Question about SkyScan 86709 Atomic Wall Clock
433.92mhz. Remote transmitter got rained on. Tried drying it over a week, no good. Anyone repair these? Robert J. Hardy 5200 Chiricahua Trail Las Cruces, N.M. 88012 575 382 0911 home and fax K2IGW@Q.COM E mail address Thank you. Bob Hardy
    President:
  • 2,761 Answers
Actually they're not worth repairing -- because you can purchase a new one for $12.50, including shipping. Follow this link to order:
http://skyscan.info/content/parts.html
Bill B
Posted on Aug 04, 2010
Hi, my reverse sensor beeps randomly when no obstruction and in reverse after there has been rain. Do you know why as it is fine when the weather is dry. Thanks.
Well the best suggestion i could give is if your handy with tools pop them out clean the lens well and the connectors, apply electrical grease to the contacts that should help from water interference if that doesn't help its possible they are slowly going out, there are aftermarket backup sensors that are hardy and easy to install and not as costly as the oem parts good luck
Jun 14, 2017 | Cars & Trucks
Dodge w150 windsheild leaks water in heavy rain.while driving,the headlights, dashlights, rear lights and I'm assuming the ignition went out.it drove to my destination but when I shut it off and tried to...
Maybe. You should get a new windshield or at least have that one repaired by a glass shop. They can come to you. Once the windshield is repaired, let everything dry out real good and hope for the best.
Dec 06, 2014 | Cars & Trucks
Floor board stays wet losing coolant regularly evn when it hasn't rained inover a week or two just the floor carpet upper portions are dry
You have a leaking heater , hose es or tap. That is why you are loosing coolant. FInd the leak by using a radiator pressure tester and replace /repair unit.
Feb 11, 2013 | 2005 Hyundai Santa Fe
Canon iP 5200 orange light flashing 5 times
Hi
IO have one of these printers as my daily workhorse. Thankfully I haven't had the problem you are having.
Did you remove the print-head from the printer and clean it with running warm water?
When I get a possible print-head problem I always do that, rinse it until the water runs clean. Then dry it on kitchen roll making sure that the contact on the back are completely dry before refitting it to the printer. Generally this has cleared any problems (I have several Canon printers - I'm not just referring to the 5200 now).
However If you still get the error it may be worth contacting your nearest Canon service centre. New print-heads are not exactly cheap but these printers are so good it's worth keeping it going. They will probably be able to diagnose the problem quickly and accurately and tell you if it is cost-effective to repair. I don't know what would be involved with the Eprom error. - probably a circuit board change inside the printer.
Dec 22, 2009 | Canon Office Equipment & Supplies
My remote start is going off on its own, what
the control box got wet take it out and dry it. dry with a blower drier make it dry good then put it back.
Jul 24, 2009 | 2000 Nissan Pathfinder
Replaced battery in remote even though old battery still had 3 volts,tried to initialze per instructions and still won't unlock door.get no chime when programming, just run out of time.2001 chevy impala
• Resynchronization may be necessary due to the security method used by the remote keyless entry system. Resynchronization may be necessary due to the security method used by the remote keyless entry system.
The transmitter does not send the same signal twice to the remote control door lock receiver (RCDLR). • The RCDLR will not respond to a signal that has been sent previously. This prevents anyone from recording and playing back the signal from the transmitter. • Resynchronization may be necessary under the following conditions: - The battery in the transmitter is very weak. - The battery in the transmitter was replaced. - The battery in the vehicle has been in a low or no charge condition for an extended period of time. • In order to resynchronize the transmitter with the RCDLR, perform the following steps: 1. Stand within 1.5 m (5 ft) from the vehicle. 2. Simultaneously press and hold the LOCK and UNLOCK buttons on the transmitter for 7 seconds
Jun 25, 2009 | Chevrolet Impala Cars & Trucks
2006 NISSAN NAVARA 4.0 4X4 NOT STARTING
When engine wiring gets wet it won't start. I had an old Mustang that I had to remove the distributor cap and dry it with a hair dryer every time it rained real hard. I am thinking it will start after enough time has gone by-I had a car get flooded twice, and first time it took 3 weeks before it would start.
Aug 28, 2008 | 2006 Nissan Titan
Voice problem with nokia 5200
you need to take the phone and have the microphone replaced and also seeing that the phone may have water damaged you need to also have it cleaned and service properly so take it to a mobile repair center and ahve that done.
Aug 11, 2008 | Nokia 5200 Cellular Phone
SkyScan 86709 Atomic Wall Clock Logo
277 people viewed this question
Top SkyScan Home Experts
nejones57
nejones57
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
