Question about DeLonghi Toaster Ovens
The top heating element of my DeLonghi DO1289 won't work anymore. Is this something that can be replaced, or do I have to toss the oven? I've only had it for three years. Thanks!
4 Suggested Answers
SOURCE: Heating elements
The upper element for AS690 is part# 512623
Thw lower element for AS690 is Part# 512624
Available at www.nelsonappliance.com/Toaster+Oven+Parts.html
or
http://abtecparts.com/delonghi_toaster_oven_elements.htm
Posted on Jul 27, 2008
SOURCE: Delonghi AS690 toaster oven lower element won't turn on.
Cactus Bob Is WRONG. I've had these replaced; and then, when it happened subsequently, bought the part and replaced it myself. You have to take the entire thing apart. but it can be done.
Posted on Nov 14, 2009
  • 10865 Answers
SOURCE: The top heating element has
Hi. Once any appliance is over ten years old it is difficult to find parts. Your best bet is to replace it. J.
Posted on Jul 31, 2010
My toaster oven stopped heating all together.
your heating element has gone bad or there is some bad wiring in the oven itself
to check open up the toaster oven and look at the wires coming from the heating elements inside to the timer on the front panel if there is no bad wiring then the heating elements are bad and the toaster oven needs to be replaced
Jan 02, 2011 | DeLonghi XR640 Retro 1500 Watts Toaster...
Bottom heating element warped then stopped working
can you get in to replace the element?then do so if you can it is easy just look how it was put in as you take it out to replace it!
Sep 28, 2010 | DeLonghi AD699 Airstream Digital 1500...
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    The blue light does not go on and the heating element does not wo
    The problem is most likely the timer switch. They are very poorly made and tend to overheat causing eventual failure. B&D will be of no help and you will not be able to find the original switch. There is a switch made for Delonghi ovens that will work if you need a timer. The part # is 5218104600 and can be purchased for $10.98 at the Gourmet Depot website. This switch has a toast timer only if you turn it clockwise and turn counterCW for oven ON. Timer is only about 13 minutes. There is another switch that has a 120 minute timer. It looks the same and the part # is Delonghi 5218101800. May be harder to find. Another solution and a much cheaper one is to replace the broken switch with a single pole single throw toggle switch rated for 20 amp's at 120 volts. You will need to turn the oven on and off manually and you will no longer have a timer but at least you will be able to use your oven!
    Apr 23, 2010 | Black & Decker CTO649 Toaster Oven with...
    Bottom elements on DeLonghi AD699 failed.
    Solution: buy a new toaster oven. I determined that the manufacturer stopped selling replacement heating elements in 2006, three years after the model year (2003). After market parts makers don't sell the elements for safety and liability reasons. So I got a new one.
    Nov 17, 2009 | DeLonghi AD699 Airstream Digital 1500...
    BOTTOM ELEMENT DOES NOT WORK
    If the top element is working, then it is either the element, the wiring harness , or the control board.
    Since both elements are controlled through the same temperature probe, then the temp. probe should be OK.
    The heating element must be removed and tested using a multimeter.
    The part is tested disconnecting wiring from element contacts, setting a multimeter to read impedance at Rx1, and reading Ohms on element contact.
    If the circuit is open (no continuity and infinite Ohms value), then the element has blown and must be replaced.
    If the element has continuity, test the wiring harness, then replace wiring harness or control board.
    All the test must be done by a trained repairer, strictly observing all health and safety rules.
    Regards.
    Oct 21, 2009 | DeLonghi EO1238 Toaster Oven with...
    Mar 13, 2009 | DeLonghi AS690 Airstream Stainless Steel...
    Heating elements
    or
    Jan 03, 2008 | DeLonghi AS690 Airstream Stainless Steel...
    Toaster Ovens Logo
    205 people viewed this question
    Top DeLonghi Toaster Ovens Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Steve
    Craig Butler
    Craig Butler
    Are you a DeLonghi Toaster Oven Expert? Answer questions, earn points and help others
