Question about Western Digital Passport 120GB External USB 2.0 Portable WDXML1200UExx Hard Drive
My Western Digital USB 160 GB HDD when connected to my PC shows it detected external hdd but the disk is not displaying in MY Computer. I hope there is no problem with the USB port as my printer is working fine. Since all my data is saved in this HDD now I am helpless without my HDD. Kindly help me in this regard and thanking you in advance. Rajesh K
  • 11,800 Answers
In that case it's most likely that the hard disk inside has died. Last hope attempt: take it out of the case and plug it in directly to the motherboard. If even then it's not recognized then it's truly dead and all your data has been lost.
Posted on Aug 04, 2010
  • DanTheGeezer Sep 05, 2010
    Another possibility. Try all USB ports on the computer. If you have a firewire port, try it by using a USB/firewire conversion cable. There are also serial/USB conversion cables, if you'd like to try that.
    I finally got my WD1600 passport to work on my desktop machine by trying different USB ports. One worked!
External Hard Disk
1. External powering try changing the adaptor 2. Powered by USB try changing the USB cable 3. Try connecting to other computer 4. Check for any specific error displayed by Mac or ur PC 5. Try changing the disk name assigned to ur external HDD using disk management in PC 6. Hardware problem if under guarantee get it changed else go for data back up and solve if any bad sectors have come up in the HDD 7. You can check for software a that try to repair bad sectors in a HDD but it takes lot of patience for the same
Jan 01, 2014 | Western Digital Computers & Internet
Western digital wd1600 external hard drive
are you u using SATA to usb connector?? and when you plug in then system detecting the hard drive?? if yes then you should go to computer property click on manage the go to disc drive option you will see your connected hard drives. if your required HDD is showing the right click on western HDD and mount it all portion. hope it will work.
Dec 11, 2013 | Western Digital Passport Computers &...
Shows up as "Initio Combo Device Class" not a "Disk Drive"
RESOLVED the ISSUE...!!
Hi, Yesterday I get into similar problem of having my USB Drive ( WD passport Elite 320gb ) not being detected by my PC and as soon as I connect to it, Initio Combo device class drivers gets loaded and Drive do not show up in the device list...!!
I tried several options.1. Freezed my hard drive for 12 hrs in the freezer. It did not help me today.2. I have opened the USB drive shell ( becareful, I have damaged it.. see the instructions before you try t ). You can find the 2.5' HDD inside and there will be SATA to USB bridge adapter. I was having doubt on this bridge unit as I read through several blogs.3. luckily I have a unused 2.5' Laptop HDD. So I have removed this bridge unit carefully and tried to connect to my HDD. If the bridge is good, my HDD must be detected right away..But it is the same problem.. It did not work.. Hence I have confirmed that it is the bridge problem..
4. I bought a Rs. 250/- ( 5$ ) 2.5 SATA casing that is available in the market to use the 2.5' SATA HDD through USB. ( actually I do not know where I can buy only the bridge..hence bought the entire unit..which is still cheaper )
5. From the new unit, I have the USB to SATA bridge, which I have connected to my WD HDD SATA USB hard drive... Bingo.........It is detected by OS and I have started copying my important data immediately...
6. This Unit comes with a casing ..hence you may continue using this case... But some units may not fit well..still the bridge is usable..!!
I GOT all my data..with just Rs.250/- ( $5 ) ..I am happy to try this on my own..!!
Good luck with your drive..!!
Jan 01, 2012 | Western Digital My Book Essential 500GB...
WESTERN DIGITAL WBDAAR3200ABK-00 EXTERNAL HDD NOT WORKING
Every time windows tells you to format the drive, copy your data to your computer then format it. when windows detect problems on the drive, it will launch ckdsk, well i dont know hoy to fix it, try plugging it in then reboot.
May 02, 2010 | Western Digital Elements powered by WD 320...
My western digital Passport 320Gb usb drive is not detected
hi ,
looks like u primary hard drive is inside the laptop and so should be displayed as c : drive ,
and the reason , the external hard drive is not displayed seperately is csue ., the external HD  may be added as slave to the internal HD .,
can u tell me ,make a right click on c:/ drive and choose properties : and tell the totalsize dispalyed
Jul 23, 2009 | Western Digital Passport WDXML800UE...
I formatted the drive and erased all content now i dont have the start up software for it to run when i plug it in
My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
What is the problem? & what to do to get back my necessary files stored in the 500 GB HDD.
Can any one help me, please? URGENT.My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
Jun 27, 2009 | Western Digital 320GB MyBook External USB...
Western Digital External HDD not appearing in My Computer
It could be that the OS is not assigning a drive letter to your removable drive. To do this, go to disk management and assign one.
Assuming OS is Win 2000/XP/Vista
Right-click My Computer then Manage
Click on Disk Management
Right-click the removable drive and click on Change Drive Letter
Assign a drive letter and click OK
Your drive should now show up on My Computer
Hope this helps.
Jun 20, 2009 | Western Digital Passport 320GB External...
New external harddisk cant be detected on my computer
Since you have not given any specifications about model of your HDD hence I'd consider your HDD connects through USB. Your USB driver is old you shall consider upgradation.
Jun 15, 2009 | Western Digital My Book Essential Edition...
External hdd not detected in my computer but is in device manager
You probably still need to partition it, before you can even format it.
Try the disk manager in Windows.
In the start menu, right-click "My Computer" and in the popup menu, select "Manage".
One computer management comes up, select disk management and there you should see the disk. You can then create a partition and format it.
Jules
Mar 01, 2009 | Western Digital Passport WDXML800UE...
My external hard disc is not detected by pc and some strange tick
This is never a good sign!! Hard drives only 'tick' when they are bad, or going bad. Some popular techniques for attempting to temporarily fix the drive include freezing it for several hours before trying again, standing the drive on it's thin edge, or lightly tapping it with a SMALL hammer or the **** end of a screwdriver as you power it on. Some have also had success (myself included) removing the controller circuit board and replacing it with the controller of an identical drive, preferably from a drive from the same lot as your broken drive. However I don't recommend this to most people, it is an advanced technique and easy to screw up! Also not likely the problem if the drive is clicking.
If you can get it to work again this way, copy your data from it IMMEDIATELY then recycle the drive and never use it again!
A final option would be to send the drive to a data recovery specialist, but be forewarned this can be VERY expensive.
Nov 21, 2008 | Western Digital 320GB MyBook External USB...
Computers & Internet Logo
149 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
