Question about Huffy Cycling
Need a bearing size or part number to replace a pedal bearing in a huffy stone mountain multi speed 26" bike
    Brigadier General:
  • 8,546 Answers
Pedal bearing or bottom bracket bearing? Your best bet would be to take it to a local Bike Shop and have them assess it.
Posted on Aug 05, 2010
Testimonial: "Thank you"
How do I change gears on a 10 speed bike?
move the shift lever while pedaling. The gears won't change unless you rotate the crank at the same time you actuate the shifter. If this doesn't work then the derailleurs are out of adjustment and will need to be adjusted. Check with your local bike shop for service.
Oct 19, 2014 | Huffy 26 In Ladies Mojave Gulch Bike
What is the replacement pedal bearing in a huffy mountain 24" bike?
at the Huffy quality level of pedals, you most likely won't be able to service the part, you can find a set of replacement pedals at your local bike shop starting at about $10 for the pair.
Apr 28, 2014 | Huffy Cycling
Need size for huffy cranbrook pedals
I am going to provide a link to a video that will show you how to determine the correct size of pedal for your bike. Identifiying the Proper Size Pedal for Your Bike
Oct 02, 2012 | Huffy 26 in. Cranbrook Cruiser Bike
I have a broken derailer cable on an old huffy backwater bike where can I get a new one?
You can buy one from most neighbourhood bike repair shops. This should be a pretty standard item for them.
Jul 25, 2012 | Huffy Men Mountain Bike (26")
Huffy 18 speed multi terrain Stone Mountain..need help tweeking the gears please!!
Web search just about anytthing in a short concise way like "how to adjust derailleur" and get an instant answer.
Good resource http://www.parktool.com/blog/repair-help/categories/derailleur-systems
Aug 16, 2011 | Huffy Cycling
I dnt hav a problem i just need to know the size so i can buy another pedel tht fits
You can't buy one pedal. Take one out and bring it with you to the store so you get the right size.
http://bicycletutor.com/replace-pedals/
Jul 29, 2011 | Huffy Teton 26 Men's Dual-Suspension...
The back tire rubs against the frame only when I pedal. The tire wobbles a little bit while coasting, but appears to pull over to the frame while pedaling. Huffy Stonemountain 2 - 18 speed bicycle.
Either the wheel is mounted wrong, moving at the axle or the wheel is not straight true and strong (spoke tension issues). Look at it. Try to wiggle the wheel with your hand.
Use search engines for "how to" questions.
Jul 14, 2011 | Huffy Men Mountain Bike (26")
Chain Broke on a Huffy Tundra 18 speed 26" bike. I need to know the size chain to replace or the master link/chain connector to fix the chain.
if the bike has gears it does not have a master link, that is for single speed bikes only.
You will need an 8spd chain for your bike (1/2" x 3/32), these will fit any 6,7 or 8 spd bike. This requires a special tool to install ($8-$25), I would recommend taking into a bike shop and have them do it if you have no experience with this type of chain.
Side note: if you do own the tool, you can repair a broken chain for a temporary fix in the future, so may be worth buying. Check around, many bike shops offer basic repair classes and cover this.
Nov 14, 2010 | Huffy Men Mountain Bike (26")
I need an owners manual for a roadmaster mt storm by huffy
The best I can do is to provide you with the manual that Huffy provides for multiple bikes. The manual below is for multi-speed and freewheel bikes.
Huffy Multi-speed Manual
Hope this helps. Thanks for using Fixya.
Note: If the manual link above is not useful you may contact Huffy directly at:
Huffy Bicycle Company
6551 Centerville Business Pkwy
Centerville, Ohio 45459
(800) 872-2453 customer service
Monday - Friday: 8:00AM - 12:00PM; 1:00PM - 4:30PM EST
Jul 13, 2010 | Huffy Men Mountain Bike (26")
Cycling Logo
265 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
