Question about Sony KP-53HS10 TV
Blue part and green part of picture are out of focus. I keep going into the tv settings and trying to realign them but they keep getting off center. its difficult to get the colors lined up exactly perfect
  • Sony Master
  • 1,229 Answers
You have a bad convergence board. You need a tech to rework or replace the board. Take this note to a tech...you have some good advice on your side. Thanks for asking!
Posted on Aug 04, 2010
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Tip
What to do when you only have Green on a CRT Projection TV.
If you have a picture, but only in green on a 3 crt projection TV, I would try turning up the drive for the red and blue guns. They have probably changed over time and red and blue have lost drive and need a boost. Green makes up 70 percent of the picture compared to red and blue so the drive would not have to drop much to lose red and green but still have green. Keep in mind that this does mean that the CRTs are dying and may not have too much time left.
To turn up the drives first remove the back cover on the bottom half of the machine. Be very careful as you will have to work on this unit live. Do not touch anything other than what I tell you and keep one hand in your pocket whenever possible.
First look at the space above the main circuit board. Somewhere across the beam supporting the CRTs you will see a square box with 6 controls (shafts). You can locate the box if you follow the wires from the flyback to the box. The flyback is located on the power board and produces the high voltage. It will have 4 large red rubber wires coming out of it. Three go to the focus divider block (the box in question) then they go on to the crts (red, green, blue).
Once you locate the focus divider look at it closely. The focus controls are on top and the drives are on the bottom. They should be marked red, green and blue. You want to turn up the red and blue. Tune a picture with as much black as possible. While watching it turn up the red until you see a red tint or streak then turn down until it just disappears. Do the same with the blue. You may want to touch up the green also for good color balance.
If the set is working OK and the CRTs have enough drive left, your picture should look normal.
Thanks for using FixYa.
hardrocko
on Sep 22, 2010 | Toshiba 50H81 50" Rear Projection...
My sony tv stars blinking 5 times in a row, then the picture goes black for a second comes back then goes black again and it keeps doing it non stop
tv has a blanking picture mute circuit. adjust the screen controls which are located behind the speaker grill in front of set. there will be a access panel to unscrew in center and then you will see a black 4 inch square box with 6 physical knobs. 3 control screen the other 3 controls focus for red, green, blue. turn them down and slowly start turning them up. fixed.
Nov 11, 2009 | Sony KP-53XBR200 53" Rear Projection...
AKAI PT5598HD - I HAVE REPLACED THE CONVERGENCE BOARD AND PICTURE AND SOUND ARE "ON" BUT "PERFECT FOCUS" WILL NOT BRING BLUE INTO FOCUS. "PF" STOPS AT 37% - RED AND GREEN PATTERS ARE SHARP BUT BLUE IS...
Most of these sets have a SCREEN/FOCUS block---usually all black with 6 controls----you need to look close at it as one row of 3 will be screen controls---don't touch those----the other 3 will be FOCUS- MARKED in little letters will be r,g,b(red,green blue). TWO ways to adjust the focus: 1. carefully locate the blue focus control and adjust to see if blue will improve in focus. 2. each of the 3 large lens where the picture comes out have a wing nut and a slot--you can loosen the nut and turn the lens---usually best focus that way is if the part that turns is in the middle of the available area to move it.
I should point out that all projection sets intentionally de focus the blue--the lines if blue should be clear but never as perfect as green or red--this is normal.
I do this here for free so if this has been helpful give me a vote here.
if you need direct help:
etower.766@netzero.net
Aug 20, 2009 | Akai PT5598HD 55" Rear Projection...
I HAVE A HITACHI PROJECTION COLOR TV. MODEL 53UWX10BA 52". I JUST MOVED THE TV BY TRAILER FROM ONE TOWN TO ANOTHER, ABOUT 25 MILES, WHEN I PLUGGED THE TV BACK IN AND HOOKED UP THE CABLES, THE PICTURE WAS...
Replace the convergence Ic's with a kit that is available through your local parts distributor
You must replace all resistors in the kit
If you are not good at soldering and de- soldering have a local tv shop do it for you
Good luck
Jan 27, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Toshiba 57h81 green will not focus
Typically this is a convergence problem and can be repair relatively easy. Refer to this video to determine if you truly have a convergence problem. Also make sure you use your TV's original remote to make this adjustment.
Nov 15, 2008 | Toshiba 57H81 57" Rear Projection...
RCA P46921. Just changed flyback.
First, this assumes nothing else is going on to cause it. Here's what I did. Go to the 'green grid' via the v76 menu and go through the alignment there. Notice that there are red letters, blue letters, and a green grid. While you are in this screen, adjust the red, green, and blue focus watching the individual color's item until they are in focus. If they won't focus here, they won't focus and you have something else wrong (what I do not know). Then, return to normal programming, then select menu on the remote, then screen, then adjust projection tv convergence both horizontal and vertical crosshare. That ought to get it.
Mar 16, 2008 | RCA P46921 46" Rear Projection Television
RED AND GREEN LINES HORIZONTALLY ACROSS TV
This sounds like you may have bad picture tubes. Most likely the green and red tubes. You would have to have them replaced and realigned. I would call a Sony ASC and get an estimate to verify this. An onsite service call could verify if this is what's causing your problem.
Jan 22, 2008 | Sony KP-51HW40 51" Rear Projection...
RCA 52inch TV
If the screen control for the green picture tube is set too high, then the colors will be greenish, there will be green where there should be black and there will be fine curved lines (retrace lines) in the picture. If you feel confident then you can open the set and look for the focus block which has the 3 focus and 3 screen controls. One row is labeled Screen and the green control will be the center one. Try turning that control down a little and see is the green background and curved lines go away. If they do not go away then there is something more serious wrong. If you do not have experience working on projection sets then allow a qualified tech to handle it for you.
Jul 13, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
43H70 Blue Convergence out of line and will not line back up
If the blue colors will not line up, and the blue appears to sag inward from one or more sides, then you can bet that one of your convergence IC's has either cracked loose or burned out. The IC should be resoldered or replaced and the convergence realigned by someone experienced with projection TV convergence circuits.
May 21, 2007 | Toshiba 43H70 43" Rear Projection...
Sony KP-53HS10 TV Logo
53 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
