When i turn it on at the back the display either doesnt turn on or only some of the leds turn on in no arrangement at all. no sound comes through or anything. it worked when i first got it out of the box but then it stopped working so i turned it off then on again. after i did this it worked fine for about 5min then it went to the problem stated above. its brand new, only opened it today
  • joshmackney Aug 04, 2010
    the item in question is an edifier m2600 5.1 channel sound system, not a barcode scanner
  • 19,396 Answers
Hi.
Check the speakers wiring. If there is a contact in wiring the unit will not start. The description of LED behaviour lets think to a fault condition.
If there is no wiring problem, then the system is faulty. In that case contact Edifier. The system has one year manufacturer warranty.
To contact them ring 1-877-EDIF-IER or send Email to: main@edifier.ca;
Here their website.
Please do not forget to accept the solution.
Regards.
Ginko.
Posted on Aug 04, 2010
    I tried unplugging all the cables and turned it on, it did the same thing as before. I also replaced each cable one at a time to test each one and it got me nowhere. I bought the system online ergo i dont have a receipt or invoice, will this matter?
    Guru:
  • 825 Answers
This is definitely a defective one... pls send the manufacturer of the device...you can take it back to stores...
  • 2 more comments
    sorry, its a 5.1 channel sound system, not quite sure how it ended up listed as a barcode scanner
  • Manikandan Raj Aug 04, 2010
    the power supply adapter might be the problem... try with a similar kind of adapter if you have one to isolate the issue... if there is no issues with the power supply then the circuit switching PCB is not working fine, u can find the PCB inside the woofer...but dont open the woofer, it will void your warranty...
    the power supply is inside the woofer, the plugs or removable leads are for the speakers and sound in. the power cable runs through the box, there is no way to try a different power source. the woofer is getting power, but after that i have no idea
    the transformer that converts the ac to dc is not working properly... it is not recommended to buy an woofer with built in transformer, because it will generate more heat and will not let you use for a long time...the coil burning problems occurs most common in these kinds of speakers...better opt for a creative T6100 5.1 speakers.... best in class and greater clarity in sounds... if you are ready to spend more go for Altec lansing or bose...
My samsung plasma PN60E550 will output sound with no video. How do I know which component has failed?
Its the power supply not to exspensife to fix do you hear a click and the red led display light come on
Sep 03, 2016 | Samsung Pn60e550 60" 1080p Plasma Flat...
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
Can't see picture in TOSHIBA LED TV, but still have sound and can see picture with flash light
try changing the back light inverter that's what light the screen some sets have separate back light inverter while some comes in he power supply...good luck
Apr 03, 2015 | Toshiba Televison & Video
My Sony LCD model no CX52 There r white patches and background images are not visible Screen is full of pathes what to do
The LCD television is a flat-panel television which utilizes a Liquid Crystal Display technology. It has two layers of glass which are polarized and stuck together. The liquid crystals are held in one of the layers. These liquid crystals pass, or block the light, to produce images on the screen when the electric current passes through it.
However, the crystals do not produce their own light. The light comes from the series of fluorescent lamps at the back of the screen. There are millions of shutters arranged in a grid, which open and close to release and trap some of the light that is not needed to create images. Then each shutter is paired with a colored filter which produces a sub-pixel. These are so small, that when they combine, they create a single pixel, which appears to be a single spot of color on the screen. With the help of the fluorescent lamps, the images created by the liquid crystals become visible to the viewer.
LCD television produces high image quality. They can be made very thin, which makes them less space-consuming, and the user can hang them anywhere. This makes them appealing to buyers.
LED TV's are actually very much like LCD TV's. They also have a flat-screen which utilizes Liquid Crystal Display technology. The only difference is their source of light, which is at the back of the screen. The LCD TV uses fluorescent lamps, and the LED TV uses LED (Light Emitting Diodes).
There are two types of LED backlighting. One is referred to as Edge lighting, and the other is called Full-Array lighting. With the Edge lighting, the series of diodes are arranged along the outside edges of the screen. When there is power, the light is distributed across the screen. Alternatively, in Full-Array lighting, there are several rows of diodes behind the entire surface of the screen. They provide more control over brightness and dimming, because the diodes can be turned on and off independently.
LED TV's are LCD TV's with a new backlight system. They are newly developed for LCD's, because Light Emitting Diodes are said to give more balance in color saturation, and use less power than the fluorescent lamps. LED TV's are the newest version, and that's why they are currently more expensive than the standard LCD TV's.
Summary:
LED TV's are still LCD TV's. They are just considered to be the newer LCD TV version because of the new backlight system used. The LED TV uses Light Emitting Diodes, while the standard LCD TV uses fluorescent lamps. Although they both still use Liquid Crystal Display technology. The main difference is the part behind their screen, which is the backlight.
Read more: Difference Between LCD and LED Televisions ' Difference Between ' LCD vs LED Televisions http://www.differencebetween.net/object/difference-between-lcd-and-led-televisions/#ixzz2Bb0rIue6
Nov 08, 2012 | Televison & Video
I have a Brother HL-3040cn printer, led display says "unable to print 1A" how do i clear this? It also says to turn the power off and open the top cover wait 30 minutes then turn it back on. But...
I have a Brother HL-3040cn printer, led display says "unable to print 1A" how do i clear this? It also says to turn the power off and open the top cover wait 30 minutes then turn it back on. But this doesnt work?
Apr 20, 2011 | Brother HL3040CN Laser Printer
No screen or external monitor display when powered up
when i turn my netbook on the lights turn on but the screen doesnt. I figured out that if i leave it running till the battery goes very low it will turn on.
Jul 07, 2010 | ASUS Eee PC 900 Notebook
Laptop won't start.
connect yr system to an external Monitor(CRT) if it comes up then yr problem might be from the inverter,backlight,screen etc.
but if it doesnt come up then yr VGA card may be damaged.
NB:u must be sure ur system is up n working by pressing the caps lock key to check if the caps lock led will light up. if it doesnt lite up then yr system isnt up n running . what yu do at this atage is to replace the ram n or processor then it should display normal.
hope this helps
thank u
May 31, 2008 | Acer Ferrari 3400 Notebook
Clicking sound from VCR area
there is a infra red LED inside the unit that fails. this LED sends infra red signals to 3 other sensors for load and stop and counter. when this LED fails the mechanism thinks you are loading a tape. have a tech replace this LED.
Feb 09, 2008 | Philips Magnavox 20MC4304 20 in....
Computers & Internet Logo
Alun Cox
David Payne
David Payne
