Question about HP LaserJet 4350 Printer
Paper jams I have an HP Laserjet 4 (not 4-plus). The paper jams - won't go through the top outlet unless I roll the guides with my thumbs - and half the time the bottom of the paper is bent and hardened into a wavy, non-flat shape. I have cleaned all the rubber surfaces I could find with denatured alcohol - but that didn't help very much. Can anyone tell me how to fix it or clean it? Thanks.
  • Anonymous May 12, 2008
    my laserjet 4350 keeps indicating paper jam.I have disassembled it and i found no paper
  • 435 Answers
Please visit the mentioned link to fix your problem:
HP LaserJet 4350 paper jam
Thank You
Posted on Oct 20, 2008
  • 186 Answers
Call HP. I think you can order a new roller kit pretty cheap.
Posted on Apr 26, 2008
HP Laserjet 4plus chewing us paper
This is most likely cased by a dirty paper feed path so it will need cleaning and blowing out. Make sure that all the internal paper guides and separators are free of obstruction. Make sure that the fuser area is clean that the internal paper guides are ll in place and operate freely. Also clean it with a vacuum with a soft haired brush tool to avoid any damage. Also fan the paper before using it and do not overload the print paper tray. Also check that the pick up rollers are not work or contaminated with dirt / debris etc. Also make sure that the print tray is not overloaded and make sure that the paper is not to tightly held by the tray side guide.
Sep 30, 2009 | HP LaserJet 4 plus Printer
Documnet feeder jam
Check input paper feeder at top too - easy to miss. Top flips open with a firm (but not excessive) pull, so you can look there.
If you are sure you've opened and looked under every available panel on the printer (there are many!), turn it off and unplug for half a minute. Make sure all panels are back properly in place, but leave out the paper tray (and no paper either in the rear input paper feeder).
Plug in and turn on. Wait for it to finish its start-up sequence - it should complain about no paper.
Check the paper is flat and straight in the paper tray, and no excess room between paper and guides, and put it in again.
Print test page.
How is it now?
Sep 15, 2009 | HP LaserJet 3055 All-In-One Printer
Paper Jam
maybe there is more than 1 piece of paper jamed
Jun 29, 2009 | HP LaserJet 4 plus Printer
IN my office I have HP Laser Jet 1020 plus, A4 paper got jam
you need to deassembly the printer by removing back screws adnd open cover to access fuser unit.
Jun 26, 2009 | HP LaserJet 1020 Printer
Re HP Laserjet 4P after inserting envelope to print, upon giving PRINT command, printer will not print and indicates PAPER JAM. However, there is no real paper jam. No problem printing regular 8 1/2 x 11...
Most likely a bad pick up roller these machines will give a jam error if the paper or envelope is not picked up. Try cleaning the roll for the tray you are having the trouble with if the condition improves you have found the problem.
Hope this helps
Apr 19, 2009 | HP LaserJet 4 plus Printer
Paper jam with card stock paper
Try Getting a PM kit to replace all the rollers.
Nov 13, 2008 | HP LaserJet 2550Ln Printer
HP LaserJet 4 plus
I am assuming that you have an jammed paper in the back door or an accordion jam in which the paper is all folded up or crinkled. if that is the case the printer needs the output assm replaced (hp part number rg5-0886). which is pretty simple take out screws for top cover remove top cover at rear of machine once cover is off there are two taabs holding assm in place depress tabs rotate assm slighlty and lift out of place reverse process to reinstall takes less than 5 minutes to complete.
Sep 29, 2008 | HP LaserJet 4 plus Printer
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
HP Laserjet 4 Plus
Did you check to see if any foreign objects are in where the paper goes, I used to get that with my canon printer and I thought it was broken then I found a little rolled up hershey kiss wrapper down there when I put my hand in
check the instructions , check the computer to find the printer problems or to use HP tech support chat to find the problem becasue your printer is from HP good luck if it is defective or problem then replace new one for if under warrantly ok
Probably the wrong paper - try a different weight, less than the one that is jamming. And do not use a cheap paper, it is not worth it - it shoals off a lot of paper dust which will also cause a jam on your machine. (And make you sneeze!).
May be somthing is obstructing the paer sensor.
Check this site for clear cut information to resolve this issue.
Oct 15, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 4350 Printer Logo
184 people viewed this question
Ben Johnson
