Question about Refrigerators
Eveytime i pug my refrig in the power trip - Refrigerators
  • 4,793 Answers
You have a short circuit somewhere on the fridge (imposible to diagnose without a circuit tester..)
Posted on Aug 04, 2010
Refrig. sometimes trips GFI, sometimes not. Unplugged plug shows 5 ohms between power contacts. What's up?
Have you checked the GFI with some other appliance? Like a mixer. Sometimes the GFI are overly sensitive.
Jul 14, 2015 | Kenmore 18.2 cu. ft. Top Freezer...
Kenmore 25314922101 not powering on
HI
Does it trip your mains? If yes disconnect and replace your defrosting element.
Feb 16, 2014 | Freezers
No, i have a 50 amp GFCI in my main panel and i am trying to feed a sub panel in my garage. i have power to everything until i plug anything in or turn on the lights.
GFCI's are really temperamental. They are this way for a reason. It seems like you have something that is tripping this. I would try using a regular 50 amp breaker, and then see what happens. You can also try process of elimination. Shut everything down, then bring power up - one item/circuit, appliance, etc. at a time. This will narrow down your problem. Also, if you have a refrig/freezer on this GFCI, this could be tripping it too. Any appliance, etc. that has a motor - usually leaks to ground just enough for the GFCI breaker to sense, and trip it. I hope some of these solution's will help you...Good Luck!
Sep 01, 2011 | Cutler Hammer 1 Pole 15 Amp Ground Fault
Is my refrigerator running properly? Refrig. went into defrost mode about 6-7 hours the other night. Unplugged and pugged it back in and it seems fine. Now, the refrig is performing defrost every 1-2...
if its a timer controlled defrost it will defrost every time the timer gets to the spot where it cuts off the compressor and activates the defrost circuitry,if its an "adaptive defrost type system" then it depends on the amount of times the door is opened,the amount of frost on the evaporator coil,etc and is determined by sensors in the units walls
Mar 08, 2011 | GE Refrigerators
I was just using the microwave and it died on me. No power to the unit that I can tell.
Check the circuit breaker. If it's pugged into GFCI type outlet or an outlet that's run from one, make sure the breaker didn't trip there.
Mar 05, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My wife opened the refrig. door and saw a blue flash now all the lights in the refrig side are out and the temp gage indicator lights are out as well.
Blue flash sounds like an electrical short (spark) that blew a fuse or tripped a breaker.
Is the machine running? You need to unplug and check the switch that turns the light on and the lamp socket itself for frayed or broken wires befoe restting breaker or replacing fuse. Once your electrical problem is resolved you can reapply power
Jan 20, 2011 | Whirlpool GS6NBEXR Side by Side...
Side by side refridge was dirty and I cleaned
I would pull the refrig out , and remove the back panel , covering the compressor and fan motor . Check to see if the fan is working . Fan not working , causes the divider panel , to get very hot . Also , fan not working , causes the compressor to over heat and cut off on the overload .
Sep 29, 2009 | GE Refrigerators
My Whirlpool refrigerator trips the main breaker of 40 Amps
A refrig cannot pull 40 amps in defrost , unless there is a direct short in the defrost system ( timer , heater , bimetal ) . I would use an extention cord ( for test purposes only ) , and try a different plug . Sounds like the circuit breaker is weak . In defrost , the MOST you should get , is 6 amps . This will not throw a 40 amp breaker . If you have an amp meter , remove the back refrig panel behind the refrig , and connect to one of the power cord lines (just not the green ground ) , turn into defrost and check the amps . This will tell you if short is in refrig , or weak breaker .
Sep 06, 2009 | Whirlpool ES5FHAXS Side by Side...
Whirlpool Gold GS5SHG Refrig/Freezer trips gfci
Sounds like the condesor coil fan motor went bad and shorted in the windings or stator. It can be replaced fairly easily. You can get the mtor from one of the online part stores and install through the base of the unit next to the compressor. you should clean the area of lint while your down there, it helps keep it operating more efficiently.
I’m happy to help further over the phone at https://www.6ya.com/expert/josh_87ce33216d7b2148
Jun 08, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
