Check the HEADLAMP relay in the under fuse / relay box . Plus the high / low beam relay . same location . If those are good can you check B+ voltage an grounds using a DVOM - digital volt ohm meter ? Do you know what a wiring diagram is ? How to read one ? It's always a good idea to do testing of the electrical circuits before replacing parts . A lot of good videos on youtube for learning how to test electrical systems on automobiles .
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
Electric Testing Techniques You Need to Know
How to Use Multimeter to Troubleshoot Common Problems
You can find free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model an engine size . Under system click on lighting , under subsystem click on headlamps . Then click the search button ,then each blue link one at a time .
SOURCE: 1993 seville automatic transmission V8 4.9 liter?
neither the 93 seville is just that it's the 4.9 liter before the northstar sts 4.6 came out in same year
SOURCE: 2003 Seville STS low beam headlights don't work
ya its is prolly the bulbs, open your hood. look behind your headlamps, some have covers for the low beam and high beam. if there are covers turn on your high beams so you will know which bulb is your lowbeam. if you can unplug them. after cover is removed and you can acces the bulbs. they either twist out, lefty lossey. or they have little metal retainers that you have to move a certian way before you can swing the retainer out. its like a door you just have to unhook the proper side of retainer and the other side will be hinged. use a flash light and look at it close. good luck
SOURCE: headlights won't work Chevy K-10 Pickup
With electrical problems I always look for a bad ground wire, especially on older vehicles. Look for any wire that goes to an inner fender or the engine, there maybe a faulty relay in the circuit too. good luck, Chuck
SOURCE: Jeep Headlights not working. High beam works
had the same problem on my 92....check under the hood on the drivers side,towards the front,there is a "junction box" with all of the lighting wires connecting from the switches to the lights.My wires were all corroded inside,so I cleaned the ends and bought a new box from the local electronic supply store.The problem has not come back.
Cheers
SOURCE: 1999 cadillac seville sls it over heats when in drive
how many miles are on it? if you have over 70k the head bolts may have let loose and allowed the head gaskets to leak they all do it
