Question about KWorld PVR-TV 305U (KW-PVR-TV305U) Video Capture
I have PVR Plus DVD maker usb 2.0, I was previously using it on another laptop and it was stolen so we replaced and this one has windows vista. (I am unsure what the other one had, but I doubt that it was vista). I use this software for a camera that records video footage. I have installed the software but I can not use it to record footage. I use to go to the TVR button and then it would come up with another window but it does not do anything when i click on this button. Do i need to download another driver ? Please help. Rosemary
5 Suggested Answers
SOURCE: Sound is not recorded
Make sure that the your audio wiring is correct. The L&R audio cables from your VCR, etc should be connected to the red and white RCA jacks on the capture card cable. The small 3.5 mm phone jack from the capture card cable must then be plugged into your PC's line-in jack - usually blue. Then in the PVR application, select line-in as your source. This is necessary because the capture card only processes video. The audio signal is passed through to your PC.
Posted on Apr 24, 2008
  • 110 Answers
SOURCE: I press the record button which glows red the pc
It would most likely be easier for you if you open Windows Movie Maker and record from there.
Posted on Dec 29, 2009
  • 1481 Answers
SOURCE: when i record from vhs video camera using av out
u need to check ur audio setting in ur recording software, if it's line-in or mic that's selected.
Posted on Jan 16, 2010
SOURCE: audio does not record when
1.Download and install k-lite codec pack(full version) > http://www.free-codecs.com/k_lite_codec_pack_download.htm
2.Click the link below to download DVD MAKER USB 2.0 Software. driver/win7/Edit/V5.9.721.812_DVD_%20Maker_USB2.0.zip
Posted on Aug 31, 2011
Need to put system recovery disc's 2 disc set on flash since dvd drive has quit on me.
http://www.computerhope.com/issues/ch001366.htm
How to create a bootable Windows USB drive. A common use of a bootable USB flash drive is to use it to boot into Windows. Booting from removable media such as a USB drive allows you to perform diagnostics on a computer that is having trouble booting from the hard drive. You can also use the flash drive to install Windows, instead of using the Windows installation CD.
This guide will outline making a bootable USB flash drive with Windows XP, Vista, or 7. Before we begin, it is important to note that the computer you want to use your bootable USB drive must be able to use a USB drive as a boot device. Most computers built since Windows Vista was released are capable of booting to a USB device. Prior to the Windows Vista time frame, it is hit or miss with motherboards.
To determine if a computer is capable of booting to a USB device, access the computer's BIOS and check the bootable device list. If a USB device is listed, set the USB drive to be the first boot device. If you do not see a USB device in the list of bootable devices, your BIOS is not capable of booting to a USB device.
Note: You may need to have your USB flash drive plugged in when you access the BIOS).
Windows Vista and Windows 7 users To make a bootable USB drive for Windows Vista or Windows 7, you need to have Windows Vista or 7 installed on your computer. It is recommended that you have a flash drive of at least 4 GB in size, to store all the necessary files.
Tip: Before you start, plug in the USB drive and backup any files you have stored on the USB drive. The drive will be formatted during this process and all files on it will be deleted.
Note: You need to have a Windows Vista or Windows 7 DVD for these instructions to be successful.
1. Open an elevated Windows command line window by clicking Start, typing in cmd in the search text field, then pressing CTRL + Shift + Enter on your keyboard (at the same time). You can also access this by navigating to Start, All Programs, Accessories, right-click with your mouse on the Command Prompt menu item and select Run as Administrator.
2. At the command prompt, type cd c:\windows\system32 to change the directory to the Windows system32 directory. Ensure your USB drive is plugged in, type DISKPART, then press Enter. Type LIST DISK and press Enter.
3. You will see a listing of the disk drives connected to your computer. Find the disk number of your USB drive and type SELECT DISK [USB disk #], where "[USB disk #]" is the disk # for your USB drive. It should now state that your USB drive is the selected disk. If you're not sure what disk is the USB disk, eject the USB drive, perform step number 2 again, connect the USB drive again, and compare the results. Usually the USB drive will be the last drive.
4. Type in the following commands, one by one, pressing Enter after each command.
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(may take a couple minutes, depending on the USB drive size)
ASSIGN
EXIT
Keep the command prompt window open, but you can minimize it for a little bit.
5. You will now need your Windows Vista or 7 Installation DVD. Put the DVD in your computer's DVD drive. Open up My Computer and note which drive letter is assigned to your DVD Drive and your USB flash drive.
6. Go back to the command prompt window and type in D: CD BOOT (substitute your DVD drive letter for "D:", if necessary) and press Enter. Type CD BOOT again and press Enter. Lastly, type BOOTSECT.EXE /NT60 H: (substitute your USB flash drive letter for "H:", if necessary) and press Enter.
7. The last step is to copy the entire contents of the Windows DVD to your USB flash drive. To do this, in the My Computer window (opened in step 5 above), right-click on the DVD drive and select Open to view the contents of the DVD. Copy all the files and folders on the DVD to the USB flash drive.
Your USB flash drive is now set up to be a bootable USB drive for Windows Vista or 7.
How to or can boot from CD or DVD
Good luck.
Jan 12, 2016 | Compaq Presario CQ60-220US PC Laptop
I have bought a cannon XH-A1 HDV camera but find i cannot capture scenes using Pinnacle Studio plus v9 could you please advise me on what is required, may be studio 11 plus for windows XP will solve this?
Hi there
Pinnacle Studio Plus V.9 can only be used for editing DV and not HDV however Pinnacle Studio Plus V.11 can be used to edit both DV and HDV.
Please remember to put a good rating on this post.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 27, 2008 | Cameras
Can you still hook up a DVD & VCR Recorder through Rogers PVR and record to disc anything you have on the PVR memory to a disc to have a hard copy to keep and free up space on PVR memory????
I think you will have difficulties with DVD or Video tapes that have imbedded copy right signas l if you feed the video cable from old device into PVR s input source. You may find the PVR will refuse to record due to copyright . Does the PVR have a USB port you may be able to plug in a 20 Terabytes USB portable drive into it . I am not familiar with the rogers PVR but check its manual to see if it can.
you may be able to convert the DVD or Video Tape into an MPEG -2 or MPEG -4 format and read it on the PVR using a computer.
Copyright law may allow you to convert the type of media (you must own the rights to use original copy) to another format of media (PVR) for your use only. Check if copyright in your country allows this in Australia it is covered under https://www.comlaw.gov.au/Details/C2004C01235
also see
https://www.pctechguide.com/how-to-transfer-your-vcr-tapes-to-dvd/how-to-transfer-vcr-video-to-dvd-preparation
https://www.pctechguide.com/how-to-transfer-your-vcr-tapes-to-dvd/rip-import-copy-vcr-vhs-video-and-burn-to-dvd-with-nero
Aug 14, 2015 | Televison & Video
Forgot Sony Vaio password
I met the same difficulty for the previous period,and I know the easy an effive method that you can use Windows Password Reset to solve it by the Internet,while the use method is following.
Tip1:Download Windows Password Reset from http://www.windowspasswordreset.net and install it on other unlocked computer.
Tip2:Burn Windows Password Reset to CD/DVD or USB.
Tip3:Insert newly created CD/DVD or USB to your computer which you forgot its password and reboot it,and follow the instruction that follows.
I hope it can help you soon.
Jul 25, 2012 | Sony Computers & Internet
Reset windows vista
I met the same difficulty for the previous period,and I know the easy and effive method that you can use Windows Password Reset to solve it by the Internet,while the use method is following.
Tip1:Download Windows Password Reset from http://www.windowspasswordreset.net and install it on other computer.
Hope it can help you reset windows vita password soon.
Jul 20, 2012 | Toshiba Computers & Internet
DVD wont burn with dvd maker gets to 99% then stops
HI THERE,
When was the last time it was working fine?
• Do you have any third party CDDVD burning software?
• Are you able to burn DVD's using windows explorer?
First I would suggest that you try burning using another DVD and check if it works.
Method 1
Try one or more of the following:
Verify that the DVD burner is connected properly to your computer and powered on, and that any necessary software drivers for the DVD burner are installed. You can check your hardware settings in the Device Manager by doing the following:
1. Click Start, and then click Control Panel.
2. Click Hardware and Sound.
3. Click Device Manager.
• Make sure that the videos you're trying to burn are not corrupted. To see whether the videos you want to burn is corrupted, try playing or viewing them using Windows Media Player. If the files don't play using the Player, Windows DVD Maker cannot burn them.
• Choose a slower burning speed for your DVD burner by doing the following:
1. Return to the Add pictures and video to the DVD page, and then click Options.
2. In the DVD burner speed box, select Medium or Slow.
Troubleshoot problems with creating a DVD-Video using Windows DVD Maker
http://windows.microsoft.com/en-us/windows-vista/Troubleshoot-problems-with-creating-a-DVD-Video-using-Windows-DVD-Maker
Change Windows DVD Maker DVD-Video settings
http://windows.microsoft.com/en-US/windows-vista/Change-Windows-DVD-Maker-DVD-Video-settings
Method 2
Check if you are able to burn DVD successfully using Windows Explorer.
Burn a CD or DVD
http://windows.microsoft.com/en-US/windows-vista/Burn-a-CD-or-DVD
Method 3
Check in the event viewer to know the cause of the DVD burning failure and post back with the details.
What information appears in event logs? (Event Viewer)
http://windows.microsoft.com/en-US/windows-vista/What-information-appears-in-event-logs-Event-Viewer
Hope this helps!
Halima S - Microsoft Support.
Visit our Microsoft Answers Feedback Forum and let us know what you think.
Aug 25, 2011 | Compaq Computers & Internet
Dvd not reading
The objective here is for us to determine if the dvd is bad or Operating system is causing DVD not able to detect DVD's or cds
Hardware Issue
1. Try booting the computer from the DVD. Use the windows XP or vista or windows 7 to boot with it
2. If the DVD boots up. Definitely the DVD rom is working because it can read dvds outside of windows proceed to step 4
3. If it does not boot up make sure that the dvd is working on another DVD rom. And we are sure that the dvdrom is bad and needs to be replaced
Software Issue
4. Click start -> Click Run (Windows XP)/ Start Search (Vista) / Search Programs and Files (Windows 7)
5. Type Regedit
6. Click on the triangle/plus sign beside HKEY_LOCAL_ MACHINE
7. Click on the triangle/plus sign beside SYSTEM
8.Click on the triangle/plus sign beside CurrentControlSet
9.Click on the triangle/plus sign beside Class
10.Click on the Folder {4D36E965-.......}
Note: The first 4 digits might be the same we need the digit that has a 65
11. Restart the computer and your done
Jul 07, 2011 | Computers & Internet
I have a hp laptop that i dj with ..every time i open windows media player to burn a disc it says connect a burner and restart ....HELP!!!
The solution to your problem depends on a couple of things:
1. Which operating system are you using (for example, Windows XP, Windows 7, Windows Vista)?
2. Have you connected an external devise (such as an external CD/DVD burner) to the laptop in question previously? If so did it work successfully?
3. Does the laptop have a built in burner, and if so have you ever used it successfully?
Please repost with you original question plus answers to the above the questions and hopefully someone will be able to help you soluve the problem.
-Patrick
Dec 20, 2010 | Computers & Internet
How to use windows dvd maker
Here is a page from Microsofts website that explains about windows dvd maker:
http://www.microsoft.com/windows/windows-vista/features/dvd-maker.aspx
Jan 23, 2010 | Dell Computers & Internet
X-PERT DVDMAKER USB2.0
Yes - same problem here -
Downloaded the latest drivers from http://www.kworld.com.tw/Support_download.aspx?id=241&d1=5&d2=1
and they worked with Vista initially, then when Vista SP1 came out - doesn't work anymore.... Dohhhh Waiting for new version / patch.....
Apr 14, 2008 | V-Stream Xpert USB 2.0 DVD Maker...
KWorld PVR-TV 305U (KW-PVR-TV305U) Video Capture Logo
146 people viewed this question
Top KWorld Televison & Video Experts
kenwal
Level 1 Expert
Alun Cox
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
