Question about Sharp AF-S120FX Air Conditioner
SHARP AIR CONDITIONER MODEL AF-S125FX HAS ERROR CODE E1. HOW TO CLEAR?
  • 143 Answers
SOURCE: AIR CONDITIONER MODEL #AF-S85FX--CODE E1
The Sharp e1 problem is a timer that is pretending to demand that you clean the filter. It stops the machine every 720 hours and forces you to do a procedure to get it to go away.
There are 2 possible procedures.
1) Unplug the machine. Hold down the power button while you plug the machine in and wait for a beep about 5 seconds long. Let go of the power button. Unplug the machine. Plug it back in.
2) Unplug the machine. Hold down the mode button while plugging the machine back in and waiting for a beep of about 3 seconds duration. Let go of the mode button. The machine will start. Turn the machine off by pressing the power button. Resume trying to use the machine normally.
If these don't work, the "demand to clean filter" timer is broken and you will need to buy parts to repair the machine.
(Don't you just love having a computer chip in every appliance?)
Posted on Jul 25, 2008
  • 3 Answers
SOURCE: Have a ge model ASW12ALS1 Air conditioner with error code E1
I have a G.E. window air conditioner that kept giving me the E1 error code and would not allow the unit to turn on. After much frustration (and no results from following various tips on internet forums) I decided that I had nothing to lose by taking the thing apart. After all, it was way past the warranty period.
Make sure the unit is unplugged before doing any of the following.
When I took off the cover (not the front grill, but the metal cover over all the internal parts) I found a small black envelope stuck to the top of the styrofoam inside the unit. What an inconvenient place to find what the error codes mean! It obviously means they don't want the average customer to know any of this. "E1" means a short or open circuit, unit inoperable.
With that in mind I noticed that the black two conductor sensor wire was broken. This is the wire that leads from the sensor on the front fins to the control circuit board. After soldering it back together and wrapping it well with electrical tape the unit works perfectly.
If you don't wish to try soldering the wire, it can be unplugged from the circuit board. I would not be surprised if you can order a new sensor (with wire and plug attached) from a G.E. parts supplier.
By the way, this particular G.E. 6100 BTU air conditioner was manufactured by Samsung electronics.
Posted on Jul 03, 2009
bobicehouse
  • 1524 Answers
SOURCE: we have an E1 code
Display Codes:
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Posted on Jul 22, 2011
  • 1218 Answers
SOURCE: Sharp AF-S125FX. Turns off with code E1 after
http://www.sharpusa.com/downloads/archives/product_manuals/air_man_AFS100FX_S120FX_S125FX_R100FX_R120FX.pdf
Go to this web site. It has your manual and instructions to your codes.
Hope this helps.
Posted on Nov 29, 2009
  • 674 Answers
SOURCE: Sharp AF-S125FX air conditionaer doesn't work when I plug it in
Sounds like there is something grounded inside the A/C unit or a fan or the compressor locked up. Could also be a motor winding in the compressor or one of the fans shorted thru.
Posted on May 02, 2010
What does E1 code indicate?
Your Air Conditioner Displays E1 (E2, or E3) In The Display ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsJul 8, 2010 - Home > Operation? > Your Air Conditioner Displays E1 (E2, or E3) In The Display Panel And Won't Turn On Share on Google+ Share on ...
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error ...
sci.tech-archive.net > Archive > sci.electronics.repair > 2005-08
Aug 5, 2005 - Owners of Sharp air conditioner models ... the error code E1 will appear... following procedure to clear the nefarious E1 indication, and obtain
Oct 27, 2015 | Heating & Cooling
Error code e1 starway air conditiiner
one day at home by mistek my top level and bottom level switch was off and i start me air condinion after that i get error E1
how to fix this error
thanks
jatin
Oct 13, 2013 | Sharp AF-S85FX Wall/Window Air Conditioner
We have an E1 code on our Sharp energy star model AF-S100FX air conditioner and the unit will shut off. What does the E1 code mean?
Display Codes:
Jul 22, 2011 | Sharp AF-S100FX Comfort Touch Air...
Ac shuts off E1 error message
E1 Error Code -->> Clean Filter
Owners of Sharp air conditioner models AF-S60FX, AF-S80FX, AF-S85FX, and AF-R80FX may experience the following (highly annoying) issue. After 720 hours of fan operation, the error code E1 will appear on the seven segment LED temperature display. This error code is intended as a reminder for the user to clean the air filter. However, because the procedure outlined in the user manual does not clear this error code as indicated, and the appliance has a nonvolatile memory that cannot be reset by simply unplugging it, the user of the appliance will become mightily frustrated, standing in potentially sweltering heat watching the appliance repeatedly shut down in the midst of operation with the "E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the "E1" code from the display, and plug it back in and re-start it, it will simply run for anywhere from a few minutes to a few hours, and then merrily shut down again with the same flashing "E1" code.
Many people at this point, having put the manual under the canary or some such, will simply return the unit and never buy another Sharp air conditioner. But for the tech-savvy and search-adept, I offer the following procedure to clear the nefarious E1 indication, and obtain another 720 hours of cooling bliss:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above exactly.
If you doubt the veracity of this information, or it does not work as expected, you can get it directly from the source at: 1-800-237-4277 (Sharp customer service line). You'll need to call between 7 AM and 7 PM US Central time, and have your model number and serial number ready.
May 28, 2011 | Sharp AF-S120FX Air Conditioner
E1 ERRORE COMES IN M Y AC WHICH REASONS
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
panel.
button.
the instructions above EXACTLY.
  • Date: 5 Aug 2005 06:33:46 -0700
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error Code
http://sci.tech-archive.net/Archive/sci.electronics.repair/2005-08/msg00472.html
Mar 01, 2011 | Heating & Cooling
I have a Sharp model number AF-S125FX that shuts off and I get the E1 message . I have cleaned the filter and tried the E 1 solution that was listed for a differant model number and have had no...
please check the relay of the comppressor and also the capacitor of the compressor. Check also if there is any issues in the controller section that can bring in the errors.
open and tigten all connectors, take a test on relays to manually switch on fan and compressor to confirm their worrking. the check for the micro controller's functiioning.
Sep 02, 2010 | Sharp Comfort Touch AF-R120EX Air...
My unit shut off now displays E1.
Sharp updated the procedure for resetting the E1 code.
1. unplug unit
2. hold the Power button while plugging the unit back in
3. keep holding the Power button until the unit beeps
4. unplug unit again
5. plug it back in and it should be good
Here is the updated user manual
Jun 05, 2010 | Sharp AF-S120FX Air Conditioner
May 02, 2010 | Sharp Heating & Cooling
Sharp AF-S120FX Air Conditioner Logo
643 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
