Question about Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F
My compressor runs for five seconds and then stops.Then starts back up 5 mins later.The temp is about 65 degs
  • joedodgeram Aug 04, 2010
    This is the modle LFFH2067DW1
    My freezor door was left open over night and now it not cooling.The compressor runs about 6 second every ten minutes and never get cold
    Genius:
  • 1,035 Answers
Hi. You might have a bad compressor relay. try changing the compressor relay. If same thing happens after chaning the relay then this might be a compressor problem.
All the best!
Posted on Aug 04, 2010
  • Angelito Rabago
    Angelito Rabago Aug 04, 2010
    Try this troubleshooting before your change the relay.
    Turn off the frig for at least 24 hours to allow the excessive ice build up on the evaporator coil to melt. It's blocking the airflow to the refrigerator section. The motor or compressor isn't bad if it's blowing cold air. Leaving the door open just caused the coil to accumulate too much ice.
    If that doesn't work, there is an outside chance that the defrost timer is bad or the defrost drain is clogged up.
    Guru:
  • 1,524 Answers
This indicates a possible bad relay. Pick up a replacement at local parts store or call 1-800-673-1262
GDM12 reach-in just cycle clicks when plugged in - not cooling
Clicking like this is usually a problem with the compressor start device. They are prone to failing and the overload protector is cycling to hopefully protect the compressor from burning out. If the start device is a solid state device if you remove it from the compressor it should not rattle. If it does it is bad and will need to be replaced. Installing a new strat device should get it back up and running.
Apr 09, 2014 | True Gdm12 Refrigerator Glass Door 12 Cu....
Kenmore 7.5 freezer stopped working.
Thanks for all the suggestions. I just replaced the overload relay and it does the same thing. Runs for a few seconds and the loud click from overload relay. I did notice the relay is really hot to the touch, if that matters.Coils on back are clean. I had noticed the last few months that the inside coils were frosting up quite a bit.Really had hoped it was the relay.
Dec 04, 2012 | Kenmore 7.5 cu. ft. / 212 liter Upright...
Miele F7131 S The red alarm and the orange -32 degrees orange light on the front of my under counter freezer keep flashing. I have defrosted it. It appears cold but the lights will not stop flashing.
Freezer Temp. shoud be 0 to -5 Deg. if to warm it will set off the alarm. try unpluging or turn off power to freezer for 1 or 2 min. to see if it will reset.
May 17, 2010 | Freezers
Compressor start for a few second and cut off and start again. whats wrong . berverage-air freezzer single door model no. ef24-1as
dirty condencer coils bad fan motor or compressor start relay on the side of compressor or turned off then back on without waiting 5 min.
Dec 09, 2009 | Beverage-Air Freezers
We lost power due to storm since restored and now the compressor starts but stops within 30 seconds and does this over and over
It sound like your compressor is in trouble, I would try and see what amp. the compressor is running in this 30 seconds. If it is over the name plate requirement I would try to change a 3 in 1 electrical component to see wheather it helps. Check your amp. at all time.Hope this help.God Bless
Jun 25, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Compressor starts then stops after 5 seconds
Installed hard start Kit for this little freezer. No help. Needs new compressor.
May 28, 2009 | Freezers
Frigidaire Chest 5 cu ft Making Fan noise & will not turn on...6 yrs old.
at 6 years old it certainly aint new!
from what you describe, sounds like a compressor fault
Oct 09, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F Logo
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
