Question about E-Machines T5082 PC Desktop
Trying to upgrade t5082 emachines from 1/2 to to 2g. the only way it will boot is if I leave the 1/2g in slot one & put one of the 2g in slot 2. Is there a way to make slot 1 read the 2g?
  • E-Machines Master
  • 11,800 Answers
Your motherboard has a 1GB limit per slot so the 2 GB sticks are simply not recognized. Take them back and replace them with a 2x1GB set if you still want to upgrade the RAM.
Posted on Aug 04, 2010
Emachines t3516a memory upgrade
The eMachines T3516 uses an Intel D101GGC motherboard,
http://www.ascendtech.us/intel-d101ggc-lga775-800fsb-motherboard_i_mb4intd101ggc.aspx
Two Ram Memory slots.
Maximum Amount for EACH ram memory slot is 1GB.
Maximum TOTAL Amount for the motherboard is 2GB.
Ram Memory used is DDR Sdram at 333MegaHertz, or 400MHz.
That is PC-2700 and PC-3200 respectively.
Uses Non-ECC, low density, Unbuffered, CAS Latency of 2.5, and 2.5 Volt.
Regards,
joecoolvette
Oct 01, 2012 | E-Machines T5082 PC Desktop
Emachines T5082 Adding 512Mb ram. Getting slot 0 installed slot 1 not installed.
Try swapping the memory in the two slots. It sounds like either one of the memory chips is bad or one of the memory slots is bad.
If you find that one of the slots is bad, then you might try just putting a 1GB Chip in the slot that works.
Apr 24, 2012 | E-Machines eMachines Desktop PC
Acer desktp internal ram installation needed
I'm a bit confused....did you have all four of these in the ACER and are trying to put the 2x1GB into the Emachine? And that the 2x1 GB wouldn't work in the Emachine but they did in the ACER and that the 2x512 Acer cards worked in the emachine?
If that is what happened here is my best guess. The ACER MOBO will support 533/667/800 MHZ DDR2 RAM. The Emachine will only support 533 RAM. Iys possible the 2x1GB are either 667 or 800 MHZ and are not compatible with the Emachine but will work in the ACER.
Jan 23, 2012 | E-Machines T5082 PC Desktop
Will pny pc2-5300 work with a emachines t5082
Ships with
512MB DDR2 (1 × 512MB), 533MHz (PC4200)
Expandable to 2GB
2 DDR2 Slots (Total) | 1 DDR2 Slot (Available)
recommend
512MB PC2-4200 M-533D-512BD10
Aug 24, 2010 | E-Machines T5082 PC Desktop
I have an emachines t5082 and tried installing 2GB (2x1GB) they are a 2-pack, DDR2 6400's The board sees 1GB but when I put both in it won't even give me a boot screen or anything, just a black screen. Is...
eMachines recommends DDR2 at 533MHz.
(PC2-4200)
A lot of ram memory manufacturers, state you can use DDR2 at 667MHz. (PC2-5300)
This is a logical statement due to the fact that a lot of motherboard chipsets, (Northbridge chip specifically),
will allow ONE step up in ram memory frequency rate.
You are going Two steps up.
Who told you this would work?
This is erroneous.
(Mean that in a nice sort of way)
PC 6400 is DDR2 at 800MHz.
Your eMachines T5082 motherboard uses an ATI Radeon Xpress 200 motherboard chipset.
This chipset will only support DDR2 at 667MHz at best.
http://en.wikipedia.org/wiki/Xpress_200
Suggest you send that ram back, and get PC2-5300.
Jan 07, 2010 | E-Machines T5082 PC Desktop
I have a eMachines T5082 and have attempted to upgrade the RAM to 2GB (2x1 gb) PC4200. The problem is the computer will read either one or the other of the modules but not both at the same time. Any...
sorry, i re-read your post and saw that you are using 2 sticks,, if you have 4 slots for ram, insert one into the first slow, skip a slot and put the second stick in the 3rd slot, give it a try.
Dec 09, 2009 | E-Machines T5082 PC Desktop
T5082 RAM upgrade
you should always use the same size ram chips, never mix sizes, this can and will cause failures
Jun 11, 2009 | E-Machines T5082 PC Desktop
Dual Channel on an Emachines T5082
Look closely at the BOLD print
Memory Upgrade for eMachines eMachines T5082 Computer, the eMachines eMachines T5082 Computer takes the PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T5082 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for eMachines eMachines T5082 Computer.
Apr 17, 2009 | E-Machines T5082 PC Desktop
Installation windows xp emachine t5082
You must find "eMachine" XP USB drivers for your computer.
If all USB support is "enabled" in BIOS, the conflict is with drivers.
XP is loaded with many generic drivers, however eMachines is proprietary and requires eMachine drivers for most on-board hardware.
Contact eMachines support to locate the drivers (if available).
Thanks for using FixYa - a FixYa rating is appreciated!
Dec 14, 2008 | E-Machines T5082 PC Desktop
I have installed one 1gb chip into my emachines t5082 computer and it worked fine. So I got another and removed the original 512 MB chip from it and it won't recognize the second 1gb chip.
I'm assuming that your 2nd DIMM is the same type and speed as the 1st one you put in. If you are not sure, check and make sure that it is DDR2, 533MHz, PC4200.
If they are not the same, that is most likely the problem.
If both DIMM's are the same, remove them both and then put one of them back into DDR2 Slot 1. Start your computer and see if the computer recognizes the memory. Remove it and try the other DIMM in the same DDR2 Slot 1.
If both work OK, the problem is on your mainboard.
Dec 13, 2008 | E-Machines T5082 PC Desktop
E-Machines T5082 PC Desktop Logo
208 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
