Paper jam cannot clear - Office Equipment & Supplies
  • 12 more comments
  • Anonymous Apr 30, 2008
    Portion of paper jammed and can't remove.
  • JOEYA1223 May 08, 2008
    NO PAPER JAM BUT ALARM STUCK ON, NO RECIEVING OR BROADCASTING
  • DTL Alan May 13, 2008
    Paper Jam alarm stays on. No paper appears to be jammed anywhere.
  • Xavon Jun 05, 2008
    I've got a similar problem. The machine starts to be "printing" but immediately falls to paper jam. I open the machine, release the paper, close the machine again but next paper does the same. It keeps repeating. Any suggestion? If you have an answer or a solution, please don't hesitate to write to mirein@seznam.cz. Many thanks
  • Anonymous Jun 17, 2008
    paper jammed says on and no paper is in it.
  • Anonymous Jul 11, 2008
    paper jam will not clear. had a paper jam and all paper removed that we can tell. ??????not sure what to do?????
  • skatom Jul 28, 2008
    The machine starts to be "printing" but immediately falls to paper jam. I open the machine, release the paper, close the machine again but next paper does the same. It keeps repeating. Any suggestion? If you have an answer or a solution, please don't hesitate to write to skatom@hotmail.com Many thanks
  • MuffinTopz Sep 22, 2008
    I have a 1240 Fax Machine, and I just accidentally the WHOLE fax machine. I cant seem to fix it, either. Any suggestions?
  • winks11 Oct 16, 2008
    It permanently says 'paper jam' although there isnt one. I can't receive faxes either but can send. any ideas how to clear this would be greatly appreciated.
  • eli farag Oct 20, 2008
    i have the same problem:" paper jam , check cover,check film" message on the display.
    but no paper is jamed, film is ok,cover is closed.
  • drmiker42 Oct 31, 2008
    Get messasge that there is a paper jam, but there is none. If I turn off machine and restart, machine is ready. But if I try to make a copy or get a fax I get message there is paper jam.
  • Anonymous Dec 14, 2008
    2480C Fax SAYS PAPER IS JAMMED BUT THERE IS NO PAPER THAT IS JAMMED
  • dazzajo Apr 28, 2009
    My Brother MFC-3820CN printer/fax is saying on the LCD - "Paper Jam. Open cover, then remove jammed paper." I have opened the cover and there is no paper jam at all. Please help?!
  • dat2384 Apr 29, 2009
    I say ****
Darn, my problem was only solved after I blasted someone at HP and got a resolution to the problem, it was a new machine which did not work from day 1, after spending valuable time trying to find a resolution to the problem and speaking with someone who was very very difficult to understand, they then suggested I waste more time and deliver the machine to South Melbourne, miles away from where I purchased it at a local Officworks store. Turns out there was a bodgy card in the machine and this is why it did not work. Wast told we would have to wait without the machine for some 3 days, finally after more complaining I got it back after 48 hours. Sours the tase in my mouth and makes me wonder if I ever buy anything HP again.
Posted on Sep 22, 2008
Accidentally what?
Remove paper jam
you MUST get the tiny paper out of the machine. It will make more jams for sure. If you do not have a manual or someone handy try looking up your printer model on the web for jam clearing advice at the location where the paper ripped. Usually there are numbers. Sorry!
Feb 20, 2015 | Office Equipment & Supplies
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
Paper jam
Dear sir,
i am giving u setp to solved your problem,
Step one: Remove any loose paper.
Step two: Clear the jam from the back of the All-in-One
Step three: Clear the paper jam from the front of the All-in-One Step four: Clear the jam from the automatic document feeder Step five: Print a self-test report Thanks For Your Time,
Apr 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
Clear paper jam
may be there is small pice of paper inside just remove that.
Jan 20, 2010 | Canon FAX JX200 - Fax / copier - ink-jet...
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 15, 2009 | Brother Office Equipment & Supplies
Canon error code 6000 in mx308
please help me. i have canon print mx308. the have paper jams. paper has the full out from print. how i can finish the problems?
Jul 25, 2009 | Canon Pixma MP450 All-In-One InkJet...
Paper jam
Solution one: Clear the jam from the back of the All-in-One Follow these steps to clear a paper jam from the back of the product. Step one: Remove any loose paper Remove any loose paper from the input tray. CAUTION: Do not remove jammed paper at this stage. Step two: Clear the jam from the back CAUTION: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the product slowly and gently. Avoid touching the internal components of the product.
  1. Disconnect the power cord from the back of the product.
  2. Remove the rear door. Push in the two release tabs, and then pull the door toward you.
Feb 01, 2009 | Lexmark P6250 All-In-One InkJet Photo...
863 people viewed this question
k24674
