Question about E-Machines eMachines Desktop PC
Had very bad storm and my e-machines desktop started making loud buzzing noise. I tried to turn it off but it would not power down by button so I unplugged it. Now I can not get it to come back on at all! No power no nothing! What is the problem?
  • 146 Answers
You may need a new power supply....also check your internal fans to make sure they are spinning. Make sure memory is seated properly. Motherboard may also be in question. Try unplugging letting it sit for a few then plugging back in.
Posted on Aug 06, 2010
Freezer making loud buzzing noise when turned on. We had storm and lost power sounds like its coming from on and off switch
the power grid may not be up to full power
happens after a power up every electric unit left on in the grid
on a storm all kick in in a massive load
turn off at the wall
unplug
plug back in
see if compressor startup again
Oct 15, 2016 | Refrigerators
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Apr 20, 2014 | Sewing Machines
E had a power outage due to a storm blowing trees down on power lines. When the power returned, about 4 hour later, the refrigerator/freezer (side by side) was making a loud buzzing noise. The ice maker is...
This sounds to me like a busted compressor, nothing more you can do to it. You must call a repairman to test it and replace it, a very delicate procedure that requires specialized equipment.
Jun 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
Drum will not turn and there is no heat.
This dryer has a circuit board that controls virtually everything. If it makes a buzzing noise when you press the power button to turn on the control panel, it's probably not going to be an easy fix. When you hire a professional, you avoid buying expensive parts that you might not need, such as a control board. If it makes a loud buzzing noise when you press the start button, it's possible that it could be a motor or belt problem. But again, I'd recommend a service call for this one.
May 25, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer has started to make a loud sqealing when it starts and gets up to speed, the kind of sound a loose fan belt makes on a car, and now just makes a buzzing sound when the button is pushed but dosen't...
If you push the start button and you here a buzzing sound, This sounds like the motor is bad.
Somthing you can try and this might not work. but open the dryer door and turn the drum a littel bit then close the door and try to start it. If it starts running again then you have hit a bad spot on the motor.
If it just still just makes the buzzing noise then the motor is most likley bad.
Jan 15, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
E-Machines eMachines Desktop PC Logo
64 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
