Question about E-Machines eMachines Desktop PC
T2615 E-Machine No signal to monitor. Red Light on mother board is lit.
    Genius:
  • 1,554 Answers
Sounds like mb is not posting,
remove all cables to drives,
remove all cards except video , re-seat video.
remove all external devices keyboard,mouse , usb etc...
remove all but one stick of memory
re-seat the cpu
power up and if fans all turn and still no post then power down, clear bios jumper , swap memory
if fans turn and still no post pull memory ,power up does it beep,
if it does memory may be blown.
swap video card or cpu
at some point you wont be able to swap much without extra parts or help.
Posted on Apr 26, 2008
I have two monitors. One Samsung SyncMaster 2233 an one Samsung SyncMaster 2243. My problem is that the SyncMaster 2233 for some reason is totally black. I'm usually not terrible with these things, but my...
hello Gabriel
Could you check your SyncMaster 2233 for me and tell me your findings. If this monitor is connected from your computer and when both switch on, did the led indication lamp from your monitor lit steady green? or this lead indication lamp lit green then turns red?
1. If the led indication lamp lit steady green then there is nothing wrong with the settings, configurations, driver or hardware on your computer. The problem would be the backlight inverter lamp in your monitor is busted. Or it could be the inverter board that supplies high voltage for the backlight inverter lamp that is bad. You can replace the backlight inverter lamp located at the upper and lower part of the monitor with a replacement part you can purchase at shoppejimmy.com. Inverter board repair can be risky if you don't have the skill. Even opening the back cover of your monitor and replace by yourself the inverter lamp is risky too, could inflict more damage. you can bring it to a local professional service man.
2. If the led indication lamp lit green then turns red, then if not the video card the power supply section from your monitor is bad, you can replace polarized capacitor with same value. Just inspect and those with blown or leaking capacitor. You can also check the terminals and solder joints for the 15-pin vga terminal connector where vga cable is connected on your monitor. Resolder the terminals.
3. If the red indication lamp did not lit at all. Power supply section in the monitor is bad. You can check the output voltage from the power supply section. +5VDC is supplied for the main board and +24VDC is for the inverter board. Replace leaking or blown capacitor with same value.
Just remember, this should be done when computer and monitor is turn off
Post back if you have more questions. I am willing to give you assistance.
Feb 10, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
My wife went to work on the computer- then screen would not turn on. The power light was yellow. We unplugged and replugged in the monitor with no help. I finally did a hard reset of the PC and the monitor...
Yoy see the yellow power light because it is not seeing the video signal from your PC's video card, so that can be the possible cause since you reboot the computer and you get the signal back. Your computer may need to be looked at, try reseating the video card if it is not integrated into the mother board, reset the RAM, check to see if it has any caps with bulging tops in the mother board.
Jan 01, 2011 | Microsoft HannsG HU171D 17" LCD Monitor
Not gettin any signal from cpu
When the monitor shows no signal it means either the data cable going from the monitor to the computer or the computers graphics card needs to be replaced.
Sep 07, 2009 | Computers & Internet
NO SIGNAL. SCREEN IS LIT WHITE.
Try to check cable connector from main board to controller board, Check entire main board resolder voltage reg. ic, check MCU IC, Scalar IC, EEPROM IC and Crystal Capacitor.
Nov 13, 2008 | AOC LM 520A 15" LCD Monitor
LG Monitor Display Problem
1. Mostly Loose contacts in video section that means CRT Neck board dry points checke it.
2.Pl check VGA Cable RGB signal pins 123 to ground 75 Ohms (on OK condition).
3.check 5v supply
4.check SDL and SCL signals.
Oct 05, 2008 | LG Studioworks 563N 15" CRT Monitor
Red light and monitor will not start up
you need to shut down the computer and pull the power cord off powersupply then remove the wire harness that goes on to the mother board then press the and hold the computer on button for 3 seconds then plug in the the harness back on the mother board and and plug in all power cords then try to turn on the computer it should give u a beep or the monitor should go from orange to green good luck e-mail me if u want tbirdfan1@yahoo.com
Aug 07, 2008 | Intel Motherboard
Monitor port not working
ok...let's assume the monitor works, right? got another one around, by chance, an older dell one, maybe?
Feb 18, 2008 | Computers & Internet
My Dell Monitor isn't working....yellow light?
A yellow light indicates no signal input. Test it on another machine.
Feb 16, 2008 | Computers & Internet
Monitor displays signal cable disconnected
Check if motherboards you connect the monitor into has a video signal frequency range that the monitor supports.
Feb 01, 2008 | Dell UltraScan P1110 21" CRT Monitor
No display
Your monitor's signal cable is loose.Tighten the screws of the cable....
Oct 12, 2007 | E-Machines T2615 PC Desktop
E-Machines eMachines Desktop PC Logo
87 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
