Brother MFC-3240C All-In-One InkJet Printer Logo
Posted on Apr 26, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you scan on the Brother MFC-3240c?
There is a scan buttone on the top but no flat glass plate to put your document onto.
  • ele62 Apr 26, 2008
    Thanks for your help Ele62
Anonymous
Level 2:
  • Expert 57 Answers
  • Posted on Apr 26, 2008
Anonymous
Expert
Level 2:
Answers
57
Questions
0
Helped
43502
Points
128
It scans it like a fax machine or a copier does, feeds the paper instead of pulling it from the tray.
Brother mfc-8910dw scan lines
The scanner bar & glass need cleaning with neat alcohol in very very small amounts, hope this helps...
How to scan a picture from my printer to my pc i did it one day and i can't remember what i did i thought i did the same thing the printer is a brother mfc-490CW
Hi
2 way on how to scan.
1. Put the document either in the top feed or in the glass scanner. Press SCAN button in your printer and then navigate and choose save AS PDF or OCR or FILE.
2. Go to the scanner icon located in your computer and then put the document to be scan and then press scan button.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
3helpful
Original document fed into top feed tray of mfc 7440N model come out with few thin black lines on the mid left of the scanned file. Scanning file from glass has no issue.
You need to clean the narrow glass strip on the left side of the machine when you open the cover. There is likely lint or something on this glass. This is where the auto document feeder pages are "imaged".
7helpful
2answers
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
2helpful
Bad Scan Quality Using Brother MFC-7820N Document Feeder
Look to the left side of the flatbed glass for a thin strip of glass by itself. When you scan from the glass, the document stays put and the sensor moves across the document. When you scan from the feeder, the sensor stays in that glass strip and the document moves across the sensor. See what I mean? I would check the small feeder glass for dirt or scratches from staples or other flotsam. Also not a bad idea to blow out the feeder path with some compressed air to ensure the documents is handled smoothly. Hope this helps!
I need to learn how to scan a document and save to a file. I have a BrotherMFC-3240C machine.
This link will help you to learn how to scan from your BrotherMFC-3240C machine. I hope this information help you. Khaled
http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000240/BH3_UsaEngSoft_C.pdf
1helpful
Scanning with the brother mfc 7300c
FIRST OF ALL YOU WILL NEED TO INSTALL THE BROTHER MFC SUITES CD THAT CAME WITH YOUR MACHINE, WHEN YOU HAVE DONE THE INSTALLATION, BRING UO THE PROGRAM PAPER PORT OF YOUR MONITOR, PUT THE COPY THAT YOU WANT SCAN ON THE FLAT BED, IN THE UPPER LEFT HAND YOU WILL SEE PHOTO OR TEXT CLICK WHICH EVER YOU ARE SCANNING, NOW CLICK SCAN ANOTHER SCREE WILL COME UP AND ASK YOU IF YOU ARE USING THE FKAT BED( THE GLASS OR THE DOCUMENT FEEDER. CLICK THAT, NEXT TELL IT AGAIN PHOTO OR TEXT OR WHAT EVER THEN CLICK SCAN, ON THE SCREEN YOU WILL SEE THE SCANNING TAKING PLACE, THEN YOU WILL SEE THE SCANNED ITEM  EITHER IN MY DOCUMENTS OR MY PICTYRES DEPENDING WHERE YOU TOLD YOUR COMPUTER TO PUT THEM HOPE THIS HELPS, GOOD LUCK BROTHER SR TECH
2helpful
Lines showing up on document after scanned
Do you have lines, too when scanning a document?
In this case the scanner glas needs cleaning. Use a soft cloth and some glass cleaning solution and wipe the scanner glass. The lines should disappear.
Cannot scan an e-mail to send
OK I beleive you it is a valid product!!!!!!!!!!!
have you installed scanning software as well as print drivers?
Brother website get full software and driver package (under drivers) and install
Norman Weimar
Norman Weimar
k24674
