Question about LG WM2688HWM TROMM SteamWasher
I just got a tE message on my LG WM2688HNM washer... What does this typically mean..?
  • davidberck Aug 04, 2010
    Helps to ask an expert!
  • 8,197 Answers
The Te code means Broken Thermistor. You need to replace the thermistor. You will need to get a service person out to replace it.
Good Luck
Posted on Aug 04, 2010
    Thank you, how much does the repair typically cost?
Front load washer LG wm2140cw with error code up side down FE. Any ideas what this means? Will start to run then error code shows up and it stops.
A tE error code on the display of the washer indicates a heating error, usually caused by a faulty thermistor.
  1. Unplug the washer from the power outlet for 10 seconds.
  2. Plug the washer back in and press the POWER button and then the SPIN SPEED button until No Spin is selected. Press the START/PAUSE button.
  3. Once the washer has drained, restart the wash cycle.
  4. If the tE error code appears again, close the water taps and unplug the washer. The washer will require repair service.
Apr 06, 2015 | LG Washing Machines
Lg tromm wm2688hnm schematics
yes it sounds like you have somthing in the pump this video will help
Jul 22, 2013 | Washing Machines
My washer has a te error code, lost the owners manual, what does the te code mean and how do we fix it?
It means the THERMISTOR is faulty and most likely needs to be replaced. It's about a 7-10 dollar part, plus shipping. The problem is, you'll need to take the machine apart to replace. The best thing to do, is contact a professional for repairs.
Mar 06, 2011 | LG WM-2277HW Front Load Washer
Getting "te" error message - help!
'te' stands for Temperature Error in most LG washers I suspect; the water is not being heated. Probably the heating element is malfunctioning and it would appear you will need to make a service call ;-0(
Good luck,
John C
Mar 04, 2011 | LG Washing Machines
Te error pops up washer stops clothes still in it already drained filter not that bad
the thermistor is busted te means thermistor error need service technician tough job
Jan 05, 2011 | LG WM-2277HW Front Load Washer
I have a model WM2688HNM LG Washer and have a TE code. I would like to get a repair manual to show me how to open the cabinet to get directly to the thermistor to check for a loose or broken wire.
undo the screws at the back take the lid off then pull out the dispenser draw take two screws out holding front display on then jiggle the display out might be lugs or clips holding it in place as well then take the bottom kick plate off lever it with a flat blade screw driver it just pops off then open door take door lock screws out then take spring off the door gasket then undo the screws on the top & bottom of the front panel then your in
Jan 05, 2011 | Washing Machines
What doea the tE error message mean?
In the manual it does not have a cause... just shut off the power and call for service...
Feb 12, 2010 | LG WM-2277HW Front Load Washer
Drain pump problem and housing removal
Go to appliancepartspros.com or repairclinic.com. Enter your model number. Look thru parts until you find the pump. There you will find a how to video. Pretty easy repair/replace. Good luck.
Apr 28, 2017 | LG WM2688HWM TROMM SteamWasher
TE message. machine turns on but nothing else. I found out the message means a thermastor problem
Perhaps the error is "[-E" and it means the thermistor is out of error. Replacing it will correct the problem
Apr 27, 2009 | LG WM2277H Front Load Washer
Washing Machines Logo
498 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
