Question about HP Compaq Presario SR2180NX (RK548AA#ABA) PC Desktop
Ok my computer wont boot from the cd - HP Compaq Presario SR2180NX (RK548AA#ABA) PC Desktop
  • 3,153 Answers
Three causes
Bios is not set to boot from CD first
CD is not properly burnt as bootable (often the case in pirate copies of software)
CD rom drive is dying.
Posted on Aug 04, 2010
Pxe-e61 media test failure check cable
The PXE error message suggests that your computer is trying to perform a network boot which is why it is saying there is a cable issue.
Check your BIOS settings and disable the option to boot from the Network, plus check that the computer is configured to boot from a valid internal hard disk drive. It is Ok to have a CD or USB device listed ahead of the hard drive in the Boot order as this is normal to allow booting from CD or DVD media or USB devices.
Check that internal hard disk is operational, that the cables to it are firmly connected at both ends (the drive and the motherboard).
If you still have a problem, then provide more information on what symptoms or error messages your are seeing.
Jan 11, 2012 | eMachines C3070 PC Desktop
After installing Vista SP2. computer tries to reboot, but cant configure update 3of 3, so it reboots to start all over. tried setting CD as 1st boot, hangs waitng for CD-rom then boots off HDD. Tried...
ok go into your bios and load default settings.
set your cd-rm as your first boot device. then HDD.
save settings and exit. allow unit to reboot.
you can contact me direct e-mail. rain_catcher000_6@hotmail.com.
so i can give you one on one technical support.
Nov 14, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
After installing Vista SP2 update computer wont reboot from HDD or CD w/ vista CD
ok boot the computer and as soon as you see the black screen hit f1
or delete to enter bios go to boot menu and configure the cd-rom to be your first boot option. you can also hit f12 when you first see the black screen to enter boot menu. choose to boot from cd .
ok now install the disk and choose repair system .
Nov 13, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Error # 0x0000c1F5 It wont start windows, or even recover with recovery disk. Just blue screen with this message says possibly hardware or software problem.
ok, step one:
get a bootable CD (acts like a running backup boot), and put it in. your computer should boot up ok (NOTE* if it gives you the option to start in safe mode, don't. that will prevent the next step. start windows normally).
step two:
once it is up and running, eject the boot CD and get your recovery CDs/DVDs. insert them and follow the instructions. with everything recovered, it should work fine.
step three (optional)
attempt to create a new set of recovery CDs/DVDs.
Oct 26, 2009 | HP Pavilion dv6000z Notebook
My Computer Wont Boot Any Kind of Disk
First and foremost, Asus motherboards are garbage, avoid all asus products in the fututre.
You have to set the CD player up as first boot device. If you've done that and it still won't boot from the CD player, the player could have failed or is not connected correctly.
You may have to load software into the bios to start the CD player. Try to find a floppy disk that has CD support files on it. Boot from the floppy to load the CD drivers, and then search the CD for the executable file that you want to run
Sep 20, 2009 | ASUS P4S533-MX Motherboard
Hi guys my p.c wont boot! when I press the power on and press the front power button all the fans start running and the c/d rom starts trying to spin i.e the green light flashes 2 times every 5 sec's or...
Hi...
The problem that you have are same in common, if your cd room will not boot you need to first boot your cd room, you just go to the BIOS to first boot your cd room,, when you turn on the computer you need to press the delete key (or F2) after that, use the arrow key to select, chose the boot priorities, then you need to first boot your cd room, after the cd room first boot, press F10 to save, the ok
Good luck !!!
Regards
PCmania
Jul 09, 2009 | Gigabyte Computers & Internet
Hi all was ok in till i removed my hard drie affter i shut down the system and turn it off i removedthe hard drive now system will not boot back up it will power on but wont boot up ive unpluged everything...
hi im josh in cebu phils.may i help you? friend try to do this things. first i suggest to change new ide or sata cable.if still persist.try the following:
Boot order: Traditionally, a computer is set to boot first from the floppy drive, and then from the main hard drive (Drive C). This means that the computer will check the floppy drive first for boot files. If there is no disk in the floppy drive, the computer will then go to the hard drive to look for boot files. That is why if you leave a non-bootable floppy disk in the drive and try to boot up, you'll get an error message such as "NTLDR is missing. Press any key to restart." or "Non-system disk or disk error." This can be changed to pretty much any order, including CD and DVD drives. It is useful when installing Windows on a new or just-formatted computer to set the computer to boot first from a CD-ROM drive, and then insert the Windows installation CD-ROM into that drive. This saves you from having to use boot floppies that might or might not come with the Windows CD-ROM. Good luck.
Mar 05, 2009 | EliteGroup MB ECS A770M-A 770 SB600 AM2+...
Computer failure - HP a1120n - Wont enter safe mode, wont restore
If you can from another computer download Ultimate boot cd or Hiren's boot cd.  There are tools on the cd that can help you recover data or diagnose any hard drive problems or system problems.
Jan 13, 2009 | HP Pavilion a1120n (PX759AA) PC Desktop
Dell l400 problem
1.If you purchase an external USB CD drive you will not need to use your floppy discs for booting. 2. You can connect a USB CD drive to your system. 3. Your system will recognize any device plugged into your USB drive. 4. There is no CD drive available for internal installation in your computer. 5. With the USB CD drive plugged in and the windows installation disc inserted, your computer should take you through the setup program automatically.
Nov 10, 2008 | Dell Latitude L400 (220-3575) PC Notebook
Computer will turn on but wont boot
OK, have you tried checking the connections on your hard drive, afterwards try rebooting. If it still wont boot i suggest you back up data and boot the restore CD that came with your PC. If it still doesn't work , check your BIOS, most BIOS programs have a hard drive auto detection function so if it doesn't show, chances are the problem would be a defective hard drive.
Hope this helps:)
Oct 20, 2008 | Computers & Internet
HP Compaq Presario SR2180NX (RK548AA#ABA) PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
