Question about Kicker CVR12 Car Subwoofer
Subwoofers not bumpin, amp is still on
I have just upgraded from two kenwood 12's w/ 200 rms, i now have two kicker cvr 2 ohm dvc, and now my subs have cut out and wont come back on and no fuses are blown, and the amps light is still on, im pretty sure ihave them hooked up right for my amp which is a kenwood kac-9152d, please need help thank you
  • 1 more comment
  • howdoiuhhhh Apr 27, 2008
    the amp has a good power source, good ground. i tried hooking up one of the kenwood subs i had, and no power either, to either channel on the amp. didnt see any pinches in the speaker wire...that would short circuit it right??
    i tried hooking another amp up in my truck with one of my old subs and different speaker wire, and same thing, power on the amp was on but no sound. so its not the amp or subs....right? maybe rca cables or something but i dont see how they would just go bad!!
  • Cameronharmo Aug 17, 2008
    i wuz goin down the road and my stuff cuts off, tried cables from mini amp for highs power ground and remote good but the rca cables from the highs amp wouldnt make the subs hit but the sub rca cables would make highs hit put new amp in and still same problem
    Scholar:
  • 186 Answers
Check to make sure there is a good input to the amp. Next check each sub to another source to make sure they are good. Look for any reset on the amp.
Posted on Apr 26, 2008
  • 1 more comment
  • Scott
    Scott Apr 26, 2008
    So what have you tried? Is there a good source to the amp? Is the problem isolated to the amp only?
  • Scott
    Scott Apr 27, 2008
    A pinch could short circuit it. Try this just as a test - To guarantee the subs are good, grab a home stereo receiver with audio jacks on back. It doesn't matter the ohms because it will only be a moment of a test. Connect the Receiver to the subs. Just want to see if the subs respond. Highly unlikely they both blew but at this point it will feel good to know for sure. My gut feeling then leaves me with one of two things left then. On the Amp there should be a trigger wire that kicks on the amp that often connect the radio. If not, you might want to take it into the shop to make sure the amp itself isn't blown or bad.
    Keep Me Posted.......
  • Scott
    Scott Apr 28, 2008
    Could be a bad connector somewhere in the source wire or the receiver head unit is causing issues with it's audio out? If you can easily get behind, just run long another pair of RCA wires around to the Amp to see if it's a wiring problem that developed.
    Keep After it!
I have a kicker 10 comp d dvc 4 ohm 600 watt. How do I run a obcon 2000i 2 channel amp to it
You can't. Total mismatch of power and impedance.
You need a mono amp that can push the RMS watts of the sub @ 2 ohm (sub wired parallel).
More info here - http://sparky3489.webs.com/
Jan 22, 2015 | Kicker Car Audio & Video
I have 2 15" dvc 4 ohm kickers 1000 watt / 500 rms &a1000 watt avionixx 4 channel amp what would be the right wiring scheme?
need to know the ohms on the amplifiers then might can tell you best solution for system
Mar 05, 2013 | Car Audio & Video
How do i wire a kicker cvr if it has two reds and blacks
the sub is a dual voice coil, and depending on how you wire them, gives you different bass response as it drops the ohms in your amp. it can be wired for 2 ohms one way 4 ohms another way or 1 ohm depending on what ohm the coils are. to learn more about this got to rockford fosgate.com, click support, then click woofer wiring wizard, this will answer all your questions about dvc subs.
Feb 10, 2010 | Kicker CVR15-4 Car Subwoofer
Wireing two dual 4 ohm kicker cvr 15s on a memphis pr1000 at a 1 ohm load. I trying to get these kickers to hit harder. Do I need a bigger amp or what?
CVR series do not have large power handling capabilities.
Your subs will melt before the amplifier is used to its full potential.
If the subs arent in a ported enclosure - do that.
They both handle 500w rms - so the pr1000 is perfect.
bass response is all in the enclosure!
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | Kicker CVR152 CompVR 15 2/4 ohm 1000W...
I want to know the best subwoofer wiring diagram for three kicker cvr 10 inch subs, 2 of them are dvc 4 ohm and 1 is dvc 2 ohm, the amp that i am using is jl audio 500.1 1.5-4ohms stable. can anyone help...
if the amp has a 2 outputs then i would wire the two 4ohms together, and the 2ohm by itself. and if its a 4 channel output then wire them all sepretly, if its a 1 channel output then wire the two 4ohms together and leave the 2ohm sub out
Nov 29, 2009 | Kicker CVR10 Car Subwoofer
I have an Audiobahn A8000T amp and 2 12" Kicker CVR (DVC) Dual voice Coil. The Subwoofers are 2OHM a peice. What is the best way to hook this all up to run a 2 OHM load to my subs?
This is a link to Kicker for your CVR12 Subs...if you have the 2 ohm version (2 ohms per voice coil) and you have 2 speakers ....you will need to wire EACH speakers voice coils in series to get 4 ohms from each speaker and then wire the 2 speakers in parallel.....as in....2 ohms in series with 2 ohms = 4 ohms....both speakers wired same way, then in Parallel with each other = 2 ohm load. Page 2 of this link gives examples of both series and parallel wiring of your speaker.
http://www.kicker.com/sites/default/files/2006CompVX.pdf
If you are still not sure as to my description of ' How To',
PLEASE respond and I will attempt to explain it EXACTLY via wiring directions.
Nov 18, 2009 | Kicker CVR12 Car Subwoofer
Powering 4 6x9 speakers, need amp
Hi firstof all your deck isnt really putting out 52 watts x4 more like 17-22w rmsx4 ,companies like to throw out some crazy numbers it seems. If your into Kenwood try out a KAC-8404 4-channel on the mids/highs that will put 50 w x4 rms at 4 ohms or if you wanna go a lil louder try the kenwood x600f that will throw 100w rms on each 6x9 at 4 ohms no problem. My system is very similar to yours but running 4 pioneer 5x7's in all the doors and powering it with the 8404 its loud and clean ,fan cooled and no problems at all. My subs are a pair of 15's soundstream t-4's powered by an Alphasonik pma2500a its throwing 800w rms on each sub running in stereo at 2 ohms.It can drown out the mids if i set it that way but my mids /highs cant take as much power as your kenwoods can or else id step up to the x600f too.
May 10, 2009 | Kenwood KFC-6982ie Car Mid-Range Speaker
What car amp to use to run 2 dvc subs
You need a stereo amp that can run 400amps
continous, with an output of 4 ohms. These should
not be too hard to find and they are getting smaller
all of the time. Make a practice look on ebay.
They give you pictures and you can check the dimentions first, so you know it can fit between
your two deck lids.
Apr 25, 2009 | Kicker CVR8-4 Car Subwoofer
How to wire kenwood amp to kicker cvr 12"
How you wire it depends on how hard you want drive your amp. If your woofer runs 4ohm per coil I would wile it in series (amp +to sub +1 sub -1to sub +2 amp - to sub -2) then run it for a week and see if it has enough power. the lower your Impedance (the resistance load on the amp) the harder your amp works and more THD (noise) is produced. (Dclass amps aren't know for being clean to begin with) configured like this your amp will see 8ohms and sound the clean east. if this turns out to be not enough power wire it in parallel and double the output. wire amp + to sub +1 and +2 then amp - to sub -1 and -2.
A word to the wise... start with your volume very low and work up slowly most speakers will puk up the voice coil before the amp starts to get warmed up. you would hate to have to buy a new sub.
Have fun
Rob
Dec 10, 2008 | Kicker CVR12 Car Subwoofer
How to adjust the controls and gain on my kenwood 9104d 1800w amp
Hook the speakers in series to decrease your chances of blowing the amp and/or speakers themselves. And at high volumes make sure that the bass control is set for flat response.
Jun 25, 2017 | Car Audio & Video
Kicker CVR12 Car Subwoofer Logo
117 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
