How can I replace the left touchpad button in a Dell Inspiron 6000? it's stuck inside the touchpad and doesn't work properly.
  • 734 Answers
Hi There,
I'm a pro laptop rebuilder and I've dealt with this exact problem with both Inspiron 6000s and 640Ms many times. You'd think that it would be something easy to do when you see the button sitting right there on top near the front edge but, believe me, it's one of the trickiest and time consuming repairs you can possibly do on a Dell Laptop. I will now only perform it on machines I have bought speculatively for resale because it costs the customer too much to repair.
But, what's not all that difficult at all is to replace the entire palmrest/touchpad assembly. Here is the link to the Service Guide for your laptop. Look it over and see if you think you can do the replacement. If you feel comfortable with it, go to eBay and type in "Inspiron 6000 Palmrest" in the search window. I just checked and you've got 60 choices there of used and new ones.
Here's your Service Manual Link:
http://support.dell.com/support/edocs/systems/ins6000/en/sm/index.htm
If you think you need to have a laptop guy do it for you, at least you know what he should do and can provide the part, although he may want to help you with the selection, deciding what grade of used or whether to choose new.
Best Wishes
Posted on Aug 04, 2010
Touchpad and buttons do not work
Press and hold the Fn key and then hit F3 key.
Press and hold the Fn key and then hit F6 key.
Install touchpad drivers from dell website.
Jul 10, 2013 | Dell Inspiron N4010 Notebook
Dell touch pad not working
The touchpad on a Dell laptop is usually located under the keyboard. Moving the finger on the pad moves the pointer on the screen. The buttons near the pad act as a right and left click. Windows includes a method to troubleshoot the touchpad. In addition, if the touchpad is still giving you issues, Dell recommends draining the "flea" power the standby power from the computer to restart it. Both methods are simple and only take a few minutes.
Open the control panel from the Start menu. Click on "Mouse." This will open a window with several tabs. On the first tab, click the touchpad to open a new window to change the settings for your touchpad. You can customize the settings to how you want your touchpad to work. If this does not solve your issue, proceed to the next step. Click the Hardware tab on the screen that pops up. Select the Dell Touchpad and click "Troubleshoot." A new window will open with the Windows Help and Support Center to bring you through methods for troubleshooting the touchpad. Follow the methods described until your touchpad is working properly. Drain flea power Shut down the laptop and disconnect all external devices, such as a thumb drive, headphones and the AC adapter power cable from the system. Take the battery out of the laptop. Hold down the power button for at least 5 seconds without releasing it. Return the battery back to the laptop. Power the system on. If your touchpad still is not working properly, call Dell for customer support.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=59EB83ED2E4B1243E040AE0AB7E1468E&doclang=en b> Dell Inspiron 1525 Touchpad That Is Not Working
Turn your Inspiron 1525 off and remove any power cables that are connected to the device. Close the computer, turn it over and slide the battery lock button down to release the rectangular battery from its compartment on the underside of the computer. Turn your laptop right-side up and open the computer so the monitor is facing you. Insert the tip of your flat-head screwdriver in the seam between the plastic keyboard guard and the side of the computer. The keyboard guard is located just above the keyboard. Pry up on the guard until it pops out of place. Be sure to do this gently, as you do not want to damage the guard. Remove the guard from the computer and set it aside. The two keyboard screws will now be visible underneath where the guard used to sit. Use your Phillips screwdriver to remove the two keyboard screws and use the tips of your fingers to lift the keyboard up from the top. Place the keyboard facedown over the touchpad and locate the thick connector ribbon that runs from the motherboard inside the computer to the back of the keyboard. Use your fingers to gently unplug the ribbon from the back of the keyboard and set it aside. Insert the tip of your screwdriver in the seam at the bottom of where the keyboard used to rest and gently pry it up. This will release the top plastic frame from the Inspiron, revealing all of the broken touchpad. Use your fingers to disconnect the thick ribbon from the side of the damaged touchpad and slide the touchpad out of the Inspiron. Slide the new Touchpad (available from your Dell retailer or online) in its place, fit the top frame in place and reassemble the computer in the reverse order you took it apart in.
http://www.insidemylaptop.com/replace-damaged-keyboard-dell-inspiron-1525-laptop/ Replace keyboard in dell inspiron
Feb 01, 2013 | Dell Inspiron 15 (N5050)
Mouse doesn't work properly
That's it. There's nothing else.
The problem is with the motherboard and not the touchpad component.
The only thing you could try is updating the bios but it's a long shoot.
Sorry to give you bad news, but it is what it is.
Mar 10, 2009 | Dell Inspiron 6000 Notebook
Touchpad
Please install touch pad drivers from www.support.dell.com by entering the service tag... that shouls automatically enable the touch pad.
Sep 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Alps Touchpad not working
Try unistalling the touchpad driver, and reboot. The machine will find the touchpad and reinstall the driver automatically. These have a tenancy to glitch when using an external mouse, and this should clear it up. Let me know.
Aug 28, 2008 | Computers & Internet
Computers & Internet Logo
155 people viewed this question
Alun Cox
David Payne
David Payne
