Question about Sanyo Televison & Video
I need to configure my Sanyo DS24205 so it can run a DVD - how do I configure the video ouput channel - it currently skips from 78 to 2
  • 11,896 Answers
Connect your dvd player and turn it on.
Then go to tv menu,
Go to channel setup or tuner setup
Find the "autoprogram" option and select it.
Let it run thuroughly.
When it is done, it will ad all available channels and video/audio inputs to it's memory..
Posted on Aug 04, 2010
What do I need to do to hook up cable to this tv?
This TV has the following inputs:
RF input, composite video/audio input
The easiest would be to use coax cable
Aug 11, 2017 | Sanyo DS24205 24" TV
Tv code search
I can give you these. You should try them until one works hopefully. 0506, 0311, 0612, 0002, 0428, 0802, 0412, 0619. Sometime the universal remotes will not operate everything so be sure to try the power on/off and the volume and try changing channels before assuming the code is wrong. One of these should work...
Aug 04, 2009 | Sanyo DS24205 24" TV
How can i make my DVD player work for this tv?
It is a low priced set or it would have video input jacks to answer the first part of your question. Now to fix this all you need to do is go to Radio Shack and pick a Video Addapter that will convert the Audio and Video over to Channel 3/4.
Dec 21, 2008 | Sanyo DS24205 24" TV
Sanyo DS24205 24'' TV Not Recieving Signals.
Ok, cable connected is good. Can you move tv to another connection or run another cable from a working source. Maybe go into setup of tv and check input.
Nov 17, 2008 | Sanyo DS24205 24" TV
How can i watch dvds on this old sanyo tv?
does your tv have a scart socket or is it pre scart, if it does, and you connect the dvd player via the scart then the tv should auromativally switch to av when the dvd player is switched on. failing that, if you have no scart, then the only way you can watch dvd is by connecting a flylead from dvd player to tv, (take out antenna and put it in that socket) and then start a search if you can, normally the buttons for this are behind a flap somewhere on the tv. if you have no scart or a way of tuning tv, then i dont think you can watch dvd through that tv
Sep 06, 2008 | Sanyo DS24205 24" TV
Input channels
I would try to replace the AV switch IC which directs i/o signals to the tv decoding stage.
Jun 25, 2008 | Sanyo DS24205 24" TV
Input problem
If you have the original remote, hit video, source, or input button, if it dont have them, then try to change the tv to channel 00 (zero or zerozero), if not then the channels might have to scroll to it, from channel 02 down to make it loop, if it goes to the next highest channel, then you need a remote. It may be set in the menu options to have the video source not saved to your list of saved channels. when you scan the channels, the tv might not look for the A/V source (audio / video), maybe just the RF source. The 3 DVD RCA wires are 1 video and 2 stereo, one stereo for left and one stereo for right. The TV has only 2 , 1 for video and 1 for mono 1 channel sound. This wouldnt have anything to do with why you cant use the DVD player. but try that with the original remote (or a universal remote that is set to your tv set that has either video, input, source or something similar. It is what tells the tv to change from the cable source (RF) and the AV source (the Red White and Yellow plugs, in your TV's case, 2 plugs, one yellow and the other either red or white or something). Dont really know how to explain it much more but hope it helps.
Jan 05, 2008 | Sanyo DS24205 24" TV
DS24205 TV INPUT PROBLEM
if you have a sky remote or know someone who does you could try programming it by using one of these codes, try them all one at a time
Sanyo 0159, 236, 073, 100, 064, 174, 185, 367, 039, 245, 246, 398, 241, 572, 583, 037, 132, 182, 244, 191
Sanyo TV is stuck on Video screen
Universal Remote should do it.
Sep 08, 2007 | Sanyo DS24205 24" TV
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
