number 801 is on the 1/4 inch thickness and obliterated numbers look like 20MA0? on the top. Is this the capasator for the start or is this motor a start winding motor?
  • 641 Answers
SOURCE: Maytag Performa PAV1000AWW top load washer
Try to replace the capacitor. Good luck
Posted on Jul 19, 2007
  • 5 Answers
SOURCE: Maytag Performa PYE2200AYW - not working
Yes there is a fuse in the dryer. The black circular thing is a high limit thermostat. Beneath it is the thermal fuse. It is smaller (dime size) and is mounted to the right side of the heating element housing. It is alittle tough to see and get at. You must use the original Maytag part kit.It comes with a new high limit therm. and fuse.
Posted on Oct 26, 2007
  • 5 Answers
SOURCE: Black mark on clothes after washed in Maytag top load washer.
Check and make sure the seal at the bottom of the washer is not wore out. Alot of times you will get grease from the bearins and drum assembly if this wears out.
Posted on Apr 14, 2008
  • 20 Answers
SOURCE: Maytag washer won't Spin freely
You have a worn brake
Posted on Feb 10, 2009
jumptrout51
  • 3361 Answers
SOURCE: maytag top load washer won't pump water out=intermittent problem
You have a belt driven pump on this machine.
Maytag redesigned the lid switch for this machine because of this problem.
Try a new lid switch first.
It is possible that the problem could originate from the timer. Which would mean a new timer.
I believe the lid switch will correct your problem.
Posted on Mar 10, 2009
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
I have a Kenmore cloths washer, model #110.24642300. The other day it filled up with water and stopped working. If you try to turn it on now, it does not do anything. But you can hear a small hum or...
The belt may be in place but it appears to be loose and slipping. Probably worn out. You hear the hum because the motor is running but the belt will not let it drive. When you have it apart make sure the part the belt is driving turns by hand.
Jun 14, 2017 | Kenmore Washing Machines
I have a 6 yr old maytag top loader washer that does not wash or spin. It filled up with water and then stopped working. The power light is on but it does nothing . Any suggestions?
There is plainly no drive to the drum, it could be a broken drive belt or a dead motor.
Is there any humming from the motor?
If all is silent it could be the motor has died. If there is any sign that the motor is turning, then the drive belt could be gone.
Remove the back and look at the drive.
Alternatively the driver circuit board may need replacement.
Sep 02, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Maytag hav2558aww stopped working. It is full of
Either the fan belt is broken or worn out. Or you need a new motor
Nov 03, 2009 | Maytag HAV2558 Top Load Washer
My wife said the washer made a loud noise and now it doesnt spin or agitate
Check the drive belt from the motor for breakage. Test the driven pulley for relatively free movement. It may also have broken part of the transmission!
Aug 15, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer will not spin. motor overheats and drum won't turn
If it has a belt try loosening the belt and see if the transmission and pump will turn and are not stuck.
If they are they will have to be replaced. Try the motor and see if it turns freely with the belt loose or off. If they all turn freely check motor.
Jun 09, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool Washer LSR7233BQ2 Buzzes/Humms during spin cycle...no movement
No belt on your machine. Sounds like motor coupler that joins motor and transmission is broken. Very inexpensive part but a few steps involved in getting machine disassembled Look up YouTube video on replacing motor coupler on Whirlpool washer.
Sep 26, 2017 | Whirlpool LSR7333 Top Load Washer
Washer fills up, motor hums, but no spin.
sounds like the drive belt is broken these models have pump belt and a drive belt
Oct 16, 2008 | Maytag LAT2300 Top Load Washer
Maytag PAV2300AWW
hi there,
the humming is the motor trying to turn, which means it works. since you did not mention any error messages, it could just be a belt that slipped off the pulley. have you taken it apart yet?
it definitely worth fixing.
Sep 22, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
