Question about Whirlpool Duet GHW9150P Front Load Washer
When you turn on washer it says f13 - Whirlpool Duet GHW9150P Front Load Washer
  • wwchiefdavid Aug 04, 2010
    when you start it says f13
  • 6,784 Answers
HI. This code is in reference to the dispenser circuit. If the dispenser motor is not able to be driven to it’s proper position, the F-13 code will appear. The necessary actions are to Check the mechanical linkage from the dispenser motor to the top of the dispenser assembly. You will also need to inspect the wire Harness connections to the dispenser motor and Central Control Unit (CCU). Make sure that these connections are tight and secure. The last area of concern will be to check the motor that is located and mounted on the dispenser assembly. The possible culprit will usually be a failed motor, but you will need to inspect all that I have stated to isolate the motor. Make sure that the linkages are ok and the wire harness is securely connected to their respective connection points.
Here is a link to the service manual for this unit. This manual will guide you through the disassembling process and it will have a proper testing chart for the dispenser motor circuit, as well. I would suggest to read the dispenser details at the bottom of page 3-1. The title will be "Dispenser Distribution System". This will familiarize you with the dispecner assembly and its parts. Read the entire summary before starting your inspection procedure and repair. The summary will end on page 3-2. The dispecer can be easily accessed y removing the top. The top removal procedure will start at the top page 4-2.
Posted on Aug 04, 2010
  • Michael Masters
    Michael Masters Aug 04, 2010
    NOTE_ There is a great picture and testing information on page 5-5 of the service manual, as well. It is placed below the line filter testing point and picture. The switch circuit will be the proper testing point to verify motor functions. If the motor switch blue wire leads do not test as stated(1400ohms), it must be replaced(motor and switch assembly). Now; If the the motor/switch test proves it is indeed functioning as designed, there may be some linkage issues with the cam or cam followers.
F13 fault showing on my Ariston margarita 2000 awd12 washer dryer and the control Knob keeps continuing to turn endlessly. What could be the problem. Yours desperately John Russell
From memory I think this is a dryer temp. sensor error. Check youtube out with query; "Wash Machine F13 error code". A company in England, eSpares, posts a few vids to help. I've bought a few things from them, very helpful and good prices. I have no connection with eSpares, accept an occasional customer. If you can do it yourself it is a quick, inexpensive fix. Good luck.
H
Apr 03, 2016 | Washing Machines
F13 and F11 codes pop up
F13 is
Dispenser Circuit Error
If the dispenser motor is not able to be driven to it's proper position.
Check mechanical linkage from dispenser motor to the top of the dispenser
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
i snagged this answer from another site
i think its a worn bit of plastic
as it becomes britten when not always wet
much like a boat out of water
Mar 05, 2015 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Error code F13 Bauknecht washer front loading
error codes washer machine bauknecht f13
Nov 15, 2011 | Washing Machines
F13 error code on Ariston washer dryer combo
Model ARMF 125 with same error code F13 how to fix please advise Thks
Nov 06, 2011 | Hotpoint-Ariston ARWDF129NA Washer
It appears F13 error
hi sir we have ARISTON washer and DRYER model : AQXXMD129EX its a error coming F13 please help me soon
Dec 21, 2010 | Ariston Technologies AWD120 13 lb. Washer...
La lavatrice mi segna errore F13 che devo fare?
ANCHE A ME SEGNA F13 E L'OBLO NON SI APRE E I MIEI VESTITI STANNO MARCENDO DA 3 GIORNI E NESSUNO VIENE AD AGGIUSTARLA.....SAPETE E' IN GARANZIA......
Jun 25, 2010 | Whirlpool AWT5108 Top Load Washer
My AWOE8748 had a fault code F13. It has now switched itself completely off.
F13 indicates "Dispenser Circuit Error" in your washer.If the dispenser motor is not able to be driven to it's proper position this error code appears.Check mechanical linkage from dispenser motor to the top of the dispenser. The wire harness connections to the dispenser motor and Central Control Unit (CCU) would have been faulty so check for those.Also do a final check on dispenser motor.
Thank you !!
Jun 20, 2010 | Whirlpool AWOE8748 Front Load Washer
My whirlpool washing machine keeps saying f13 whats wrong and how do i fix it
Hello, the F13 means "Dispenser Circuit Error", if the dispenser motor is not able to be driven to its proper position.
Check the following:
1. Check mechanical linkage from dispenser motor to the top of the dispenser.
2. Check wire harness connection to the dispenser motor and Central Control Unit and lastly
3. Check dispenser motor.
Thanks
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fault f13
Hi. F13 indicates dryer fan motor or thermistor problem
If you can't hear the fan motor running on the dry cycle then it is probably faulty.
Hope this helps.
Please feedback.
Thanks
Nov 13, 2008 | Hotpoint Aquarius WD640 Front Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
197 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
