Question about Whirlpool GEW9250 Electric Dryer
I am broke and could not afford to to buy a new one"cloth dryer". The motor still working but does not produce heat. I did clean the dryer's system thoroughly but it still has no heat. if any one has idea please help me. Thank you;
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
You have a bad heater element or a blown hi-limit thermostat OR, you have a phase that's out on your AC socket. Check for 240V at socket or, if you don't have a meter, reset the breaker.
Posted on Aug 04, 2010
My Maytag Neptune Dryer works great with no close in it. As soon as you put clothes in it wont stay hot.
Instructions
Things You'll Need:
* Level
1. Ensure that the dryer's door is latched shut and that the power cord is plugged into an electrical outlet. Also check the home's fuse box for a tripped circuit breaker.
2. Make sure that the "Air Fluff" button on the dryer's touchscreen has not been selected if the dryer fails to produce heat. Also clear the lint screen if the dryer fails to heat.
3. Check the exhaust system, which exits from the back of the dryer for clogs, which commonly occur if the lint screen has not been cleaned regularly. Also ensure that only 4-inch metal exhaust tubing is used for the exhaust system. If clogs are present due to an improper exhaust system, the dryer will fail to dry the clothing completely. Also avoid overloading the dryer, which can also cause a drying problem. The amount of clothing equal to a single wash load should not be exceeded.
4. Check for the presence of loose items if the dryer produces noise, such as coins and loose buttons. The dryer will also produce noise if it is not leveled properly. Place a level on top of the dryer and turn the foot located on the bottom of each corner of the dryer until the dryer is level.
Feb 23, 2011 | Maytag Neptune MDG6800 Gas Dryer
Loooking for pull cord 5hp/ 22 inch snow blower ultra by murry. My cord broke yesterday mhagansr@comcast.net
Instructions Things You'll Need:
  • Level
Jan 28, 2011 | Dryers
Pilot light goes out about 2 minutes after starting dryer
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 25, 2010 | Whirlpool LER4634J Electric Dryer
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Not getting hot
Sounds like the heating element has broke. If it spins and doesnt produce heat its best to call someone out, or buy a new one. If nothing works, check fuses and connections
Apr 13, 2009 | Dryers
Hi I am trying to clean my drain unsder my washer. I do not know how to pull the cover off.?? It appears I need special alan wrenchs for two little screws..?? any ideas??
Though the idea of repairing a clothes dryer can be pretty intimidating, the truth is that some types of repairs are surprisingly easy. Yes, dryers appear to be built like huge, impervious metal boxes, but they are typically pretty easy to open and relatively simple to fix.
As shown at How Clothes Dryers Works, a clothes dryer has a motor that turns a big drum containing the clothes, a heat source for blowing warm air into the drum to dry the clothes, and controls for operating the motor and heat source.
Some dryers have an electric element to do the heating while others utilize a gas flame; the latter must be vented.
Clothes dryer problems generally occur because the heat source doesn't heat properly or the motor fails to turn the drum.
If a gas dryer doesn't dry properly, the first thing to check is the pilot light or igniter--it may not be lighting the burner. The second thing to check is the dryer's vent-if it is clogged with lint, the heating system won't work properly.
Pay attention to basic safety measures when working on a dryer. Always unplug the dryer, and turn off the gas supply to a gas dryer at the appliance shutoff valve.
As with most appliances, maintenance will keep your dryer purring. Clean the lint trap after every load, and clean the vent system once a year.
Dec 13, 2008 | Whirlpool LTE6234D Top Load Stacked...
Kenmore heavy duty dryer
You didn't mention if the motor runs or if it heats. If it does both of these, you'll need a new belt.
Mar 09, 2008 | Dryers
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Broken Kenmore 80 Series dryer
Sounds like you have a simple broken belt problem.  If you are sure the motor is working and the heating circuits are functioning, but the drum does not turn, the drum belt probably broke.  They are inexpensive to replace and are carried by almost any appliance repair store.
Oct 21, 2007 | Dryers
Electric Dryer overheating
sounds to me like you have a venting problem or the vent is plugged check the vent clean it out. make it as short as you can , also if you can use rigid metal vent...if all is clean then the blower wheel must be broken.. or loose. check for air flow out the vent ...let me know what you find..
Aug 26, 2007 | Kenmore Elite 20972
Whirlpool GEW9250 Electric Dryer Logo
26 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
