Question about Refrigerators
Samsung Refrigerator-RT28. Problem: Zero cooling effect. This is the third time since purchase, we are facing this problem.Each time it is a hell of a job to find Samsung service centre here in Mangalore, to get our fridge repaired.The Shop from which we bought the fridge was found closed permanently, just 2 months after our purchase. Then there is no proper service centre here.Now the fridge is outoforder again, but nobody here to attend to it from Samsung centres.
  • 1462 Answers
SOURCE: SAMSUNG RS21DCNS
speaking from memory: remove the middle translucent section held by one screw at top and clips. you will then see the additional screws you need to undo
Posted on May 07, 2007
  • 87 Answers
SOURCE: Freezer is working/refrigerator works sometimes
No No No. The most likely reason that the evaporator fan is not running is that it probably uses the heater circuit for its neutral feed. I.E. In order for the fan to have 230v/115v it needs a zero voltage brought back through the defrost heater and defrost stat. I know this for a fact because I just did one today and have fallen for this scenario (ie bad fan motor) before. You need to check from ground(earth) to each side of the fan motor (which is easily accessible) and then across the fan motor windings. The chances are that you have zero voltage across the motor. The fan will also not run until the temperature of the evaporator coil has been brought below 0 'C (32'F) and this can take up to 20 mins (again speaking from experience). This is to prevent snow being produced after defrost. I would advise getting the engineer to come back if you have paid him money and do a proper job. Shorts in Amanas can happen but have not come across one yet. Hope this helps.
Posted on Aug 28, 2007
SOURCE: Ref: Servicing of Daewoo Refrigerator
I am in search of Daewoo Refrigerator Service Centre telephone and address in Mumbai, preferably in Dadar. If you know, please mail at mbsabnisandco@hotmail.com or Ph. 22653791
From,
Mrs. Padma D. Mulay.
Posted on Jan 21, 2008
  • 1314 Answers
SOURCE: Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Posted on Jul 22, 2008
SOURCE: Samsung refrigerator at my home under repair
my refrigerater is having earthing problem. can u give me the number of service center of the same for repair.i stay in kandivali mumbai 400101
Posted on Jul 29, 2008
Cooling problem in my Samsung rt29cdlb1/xtl
Hallo
Low humidity in your area set the thermostat colder or its the thermostat not switching of at the right temp.
Regards.
Jun 21, 2016 | Samsung Refrigerators
Samsung refrigerator not cooling
Sounds more like compressor failing to pump than board fault
May 19, 2012 | Samsung RF217ACPN 19.7 Cu. Ft. French Door...
Samsung RS2555SW - Refrigerator or Freezer is not cooling. I have removing the access panel inside the freezer. There coils have zero ice on them. The fan that is there does not seem to turn on. I have...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101 .
Oct 20, 2010 | Samsung RS2556 Side by Side Refrigerator
The freezer is working but the fridge side is broken. It's a side to side fridge. How do I fix it?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 15, 2010 | Sub-Zero 695/O Side by Side Refrigerator
Refrigerator is not sufficiently cold. Changing
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Jul 14, 2010 | Sub-Zero Bottom Freezer Refrigerator
THE REFIGERATOR SIDE OF MY 632 IS NOT GETTING COLD
More than likely you need to "dust off" (with a vacuum brush tip) the coils in then upper compartment. Remove the upper cover and vacuum off the face of the coils located on the right side. This needs to be done every six months.
May 28, 2010 | Sub-Zero 632 / S
Sub Zero 561 Refrigerator side is not cooling." the freezer side is working perfect.."
pop the top panel and clean your condenser,this is the most common problem,other than that it could be your compressor or refrigerant leak.this model i believe is two separate systems so one will not effect the other/. good luck!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 17, 2010 | Sub-Zero 561 / F
My samsung refrigerator model RB1855SL is experiencing a temperature sensor issue. The freezer target temp is set to zero degrees and the refrigerator to 38. The unit cools itself down to the target...
We've had tonza problems with ours too, kept building up frost, temperature sensor acted up as well. Piece of trash if you ask me. Never fixed it (did not want to throw money at it). Amazingly we just got a new one... another Samsung.... (with 4 yr extended warranty though this time!)
Oct 13, 2009 | Samsung Refrigerators
Low Cooling from Samsung RT28 Frost Free Refrigerator
just water, tray is for defrost only nothing else happens with tray. make sure it is in right area to catch water (should see tube sticking out about inch or two) also look inside under crisper trays for drain hole to see if stopped up from moveing fridge, use straw or something small to push in to check ( it's just a drain) also make sure unit is clean under and on back, no dust bunnies ( use vacuum to clean)
Jun 02, 2009 | Refrigerators
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
