Question about Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F
Frigidaire Freezer Model LFFH2067DW1 The compressor comes on for five seconds at a time every 1o minutes.The temp is about 65deg.The compressor is good I put starter box on it and it ran ok.
  • Frigidaire Master
  • 2,005 Answers
You have a low refrigerant charge have the unit recharged
Posted on Aug 04, 2010
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
Ok, upright freezer, frigidaire, read -12 after power outage but working ok..when I tried to reset temp to 0, light went off, freezer went off, front display reads 56..any ideas?
Thank you for your post, Cynthia!
Based off the information you have provided your Frigidaire freezer is not cooling properly and is now displaying the temperature of 56. It sounds like your freezer is not on, even though it has power the compressor is not turned on. I would suggest pressing either the down or up arrow three times within five seconds. That should power on your compressor and it should start cooling properly. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Feb 28, 2015 | Frigidaire Freezers
Error code 0F
Good Morning Stephanie Garcia, thank you for your post!
From the information you have provided your Frigidaire freezer is displaying an error code of "OF". Typically, an "OF" stands for power off, you should be able to press the up arrow three times in a row within five seconds to turn your freezer back on. If that does not help correct your issue you may want to perform a reset and you can do that by unplugging the power cord for roughly ten minutes. I hope this helps. -Matt
Jan 17, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My Frigidaire commercial freezer model LFFH2067DW1 makes a loud, almost rhythmic, knocking sound. What can that mean?
Could be a compressor on its way out, a warped or clogged fan could cause similar sound issues, the valve plates in the compressor could be worn causing pressures issues.
Nov 15, 2014 | Frigidaire Freezers
Lost manual for my Fridgeidare upright freezer 20.5 with the controls on outside. what does 0F mean. and if I need to set it ,we just moved how do I set it?
Hey friend, thanks for your post!
From my understanding you have recently moved your Frigidaire freezer and it is now displaying the "OF". Normally, that stands for off you should be able to press the "Up" or "Down" arrow three times within five seconds to start your compressor. If you still need a copy of your manual could you provide me with your model number? You can locate your serial tag (which lists your model number) on the inside wall of your freezer. I hope this has been helpful. -Matt
Oct 11, 2014 | Frigidaire FKFH21F7HW 20.5 Cu. Ft. Upright...
I have a Frigidaire freezer LFFU1424DW not freezing. Came home to melting ice and thawed food. I heard clicking noise like a fan but goes off after a few seconds. Help please.
first of all unplug that freezer and wait for 15 mins. move it five feet from the wall. after 15mins, plug it back and kick in compressor at the same time!!!! remember plug and kick at the same time. the ckicking noise come from the starting relais. this says that the compressor has a problem. If it doesn't work ; you will have to call a service person who will replace the compressor for you.
Mar 10, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer defrost cycle
If the defrost timer sticks in the defrost mode,yes. Normal defrost time is 30 minutes or less depending upon which timer is installed.
If it happens again,locate the defrost timer and turn the dial manually to see if the compressor comes back on. If so,replace the timer.
It is probably on the rear near the compressor. Some are under the front behind the dust guard.
Feb 24, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
Frigidaire 20.3 cu. ft. Upright Freezer GLFU2067F Logo
439 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
