Question about Vizio Televison & Video
My tv will not turn on. I've had this Vizio for 8 months. what could the problem be. I have changed connections hook up. Still will not turn on. I tried pluging another electrical appliance to the same electrical outlet. The outlet is working fine. I paid to much hard earned money for this tv not to work
  • 11,361 Answers
You need to check inside, but I would suggest you to get it repaired under warranty, it should not go out in less than a year, lemon set!
If you open it up then will void any warranty that you may have.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Aug 04, 2010
We are trying to hook up a VIZIO sound bar model#S3820w-Co to our Vizio TV we also have Directv and a dvd player hook to this tv which wire do we hook from sound bar to Tv
If the TV and sound bar have an optical connector, then get the optical cable to connect the two. If not then use the audio out jacks on the TV and don't forget to change the audio set up to switch the sound to the sound bar.
Oct 29, 2014 | Televison & Video
32in Vizio getting no channels
You have to go to your menu screen and change the settings from antenna to cable that should take care of it, and should be able to do a auto scan to load channel memory
Mar 26, 2013 | Vizio VX37L Television
Connect Dell Inspiron 6400 to VIZIO E601i-A3 60-inch 1080p LED HDTV using VGA Connector
When you connect the vizio try changing the resolution settings on your laptop to see if that makes a difference. Could be that your video card output is not really compatible with the higher requirements of the Vizio.
Sep 20, 2017 | Vizio 60" E601I-A3 Full HD LED-LCD TV
I lost my netflix connection on my vizio blu ray player
I've searched for an answer regarding vizio vbr231 netflix connect issue to no avail. so here are my 2 cents. I'm taking mine back to Costco and exchanging it! lol. so called experts want to char4ge depending on the level of urgency to you WTF! EF them,mofos, crudentials are they've installed the systems before. just sayin
Jun 17, 2012 | Vizio VBR231 Blu-Ray Player
Vizio vm60p hdtv scanning problem
I had the same problem. Change your input to dtv even if you are using coaxial input. Then go to the menu screen and select tuner settings. Dtv setting should appear.
Nov 17, 2011 | Vizio VM60P 60 in. Plasma TV
How do I hook up my digtl cable and dvd to my Vp422 vizio tv
Surround Sound to 8 or 9 8 is best
DVD to HDMI 1
Direct TV to 10
If you have these connections on your peripherals, this is recommended..
May 12, 2009 | Vizio VP422 42 in. Plasma TV
Vizio L37
Sounds like a bad av connection on the main board. i would try to connect the xbox via an alternate av connection or hdmi to verify problem. contact vizio support and describe your problem. they have had trouble with this main board. some of their parts have lifetime warranties and the service call is free. changing out the main board is a pretty simple process, about an hour or less. hope this helps.
Sep 28, 2008 | Vizio L37 Television
42 in lcd vizio "no signal"
if the TV have a no signal sign which means most of the important part is missing. Try checking your connections. The best way is to hook up a dvd player using AV input (the yellow, red and white). make sure that you turn the device on and whatever input you connected the device to is selected. if your TV is a P50HDM model, the TV will shut itself off after a short period without and input connected.
Sep 08, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
Televison & Video Logo
137 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
